F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Plug and Play Amp upgrade for Base Audio system
proTUNING Freaks
      04-04-2022, 09:31 AM   #67
rytec
Belgium
Drives: BMW316da Touring 2014
Location: Ypres, West-Vlaanderen (near the tranches of WWI)
Originally Posted by Daveyvtec View Post
Hi all, this isn’t a question, more a very simple solution I have found that I’d like to share and hopefully make someone’s life a little easier and their crap base audio system sound a little better.
Firstly, I’m not affiliated with Vibe. I’m just a guy with an F30 that has base audio and got to the stage where I wouldn’t listen to music because the sound system was crap.
I’ve seen a lot of threads in a lot of different forums talking about what upgrade can you do and what coding and wiring do they need to do so. I’ve researched the hell out of this so here’s my two cents for you all.
I just bought a Vibe Powerbox 65.4M with BMW T harness. It took about 25 minutes to fit. I had to remove the head unit so that meant removing some trim which was really only 6 torx head T15 (vids on YouTube of course). It came with clear and concise instructions so your technical level doesn’t need to be that high to hook it up. I placed the amp under the glove box between the underside of the glove box and the removable panel. It fit like a dream and no visible wires with enough room for it to breath.
I used BimmerCode to change my head unit EQ range to HiFi
As someone who’s always had good sound systems and was horrified by the quality of the base audio system, I can tell you that this upgrade is the best €210 I’ve spent. It powers the 4 door speakers and the two sub ls with no extra wiring.
Running the stock speakers, the difference is nuts. Although if you push them hard enough, they will crackle. I had to fine tune with gain on the amp for front and rear and mess with some settings on my Apple Music EQ but after that it’s just a matter of adjusting your bass and volume settings through your idrive sound options depending on what you listen to.
All in all this was a very simple and effective upgrade to a very lacklustre sound system. I’d recommend it to anyone and I hope this post does someone some good.
Thanks for this info, could you point me to the right internet link where I can buy the correct unit and cbla harnas for my F31? Thanks a lot
And is it worth to replace the speakers with ICBMW100L speakers, I read something about these are speakers with tweeters build in. Do you need to place extra cables if you replace the standard base speakers in the doors with these?
BR
Ryan
      04-04-2022, 09:42 AM   #68
Billfitz
Billfitz's Avatar
8297
Drives: '15 328iX GT
Never use coaxial midranges, they place the tweeters too low. If you're going to add tweeters do it the right way, mounted by the mirrors in the front, at the top of the doors in the back.
Appreciate 2
      04-04-2022, 09:42 AM   #69
rytec
Belgium
Originally Posted by Jimmert View Post
I run Full in the front and HPF on the rear. (+ Hifi coding)
I have an Android HU and with this the sound is also better than the BMW oem.
Is it usefull to change in Bimmercode that to hifi to test or not?
And I think it's better to first replace the speakers with this combination?
If I would place this amplifier, will that produce better sound with Android HU too?
      04-04-2022, 09:46 AM   #70
Daveyvtec
33
Drives: BMW F30 318 M Sport
BR
Ryan
Hi all, this isn't a question, more a very simple solution I have found that I'd like to share and hopefully make someone's life a little easier and their crap base audio system sound a little better.
Firstly, I'm not affiliated with Vibe. I'm just a guy with an F30 that has base audio and got to the stage where I wouldn't listen to music because the sound system was crap.
I've seen a lot of threads in a lot of different forums talking about what upgrade can you do and what coding and wiring do they need to do so. I've researched the hell out of this so here's my two cents for you all.
I just bought a Vibe Powerbox 65.4M with BMW T harness. It took about 25 minutes to fit. I had to remove the head unit so that meant removing some trim which was really only 6 torx head T15 (vids on YouTube of course). It came with clear and concise instructions so your technical level doesn't need to be that high to hook it up. I placed the amp under the glove box between the underside of the glove box and the removable panel. It fit like a dream and no visible wires with enough room for it to breath.
As someone who's always had good sound systems and was horrified by the quality of the base audio system, I can tell you that this upgrade is the best €210 I've spent. It powers the 4 door speakers and the two sub ls with no extra wiring.
