2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing M235i track advice. Oil starvation
      12-06-2020, 07:47 PM   #67
Rotorav8r
Drives: BMW M235i ‘16
Also, if anyone has same data on MMR baffling modification; that would be fantastic too
      06-02-2021, 07:11 AM   #68
Polo08816
1613
Drives: 2014 335i M Sport
Are you guys able to starve the oil using street tires with 200TW or above?
      06-08-2021, 02:55 PM   #69
Devils41
Devils41's Avatar
263
Drives: 2023 G80 M3 Competition Xdrive
I'm about to order the MMR baffle and get my car track ready for October. I've searched for that info as well but couldn't find anything. I'll try and do some logs in October when I get it on and report back any findings
      06-08-2021, 04:38 PM   #70
BaggedAholic
69
Drives: BMW M235i
I got the MMR on my car that I'm selling. Supposedly it's really good but I haven't taken the car to the track because I decided to sell the car.
      04-26-2022, 05:43 PM   #71
Polo08816
1613
Originally Posted by bbnks2 View Post
I have an Accusump plumbed to my oil return line side of the thermostat (top port of OTH). What about the plumbing could possible affect this? Oil gets pumped to the filter first, then it gets pushed through the thermostat, and then it returns to the housing to enter the main oil galley. The oil filter housing is pretty simple. SOME oil is ALWAYS flowing through the thermostat so even on a dead cold nuts start I can use the Accusump to prime the engine with pressure. The only argument that can be made is that the oil will back-flow through the oil filter but that is what anti-drainback valves prevent. A log of oil pressure shows the accusump building pressure (up to 40psi prior to cranking), which is measured right before it goes into the block, so the oil is NOT just dumping back to the pan.
Also, you can run an in-line check valve on the oil return line to prevent the potential back-flow of oil.
I wired a light and switch to the Accusumps electronic valve so I can see when it's dumping oil. This has shown that the oil pressure PID is not as responsive as you might think. BMW either does some kind of smoothing of the data, or, the logging resolution (sensor feedback or OBD limits) just isn't that great. I say this because a log of oil pressure will show 80psi while shifting but the Accusump will dump oil during a shift which indicate it actually dropping below 60psi. Not concerning, but, it shows the oil pressure monitoring may not have the greatest resolution to capture a split second oil pressure loss.
Accusump is a great device but I've still read people popping engines even when using them.
Would you have more information on the specific PID? I'm trying to get the PID to display in RaceChrono Pro with OBDLink MX+. It may have to be a custom PID.
      04-27-2022, 05:23 AM   #72
Polo08816
1613
So my N55 on my 2014 335i took a dump at VIR this past weekend.
They both are the N55B30A variant. I know the M235i N55 has the forged crankshaft. Can I use an M235i N55 instead of a 335i N55 as a replacement and how much more work would it be to get it working?
      04-29-2022, 04:10 AM   #73
Polo08816
1613
Also, can you re-use your oil level sensor?
      07-02-2022, 04:39 AM   #74
Polo08816
1613
Originally Posted by krisa9977 View Post
http://www.realoem.com/bmw/enUS/part...20Racing&mg=11
you will need following parts:
01 Suction pump 1 11417846385
02 Drive Shaft 1 11417848466
05 Cover lid FOR RETURN LINE 1 11418335879
01 Oil pump 1 11418011851
02 Suction pipe 1 11417846384
01 Oil Pan 1 11137854463
I bought used oil pan, suction pump and oil pump from M4. Also you need cover lid FOR RETURN LINE that you can order from the dealer. That part is used on M235R racing version. All those parts exactly the same as M235R cup, so you don't need to make modifications to retrofit them. Right now I have no problem with the engine so far.
Are you able to reuse your oil level sensor or did you have to use an oil level sensor for the M2/M3/M4?
      07-28-2022, 10:16 AM   #75
Jelly_Belly
44
Drives: F22 M235i
Funny enough i spun a rod bearing on my M235I N55 a couple weeks ago, so much for forged internals...
One of the shops i called when inquiring about sourcing an engine told me that the N55 from a 335i would be a swap option and "should drop right in" mind you only one shop told me that of the 4-5 i called in my area.
I know the Xdrive N55s have different oil pans than non Xdrive N55s. so be careful with that.
Do we know if the S55 oil pump is compatible with the N55 Xdrive oil pan? S55 oil pan apparently doesnt fit on my N55 due to said Xdrive
      05-29-2023, 08:30 PM   #76
rhop101
Drives: BMW M235i, Honda S2000 AP2
Hey any word on how this worked out? From the few sources I’ve found in a half hour search on this it helps maintain pressure after a hard braking situation, but not so much with the issue during high-g on-throttle long corners.
      01-27-2024, 12:06 PM   #77
seattlesuperleggera
Drives: BMW M235i
Sorry for reviving a dead thread. Looking for reviews of the MMR oil pan baffle. Has anyone tried these on track?
      01-27-2024, 01:19 PM   #78
jb-slow
111
Drives: m235i
Yes, 2 summers on track and my engine hasn't exploded.
      01-27-2024, 06:49 PM   #79
seattlesuperleggera
Drives: BMW M235i
I see you're local also. Have you driven at the ridge with it also? Suspension setup? I've already purchased mine. Who installed yours?
      01-30-2024, 08:33 AM   #80
jb-slow
111
Drives: m235i
I've just been running at pacific raceways, it's much closer to home. As far a suspension I have Bilstein b6 shocks, Dinan springs, camber plates, adjustable end links, subframe bushings, monoballs on the front, every kind of brace basically and probably some small stuff I've forgotten. Wider wheels and M2 brakes if you wanna count that too.
I put the baffle in myself, it's a big job but you could do it at the same time as some maintenance stuff like a water pump or something to help justify the effort, having the subframe off would make that a very easy job.
      03-13-2024, 11:07 AM   #81
fanatic10
Drives: 328i. 235i/240i soon?
Do you have any log data to compare before and after?
How many events over the two summers?
What weight oil are you running for these events?
      03-14-2024, 06:44 PM   #82
jb-slow
111
Drives: m235i
I don't log anything but lap times. Probably 5 or 6 whole day events each summer, running 5-40 oil.
2addicts
