10-27-2020, 12:02 PM | #111 |
1069
Rep 1,069
This thread really ought to be stickied.
Does anybody know if there is an unstamped part for the bmw motorsport waterpump with the metal impeller? |
11-27-2020, 07:40 PM | #112 |
66
Rep 136
Drives: 2011 M3 E93
Amazing thread and information.
I'm sure everyone here appreciates the effort and time it took to compile and share this information. Cheers! |
Theodore673.50 |
11-27-2020, 10:11 PM | #113 |
3917
Rep 4,180
Assimilator1595.50 |
12-23-2020, 09:47 PM | #114 |
674
Rep 413
Updates and corrections for Original Equipment (OE) Equivalents (Thanks Davisca455):
BMW E9X M3 A/C Belt Tensioner Pulley Only = INA 5320557100 BMW E9X M3 Alternator Belt Tensioner Pulley Only = INA 5320342100 Built before 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = INA 5320418100 Built on or after 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = Only available from BMW 11287841531 |
Davisca4552207.50 |
01-13-2021, 11:36 AM | #115 |
596
Rep 1,042
Drives: BMW M3 e92 08 & 330d e90 10
Good thread, but I don't know why you haven't updated the MTF oil for the manual gearbox, I've provided the info 2-3 times already in this thread
Theodore
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. |
02-22-2021, 01:54 PM | #116 |
596
Rep 1,042
Has anyone found a replacement for the double studded rubber mount (aka bobbin) that holds the PAS pipe to the bracket? (which bolts to the subframe).
It's the part that nut, item no 15 screws to in the diagram below the PS pump in the op. I've ordered a bobbin from GSF that they think is close, it's for an original Mini! I'll find out what it's like tomorrow, hopefully! [edit] Nope, was way too big! I ended up using a mount intended for a VW Passat 2002 engine cover, turned out to be a perfect fit, and slightly thicker so stronger! You can get Febi ones (part no 23304). And apparently the VW part no is 059 103 658A (which appears to be Febi anyway). This shows the original BMW one vs the VW/Febi one (the original BMW one had sheared off through the rubber, I'd glued it with silicone, but it wouldn't have held for long). [edit] If anyone wants an exact match and not one slightly stronger (why? lol), then this one seems to be the job VW 037 133 567F, air pump rubber mount apparently. Also, has anyone ordered the INA tensioner pulleys lately? I bought 2 today from GSF, the INA 5320557100 AC tensioner pulley and the alternator tensioner pulley INA 5320342100. The alternator tensioner pulley was exactly the same size, although it did have a bolt with a large washer crimped to the bolt, it was easily screwed off. Much cheaper at about £20 , vs BMWs pulley and arm at ~£150!! The AC tensioner was however a slightly smaller diameter (~4mm), that said, the pulley I had on there wasn't genuine anyway (although it was INA) so maybe that was wrong in the 1st place? (interestingly it was exactly the same size as the alternator tensioner pulley). My car's build is 4/2008, which annoyingly is right at the change over point between 2 different PAS/AC tensioner pulley and belt config's. The belt on my car is a PK 1067. Anyone know which size pulley it should have?
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 01-23-2022 at 06:44 AM.. |
M3_Legend359.50 |
07-08-2021, 01:24 AM | #117 |
176
Rep 588
can anyone confirm if Bosch changed the part number for our injectors? I tried to find the 0280158164 but it is back ordered everywhere. But Bosch website said this
https://www.boschautoparts.com/en/au...n?partId=62418 |
07-10-2021, 07:29 AM | #118 |
596
Rep 1,042
Sorry I can't help, but how about contacting Bosch?
07-10-2021, 06:50 PM | #119 | |
2208
Rep 865
https://www.bimmerpost.com/forums/sh...php?p=26791901
Chris, 2008 E92 |
07-12-2021, 01:25 AM | #120 |
596
Rep 1,042
Yea I found that thread a little while after posting that message, and posted there .
But it's good information that you posted the link for others. Btw, IIRC (I need to double check) I think mine is the earlier version, but doesn't have the offset pulley! Lol, someone prior to me had changed the pulleys and I'd just copied their mistake, doesn't slip though!
Davisca4552207.50 |
08-14-2021, 01:01 PM | #122 |
596
Rep 1,042
Isn't that the engine from the previous M3?
01-10-2022, 03:51 PM | #123 |
26
Rep 40
Alternative Pre-Cat Sensors.
