05-22-2022, 04:34 PM | #1 |
278
Rep 632
What are the necessary tools to replace intake and charge pipe?
I am wondering what tools I will need to remove the stock air intake system and charge pipe for the G20 330i (B46TU) because I am going to be replacing them with aftermarket parts (MST Intake and FTP chargepipe).
Anyone who has done this, can you advise? Thanks |
05-22-2022, 06:37 PM | #2 | |
895
Rep 1,515
turnsignalslol278.00 |
05-24-2022, 03:25 AM | #3 | |
484
Rep 327
My 330i is FBO, for the most part besides catless downpipe, all the engine components I removed and installed myself. It's all doable, none of it is really all too difficult. Just need the time and patience. Goodluck! |
07-13-2022, 11:10 PM | #4 | |
278
Rep 632
Can you look at my new threads about some troubleshooting with these parts? I think you might be more knowledgeable about those things and it would be greatly appreciated. Have a good one! |
07-13-2022, 11:12 PM | #5 |
278
Rep 632
Hey man, I looked at that video and while it provided some support, I ended up mostly using another video to install the intake because there are differences in the installation process for the B48/B58 plus the intakes having structural differences due to the different engines. Thanks for the link though!
Chubbiejones894.50 |
07-14-2022, 05:16 AM | #6 | |
895
Rep 1,515
04-19-2024, 09:46 PM | #7 |
33
Rep 73
Drives: 328i, 330i
I performed this exact same install last night. MST CAI System and an FTP Chargepipe. I went back and forth on 2 YT videos for guidance and got it done in just over 5 hours. You'll need a Torx wrench set, Allen wrench set, various flathead screwdrivers (the smaller in length the better) to help get connectors off, a flashlight, probably some thin but tough gloves, some elbow grease, and patience. I took both off and then installed the chargepipe and then the intake.
Main grumble points were: - Removing the PCV connectors on both ends - Lining up the Chargepipe as it was being installed - Reinstalling the sensors to the Intake pipe (the two stacked on each other that sit closer to the turbo inlet) - needing a 2nd person at times and not having one |