Running the stock speakers, the difference is nuts. Although if you push them hard enough, they will crackle. I had to fine tune with gain on the amp for front and rear and mess with some settings on my Apple Music EQ but after that it's just a matter of adjusting your bass and volume settings through your idrive sound options depending on what you listen to.
All in all this was a very simple and effective upgrade to a very lacklustre sound system. I'd recommend it to anyone and I hope this post does someone some good.
BR
Ryan
I got my unit from Crown Customs Car Audio as Vibe didn't ship to Ireland 😂 I found them after googling the unit itself so if you just do that, you'll find a seller with little hassle.
In terms of the replacement speakers, I just left mine stock. I'm gonna replace them at a later date as I've been focusing on a few cosmetic upgrade for the outside of the car. But in answer to the second part of your question, I don't know as I haven't done it.
Dave
rytec2.50
      04-04-2022, 10:02 AM   #71
rytec
Belgium
Which speakers would be good to use in the doors as an upgrade for my base system?
I'm wondering which unit provides the sound now.
When I use the Android HU, this unit will create the sound now, not my OEM unit, correct?
So I think that I first will upgrade the speakers in the doors and maybe the subs later on to experience the difference.
      04-04-2022, 01:05 PM   #72
Billfitz
Billfitz's Avatar
8297
I'd buy a used set of the OEM Hi-Fi speakers from someone who replaced them. The entire aftermarket speaker industry is predicated upon the assumption that the OEM Hi-Fi and H-K speakers are deficient. They're not. Even the base are reasonably adequate when they're only powered with the 15 watts or so that the base OEM HU is capable of. I can't comment on your Andriod HU without seeing complete accurate specs for it.
rytec2.50
      04-04-2022, 02:16 PM   #73
kierownik
100
Drives: 2016 BMW 320i Sport Black
I guess it depends what your expectations are.
I actually disagree with what you said. I installed coaxial Focals in my rear doors and it massively improved the sound quality for the people travelling at the back.
In fact I believe that If instead of all the hassle with installing front HK mids and tweeters I just fitted focals I'd also be very happy. They do sound good, really good.
rytec2.50
      04-04-2022, 02:18 PM   #74
kierownik
100
BR
Ryan
I've got those speakers in my rear doors and they sound really really good. I can fully recommend them.
They are 1:1 replacement and there's no need for any alterations.
rytec2.50
      04-05-2022, 01:58 AM   #75
rytec
Belgium
What did you install in the front doors then?
      04-05-2022, 02:37 AM   #76
rytec
Belgium
Thanks a lot for this tip! Can you also buy secondhand HK speakers to use with the standard amp or isn't that possible or only possible with hifi speakers?
Great idea of buying secondhand hifi speakers! I will have a look on Ebay and have to find out the right part number for my BMW F31 2014.
Do the hifi speakers sound better than the standard speakers?
I don't think the Android HU has a power amp itself, but is the amp of the car build in the oem radio unit behind the trim or is the amp somewhere else and is it replaceable easily?
      04-05-2022, 06:07 AM   #77
kierownik
100
Harman Kardon mids and tweeters. But to be brutally honest... I think I would be equally happy with Focal speakers both at front and back. The HK's have a lot of trebble, lacking a bit in the mid tones section tho. Where Focals at the back sound much more balanced than HK. Don't get me wrong. HK sound really good and after some adjustments in the sound menu I found a good setting. But like I said before... If I had a chance to compare HK mids + tweeters and Focals before I installed HK's I would go with Focals on all 4 doors. Not only would that save me quite a lot of money but the sound would be a bit warmer all together. HK speakers are great but I guess to get them to release their full potential you would need some sort of equalizer which basic bmw HU doesn't have.
But that is just my own opinion after some time of having it all installed. It all depends what your music/sound likings are.
rytec2.50
      04-05-2022, 06:29 AM   #78
kierownik
100
HK or HiFi speakers will work with HU itself. That's how I run it. HU outputs 4x25W RMS.
rytec2.50
      04-05-2022, 06:41 AM   #79
rytec
Belgium
Thanks too for this good info, did you already replaced the standaard subs under the seats by Focals?