Bosch # 0 281 004 047. Alternative OE #'s (0055199542 , 00551995420 , 55199542 , 55260358 , 55275929 , K0055199542) Should be under 60€. Length is 330mm compare to the 340mm on the OE sensor Last edited by ZiMMie; 01-10-2022 at 04:06 PM.. |
01-21-2022, 12:57 AM | #124 |
204
Rep 795
+1 on the Rein unit, not sure about their quality but that's the only one with metal impeller I found so far other than the Motorsport one that cost $700+ now...
2011 BMW E92 M3
2018 Tesla Model 3 Long Range RWD |
03-14-2022, 07:29 PM | #125 | |
3956
Rep 3,996
Did some searching and believe I found the INA version of the later deflection pulley (after 4/29/08) BMW 11287841531: INA 11287535860, 5320512100, FP05121 FCP: https://www.fcpeuro.com/products/bmw...em-11287535860 I was able to cross reference this with the Duralast 231163 and Dayco 89163, which is a replacement for BMW 11287535860 pulley that others mentioned worked for them. I prefer sticking with the INA pulley and this fits the bill. Will confirm in a few weeks hopefully:
05-26-2022, 01:28 PM | #127 | |
42
Rep 69
Drives: BMW E93 M3 DCT
Had to wait a week for an OE getrag filter which went in perfectly and fixed my issue. Left a nasty one star review on FCP Euro which they later deleted... |
Theodore673.50 |
05-28-2022, 08:25 AM | #128 |
674
Rep 413
Updated to remove Vaico DCT filters and replace with Getrag. Thanks.
IamFODI365.50 Assimilator1595.50 |
09-20-2022, 12:43 AM | #129 | |
274
Rep 302
Theodore673.50 Assimilator1595.50 |
04-10-2024, 01:58 PM | #131 | |||
596
Rep 1,042
Was it because of the 2 different Castrol names? I see I didn't clarify that previously, the 2018 (& 2019) ZF TE-ML11 pdf lists both the Castrol Transmax as well as the Syntrans. Here's the text from that pdf (I've also attached the pdf to this post) :- Castrol BOT 338 => BMW Oil No. 2300 7533 513 (clutch bell housing label MTF-LT2) => VW Oil No. N 05279800 => Castrol Syntrans B 75W => Castrol Transmax Manual B 75W I've provided multiple links regarding what the oil is, including by the manufacturer of the gearbox (ZF). So at the least, Castrol Transmax Manual B 75W was the genuine OEM MTF LT2 oil. This is the relevant text from the "List of lubricants ZF TE-ML11" 2024 (see link in my quote below). S6-53 According to spare part number of vehicle manufacturer: - Esso Gear Oil 304 / BMW Oil No. 2300 1434 404 (clutch bell housing label MTF-LT1) no longer available => replaced by Castrol BOT 338 (ZF approval number ZF001053) - Castrol BOT 338 (ZF approval number ZF001053) => BMW Oil No. 2300 7533 513 (clutch bell housing label MTF-LT2) => VW Oil No. N 05279800 => Castrol Transmax Manual B 75W - Castrol BOT 207 (ZF approval number ZF001069) => BMW Oil No. 2300 7533 818 (clutch bell housing label MTF-LT3) Warning: use of incorrect lubricant can cause transmission failure Quote:
The Castrol Syntrans B 75w has been discontinued in the UK, and Boughton Lube's state (a Castrol agent) that it has been replaced by Transmax Manual FE 75W, but that is not BMW approved. Just trying to track down some Castrol Transmax Manual B 75W, which is proving easier said than done....... well it looks like that's been discontinued too , so there's no point adding the info to the op now (but their was 4+ yrs ago ). I wonder if the VW numbered BOT 338 oil is still available (and cheaper than BMWs).....
Oil analysis for finding wearing rod bearings?. Collation of oil analysis reports with some rod bearing photos for the M3's S65. My categorisation of pulled rod bearings in the rod bearing condition thread. My updated 'Blown engines' list. Last edited by Assimilator1; 04-10-2024 at 03:42 PM.. |
04-10-2024, 04:39 PM | #132 |
596
Rep 1,042
I actually came back to this thread intending to see/ask if anyone's managed to track down an OEM supplier of the horns.
I see the original ones are made by FIAMM, pic of my M3's horn one and two, and No2 again showing the BMW part no. Hmm, looking at the numbers on the top, the 2 horns are the same, I thought they were different tones for some reason.... [edit] yes they are 2 different tones according to realoem.
