12-08-2023, 03:14 PM | #1 |
41
Rep 226
high beam flash not working in the daylight SOLVED
I never did get to the bottom of this, works at night. I coded the front fog lights to flash with the high beam when you pull the stalk. Any ideas anyone? Has some suggestions from members here about coding it but nothing works
Martin
12-08-2023, 03:26 PM | #2 |
8297
Rep 16,186
Is the light switch set to automatic? If so a plausible explanation is that it prevents the lights from flashing when it's not dark outside.
12-08-2023, 03:33 PM | #3 |
41
Rep 226
I was just researching this, yes it is, so if I leave the switch in 0,which still allows the DRLS to be on day or night, the high beam flash will work in daylight. I’ll check it tomorrow, I guess the light sensor is the culprit in auto mode
Martin
12-08-2023, 09:39 PM | #4 |
8297
Rep 16,186
Culprit may not be the right word. The auto setting insures that the lights come on when it gets dark, and it would seem that they don't come on when it's not. Finding a way to override that function may be impossible.
12-09-2023, 02:07 AM | #5 |
41
Rep 226
Just a bit annoying if I have to have the light switch setting to 2 during the day just to be able to use flash to pass. Means that my low beams are on when they don’t need to be, that’s what the DRLS are for. Ideally you want the setting in zero
Martin
12-09-2023, 05:26 PM | #9 |
295
Rep 486
I've checked mine - same, High Beam flashes in every position of the switch.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
12-10-2023, 01:26 PM | #10 |
41
Rep 226
Checked in daylight, high beam doesn’t flash in any setting unless the low beams are on. Don’t think I can revert the coding as I’d lose everything I’ve coded, and I’ve coded a lot. I’m wondering if when I coded the front fog Lights to flash with the high beam there’s some kind of conflict.
Martin
12-10-2023, 09:16 PM | #13 | |
295
Rep 486
I have coding done too, but the other way - fog lights can be activated with either: parking lights, low beams or high beams. I often enough use fog lights at late dusk/pre-dawn hours when I don't need low beams.
12-11-2023, 09:47 AM | #14 |
41
Rep 226
Yes it’s a bit strange, when I code ABBIEGEL L and R function to 05 I get the high beam working but lose the functionality of manually turning on the fogs with the switch. In 08 setting I lose the high beam and retain the functionality of the fogs via the switch
Martin
03-18-2024, 01:03 PM | #15 |
41
Rep 226
Solved my Mr Pingu…Perfect! You are absolutely correct, the Above settings I changed the values and everything works as it should.i changed the values of ABBIEGEL to 09 and 0A function, and output 0B and 0C. FERNL 1 was already the correct settings, and I changed FERNL 2 to output 01 and 02. I now have high beam flash for both xenon’s and fog lights to flash in the daylight in auto switch setting, and the fog light switch remains able to turn on and off manually. The 0 switch setting also (DRLS ON) also gives me high beam and fogs flashing together, and the fog light switch can also be turned on and off manually. Can’t thank you enough for all your time and effort, it’s been frustrating me for so long, much appreciated
Martin
