03-20-2018, 07:52 PM | #221 | |
707
Rep 1,170
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter. |
03-21-2018, 02:20 PM | #223 |
707
Rep 1,170
No problem, easy mistake, thanks!
03-21-2018, 05:52 PM | #224 |
191
Rep 521
03-22-2018, 01:21 AM | #226 |
707
Rep 1,170
If you can do a before install dyno run and an after install run, due to variations in dyno's it's the only way to get really meaningfull numbers. The delta between the before and after is what's really important, not just an after number which without the before won't really tell us much.
StockLOL50.50 |
03-22-2018, 01:58 AM | #227 | |
22
Rep 47
2018 440i MPPSK
2018 X3 M40i |
StockLOL50.50 |
03-22-2018, 10:59 AM | #228 |
707
Rep 1,170
Understood, I wasn't able to do before and after my MPPSK for pretty much the same reason's. Let us know what you're thinking after the install.
scofflaw22.00 |
03-23-2018, 12:55 AM | #229 |
51
Rep 155
Can’t you just run the Dinan in pass through mode or where it’s not turned on then turn it on and run again? And congrats Scoflaw you waste no time, car will be a rocket!
03-23-2018, 09:54 AM | #230 | |
191
Rep 521
Experienced tuners in the space should know how to reset the ECU to clear any long term trims or if it resets every time you turn the engine off, and what PIDs to monitor to find out if it's still adjusting trims. With many cars, hopping on the highway, going up an exit, turning around and coming back would likely clear it out, if it won't clear up in a couple dyno pulls. |
03-25-2018, 02:44 PM | #231 | ||
22
Rep 47
2018 440i MPPSK
2018 X3 M40i |
StockLOL50.50 |
03-26-2018, 12:37 AM | #232 |
51
Rep 155
03-27-2018, 12:33 AM | #233 |
22
Rep 47
It will probably be next week or so for install. And yeah, unfortunately only 91 (+E85 occasionally) for now. I might make a trip to the Bay to find some 93.
2018 440i MPPSK
2018 X3 M40i |
03-27-2018, 01:26 AM | #234 |
51
Rep 155
I messaged Dinan and asked if the tuner adjusts to 91 they said it does. Waiting for their response on running e85. They said on 91 it should run smooth like stock MPPSK during normal driving and hard acceleration, not sure what the bad reviewers are doing wrong.
scofflaw22.00 |
04-05-2018, 10:31 PM | #235 |
22
Rep 47
I've got an appointment next week for S1 install so I hope to have something positive to report after that.
2018 440i MPPSK
2018 X3 M40i |
04-11-2018, 12:16 AM | #236 |
22
Rep 47
Well I had the S1 installed this morning and have driven it maybe 70 miles since then just messing around tonight.
I honestly can't say I notice an appreciable difference (yet?). I feel a little bit more torque in the lower range of Comfort mode, but Sport mode feels about the same. I haven't been able to push it hard yet but it doesn't seem noticeable. I've made sure it's enabled on the app. Sport+ feels like a rocket as usual so I can't comment if there was any change there. Hoping to get a dyno run soon.
2018 440i MPPSK
2018 X3 M40i |
04-11-2018, 03:24 AM | #237 |
348
Rep 352
Drives: 2007 E90 335i, 2016 F80 M3
I really wish I could say I was confident enough to order this for my 440i Xdrive with 6MT & MPPSK. In Alberta some gas stations have 94, but most have only 91 (which is what I usually get). it would appear the odds are against me based on what people have said, due to my combination of 6MT, Xdrive, & more regular usage of 91.
gonna play it safe for now.
2016 F80 M3 6MT Azurite Black/Sakhir Orange Full Leather
2007 E90 335i 6MT Black Sapphire Metallic/Terra Brown Leather 2017 F32 440i xDrive 6MT Alpine White/Coral Red Leather (SOLD) 2006 E90 330i 6MT Arctic Metallic/Lemon White Leather (SOLD) |
04-11-2018, 07:51 AM | #238 | |
126
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
If you already have the MPPSK then I would most definitely sway you away from any piggy backs while running 91 octane... IME even with 93 octane here in NY some times my timing runs pretty low in the summer with a JB4 on Map 1. To the point I have to go to Map 6 and put in 2PSI (custom map) to maintain timing.
That is an option for you - a JB4 and then you can just define 2PSI if 3PSI (Map 1) is too much... the true benefit of the JB4 is knowing how your car is responding to the added boost.. however, each PSI is about 10HP - may not be worth the cost in the end - and you might find, its worse performance with any added boost because of timing being pulled so much.. Quote:
High Flier102.50 |
04-11-2018, 11:54 AM | #239 | ||
348
Rep 352
JB4 is something that I might consider in the future, after my warranty is up.
05-02-2018, 12:03 AM | #240 |
74
Rep 248
Ive had it for a year now and while it works fine in the winter the summer months bring check engine lights and stuttering when idling and accelorating.
I'm reaching out for a refund at this point because the car has been at the dealer so many times for this issue and its just ridiculous at this point. Regardless of the fact that NY may have "bad" 93 it shouldn't be so bad to the point that the product doesn't work as designed. |
monkiboy534.50 |
05-02-2018, 09:09 AM | #241 | |
126
Rep 484
I know others who have the same setup - they have no issues up to map 2.
I really think its the fuel quality in NY - almost believe these stations are not giving us 93 octane. The cars performance and driveability varies too much from station to station. PS - go to map 6 and define it to 2psi. Its major improvement in the summer months.. If you have the EWG wires you can fix the PSI to 15 or 16. The issue lays when timing drops - computer seems to recalculate and for that session becomes a mess... if you can keep timing consistent all issues go away. Need to log and find the right balance Quote:
05-02-2018, 09:28 AM | #242 |
191
Rep 521
Is the fuel in NY high in ethanol? From talking to friends who know far more about tuning than me, making up octane with ethanol has downsides, because the energy density of the fuel decreases. So if your 93 is '91 mixed w/ 15% ethanol' it will technically meet the definition of 93 (it will have the same detonation resistance as 'pure gas' 93), but it will behave differently than 93 w/ 0% ethanol.