      04-05-2022, 07:59 AM   #80
Billfitz
Billfitz's Avatar
8297
H-K will work. However, I know that the woofers are 8 ohm, so I suspect that the midranges are as well. That being the case they would need more power to reach the same output level as the 4 ohm Hi-Fi.
rytec2.50
      04-05-2022, 08:07 AM   #81
rytec
Belgium
"same output level as the 4 ohm Hi-Fi." to reach this 4 ohm it's possible to use the standard oem radio output without an extra amp?
Is it possible to install an extra amp in the car and connect it to the original radio unit or do you need another radio unit together with an amp?
      04-05-2022, 08:12 AM   #82
Billfitz
Billfitz's Avatar
8297
I wouldn't do anything without first adding an amp, as that's the weakest link in the chain, not the speakers.
https://f30.bimmerpost.com/forums/sh....php?t=1475424
rytec2.50
      04-05-2022, 11:43 AM   #83
kierownik
100
I'm not so sure about mids being 8ohm. I run HK mids and tweeters at the front. All powered by the HU and they are loud or even slightly louder than my original base speakers were at the same volume level. The only downside is lack of proper eq.
As a matter of fact I didn't even feel like I needed to add an additional amplifier until I decided that I want to replace my subs which I decided to give up anyway and keep the original subs. They're not that bad and I'm not a super loud listener.
      04-05-2022, 12:16 PM   #84
Billfitz
Billfitz's Avatar
8297
Only BMW knows for sure, and they're not saying. Someone would have to measure them. If the HU has a pre-shape EQ that's tuned for best results with the base midrange with no tweeters then it's not going to be right with the H-K or Hi-Fi midranges with tweeters. The low power of the HU internal amps will also result in high THD when pushed to even moderate levels, which can add to harsh response through tweeters. I doubt that the HU is capable of 25w/ch, as it requires a sophisticated step up power supply to get more than 15w or so from 12v.
      04-06-2022, 12:10 PM   #85
TeaorCrumpets
Drives: 2017 F31
Personally having the base audio .. biggest Bang for your buck was upgrading the front speakers and MMI box wow what a difference and TBH i dont see the need for a amp now.
      04-07-2022, 06:22 AM   #86
kierownik
100
That's exaclty what I've done. Mmi box + HK speakers at the front +focals at the back and it's really good. No need for amp unless you want more powerful subwoofers
I also recently upgraded my screen to 8.8".
      04-07-2022, 07:27 AM   #87
wataroo
Japan
Drives: 2015 F30 320i
Originally Posted by FastFrog View Post
Originally Posted by wataroo View Post
I finally got a hold of the right esys to code my HU, and changed the Audio_system from STEREO to HIFI. Also changed Amplifier_variant from INTERNAL to EXTERNAL. Not quite sure if the later actually switches the internal amp off or not. Does anyone know? I now run full front and HPF rear.
I prefer the above setting over what I had before. To me, vocals stand out more. There's less bass but I feel it sounds tighter. One issue I have is Carplay music volume is low compred to other sources such as FM radio. Hence I have the gains at max. I will probably play around with these settings but am happy for now.
No, the EXTERNAL setting won't switch off anything, nor switch the HU output from High-Level to Low-Level. It only affects the EQ.
You will find an in-depth write-up about the sound settings and coding here: https://www.diymobileaudio.com/threa...n-most.437890/
I've finally found the setting of my liking. It's definitely a personal preference, but this works for me. After some going back and forth with the setup, I am very happy with this upgrade given the money spent! Your suggested link really helped. Thanks once again.
[HU settings]
AUDIO_SYSTEM > HIFI (STEREO was too EQ'd for me)
AMPlIFIER_VARIANT > INTERNAL (EXTERNAL didn't give me enough volume)
AUDIO_SYSTEM_VARIANT > VARIANT_2 (VARIANT_1 had weak bass and VARIANT_3 had too much bass)
[VIBE settings]
Gain at Max
Running front at FULL and rear at HPF
Note: Since I had already installed tweeters, this is not a stock base audio.
      04-18-2022, 08:21 AM   #88
Incomplet
Australia
Drives: '13 328i
Thanks for sharing your installation guides/tips!
Am I able to install the amp if I already have an MMI box? Could daisy-chaining be possible?
Thanks!
Tags
amplifier, audio, base, upgrade
f30post
