BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Concerning inconsistencies with F30 ZF8HP transmission oil change. Advice?
ARMA SPEED
      09-09-2020, 01:15 PM   #23
Jimmert
69
Drives: BMW 420i F36
When your car is jacked up such that the rear wheels can freely spin (but make sure car is level), you can go through the gears without problem, don’t hold the brake though. If it switches back it didn’t engage the next gear.
2000rpm at idle seems correct yes.
      09-09-2020, 01:39 PM   #24
Slick_FThirty
Slick_FThirty's Avatar
126
Drives: 13' BMW 328i Xdrive
Originally Posted by Jimmert View Post
When your car is jacked up such that the rear wheels can freely spin (but make sure car is level), you can go through the gears without problem, don't hold the brake though. If it switches back it didn't engage the next gear.
Thanks.
I'm slightly confused because the FCP euro video says ""with the car on the ground and foot on the brake pedal, put the transmission in gear and go through all the gears""
And at gear 8, I would imagine the wheels would be spinning very fast.
I should leave this to a mechanic next time.
All these videos and instructions skip these items.
If you can imagine it, you can achieve it.
If you can dream it, you can become it.
      09-09-2020, 03:01 PM   #25
Slick_FThirty
126
This is what the writer of the FCPEuro Blog Post wrote:
""The second fill/level check can be done with or without the engine running (ideally the engine should be running) as long as the temp is within the specified range""
Looks like we were doing it right?
      09-09-2020, 03:08 PM   #26
Slick_FThirty
126
Either way, ZF says keep the engine on, so I will be filling with the engine on.
      09-09-2020, 03:53 PM   #27
montr
157
Drives: 2010 335d, 2018 430i G-Coupe
This is wrong. It is essential that the engine must be running.
To fill the transmission, go to the hardware store, buy a funnel and about 5' of flexible vinyl tube to fit the funnel. That will allow you to fill the transmission from the top of the engine bay while the car is still running. When the transmission is full, you go under the car and put back the fill plug (engine still running)
      09-09-2020, 03:56 PM   #28
Slick_FThirty
126
Agreed.
      09-09-2020, 06:29 PM   #29
Slick_FThirty
126
As for going through the gears, I've watched a Myle training video which stated that you need to only go through park, drive, reverse, and neutral, and you only have to switch to manual mode once. Just switch over, no need to cycle through gears. Foot on brake pedal and engine idling.
Source :
This makes sense to me.
I'd be curious to hear other's thoughts.
      09-09-2020, 10:55 PM   #30
Slick_FThirty
126
Filled up the transmission with the engine running. Took an additional 2 litres.
Silky smooth and fast shifts, better fuel economy, and seems quieter too.
Thanks everyone.
obert1783.00
      09-10-2020, 03:02 PM   #31
montr
157
Thanks everyone.
Great, that was fast.
In the E90 forums, the transmission oil filling has been discussed many times. Everyone that filled the transmission without the engine running ended up with an under filled transmission. You have to start filling without the engine running, after level reach the fill plug, then you start the engine.
      03-04-2021, 08:43 PM   #32
HassanM5
Drives: 2014 M5
Just went through this on my 2015 328i. Did a complete service then noticed I couldn't get the same amount of fluid in as I got out. Forgot to keep the car running during the initial refill. Tried again today with the car running and it took about 1 more quart. Such an annoying procedure, especially without a lift. Definitely would leave this to a shop next time. Also, why the hell there isn't a better way to check the level is beyond me. For something so critical and sensitive, there has to be a better way.
      11-03-2023, 11:16 PM   #33
Kadised
Drives: 2007 BMW 335i
How bad would it be to drive 200 miles after refilling? I didn’t do the second fill with the engine running, but did it within the temperature range and right after turning the engine off so I was able to get about 4.3 quarts / 4 Liters back in. Is this enough fluid to not cause any problems until I can get it in the air again? F30 LCI / ZF 8HP50 if that matters 😅
      04-26-2024, 08:04 AM   #34
Aleksandar97
Drives: BMW X5 E70
Slick_Fthirty, Can you give us un update whether you have had problems with the transmission now it’s been 3 and a bit years later? Thanks in advance.
      05-05-2024, 09:10 PM   #35
kidkar
Drives: 2013 320i xdrive
Did my 320i X drive F30 about 6 months ago and everything is fine.
-car off
-loosen fill plug.
-loosen trans pan (lower one side first so you control the falling oil).
-collect oil and measure how much came out.
-remove drain pan and clean edges of transmission.
-install new drain pan( moisten seal with fresh fluid), criss cross bolt pattern. Torque bolts think it was 10NM (not super tight).
-remove fill plug and fill till fluid comes out, replace plug.
-start car, no gas, idle engine while running through P-D-R a few times.
-wait til can trans temp is 30-50C.
-with car running, add more fluid until it comes out of the fill hole.
-tighten plug.
For me, this was the first trans fluid change done in this car, meaning it had a factory fill in it. There was no leaks or loss of fluid before I did this.
-measuring what came out 4.75L and comparing to what I put in was the same.
This was 6 months and 15k KM ago, no issues and still smooth.
Did change at 130k KM currently at 146k KM
