03-07-2023, 03:31 PM | #1 |
225
Rep 65
From Frankenstein e30m3 to GTS
Been running a built s54 e30m3 for the last 15 years, primarily on tracks in the SE (Sebring, Homestead, Roebling, Road Atlanta). Anything and everything was done: 367whp, dry sump, MCS, PFC, 2400lbs wet, cranking 2:18s at Sebring so turned out to be a quick little old car. But after my trailer and gear was stolen and my old man was retiring and selling his shop (my free labor track support, lol), I decided it was time to sell and move to a newer platform.
Took my lizard GT3RS to Sebring a couple times hoping it would be my next track weapon, and while it’s extremely quick out of the box, I just can’t get myself to drive it 10/10th and really push it. Fear of screwing it up always in back of my head. So after tons and tons of research on various platform options for a dedicated track car, I’m back in a BMW. Picked up an 8k mile M4 GTS last week and already started with part orders. Have done a lot of reading in this section to learn from your experiences, hoping to apply a lot of that to make this a quick and enjoyable beast on track! So excited, car feels so planted, connected, responsive even from the few spirited runs around town. Plans for Phase 1
Will post updates of the build… |
12
RugbyBro7601.50 jfritz271107.00 bvrider1345.00 GERMAN M34181.00 D_SheerDrivingPleasure1092.50 swagon13522.50 TractionControlDelete4593.00 cotmfk2049.50 clutchdj1878.50 W///7494.00 JustAnothaM4883.50 M3 boi3211.00 |
03-07-2023, 04:06 PM | #2 |
7602
Rep 3,604
Nice! Check out the track section too, lots of resources on there. SYT_Shadow runs 2 GTS and there’s a few other guys who exclusively run GTSs as track cars. Also Bimmerworld’s GTMore car has a lot of dedicated track development and parts.
Current: F80
Prior: F82, F32 |
SYT_Shadow11490.00 |
03-07-2023, 04:27 PM | #3 | |
///M Powered for Life
11490
Rep 10,329
I ran into multiple issues with water in the GTSs, finally we change the stone every track weekend and now it works perfectly. Of course we only use distilled water. Note that one car has the upgraded/updated water block but the other still has the factory original The Girodiscs are much, much better than the M2C rotors. Been there done that, although not on my GTS. Unrelated to the reco, I have my Giros for sale (along with pads optional) as both GTSs have moved to the nickel plated Alcons. These can be found right here: https://f80.bimmerpost.com/forums/sh....php?t=1988307 For pads, you are better off with the Girodisc GP40/20 combo. It's the best feeling pad we found on the CCB calipers. The stock suspension is very capable. You probably will want to increase front and rear spring rates by ~100, but leaving them as is works great. The manual recommended track settings work extremely well for tracks like WGI and VIR, and also for smaller tracks One more thing: you probably want to get the front thrust monoballs. They don't have a negative effect on nvh and slightly improve braking and steering. We've used the Bimmerworld ones since 2016 and they're great. https://www.bimmerworld.com/Suspensi...Bearing_2.html I hope this is helpful, cheers
FrankMstein1019.50 |
03-07-2023, 05:28 PM | #4 |
1107
Rep 1,301
Welcome! -- over your stable
Listen to SYT_Shadow! My only input would be to avoid the DS1.11 pad. At brake-heavy tracks you'll burn through a set of those in 1-2 days, they wear like butter (at least with stock-level "cooling", or lack thereof). For standard F8x blue calipers many of us are fans of PFC11 |
SYT_Shadow11490.00 ClubsportJunkie311.50 |
03-07-2023, 07:29 PM | #5 | |
11490
Rep 10,329
03-07-2023, 07:53 PM | #6 |
225
Rep 65
SYT_Shadow, thank you for all the helpful info. Will definitely look into the Girodisc setup for rotors and pads. Good call on the front thrust monoballs. Will order them as well.
jfritz27, I exclusively ran PFC pads with our PFC bbk on e30 for many years and would love to stick with them but doesn’t appear to be available for our calipers. Had good success with Ferodo DS3.12 on GT3 but also not available for GTS. Any other brake pad options? I only see Carbotech and Pagid on bimmerworld site for our ccb caliper application. Have zero experience with either… Thanks guys! |
03-07-2023, 08:26 PM | #9 | |
7602
Rep 3,604
https://cobaltbrakes.com/shop/oe/bmw/f87-m2-competition
Current: F80
Prior: F82, F32 |
03-08-2023, 09:49 PM | #11 |
225
Rep 65
I jumped on their Group Buy for the Forged VS-5RS wheel. I went back and forth between squared or staggered but decided on the 10.5/11” staggered setup. I wasn’t happy with the square option of 19x10 since I wanted to run 295s and that is too stretched on 10” wheel for my liking. The 19x10.5 et25 offset seems to be too much for rear, so was limited there.
03-08-2023, 11:43 PM | #12 | |
909
Rep 696
03-09-2023, 06:49 AM | #13 |
225
Rep 65
I’ve had BBS wheels on my Porsches for years and also ran Apex on our track cars for a long time. Apex, especially the forged line, are great wheels at a very good price point. Easily accessible, pretty good size/offset options, great overall wheel. Good luck with the new car…
clutchdj1878.50 |
03-09-2023, 01:33 PM | #14 |
11490
Rep 10,329
You can easily fit Apex 19" 10.5 square ET45 onto a GTS. Or a Bimmerworld TA5R 10.5 square ET36 that requires smaller spacers.
Although I've had a nice set of BBS FI as street wheels, I would never use them for the track. Abrasive brake pad materials, melting wheel weight glue, etc etc all conspire to destroy your wheels. Better to destroy a set of cheap wheels than nice expensive ones! |
The_Werm212.00 |
03-09-2023, 11:27 PM | #15 | |
225
Rep 65
I checked the knuckles by the way. No cracks, so will machine down the notch as you guys did. |
03-10-2023, 07:14 AM | #16 | |
11490
Rep 10,329
03-10-2023, 11:31 AM | #17 |
1020
Rep 910
03-11-2023, 05:10 PM | #18 |
1093
Rep 920
Willkommen. Curious about your issue with the GT3RS. Was your inability to drive 10/10s because of the financial consequences of wrecking it or the car's handling at the limit?
03-11-2023, 10:28 PM | #19 |
225
Rep 65
GT3RS was spectacular!!! Handles better than anything I’ve ever experienced out of the box. My hesitation was always because of its rarity and value…to screw that up would suck. And shit happens on track, not always your fault.
D_SheerDrivingPleasure1092.50 |
04-15-2023, 07:05 PM | #20 |
225
Rep 65
Great progress today, spent all day at the shop, prepping for the first track outing at Sebring. Machined down the knuckles (thanks for the info SYT_Shadow), installed Gyrodiscs, pads, did fluids and got the wheels/tires fitted. 19x10.5 et25 with 275 Nankang fits like a glove with no spacers needed. Went with 19x11 and 305s in the rear.
Thanks for the advice everyone. Will report back on how the car feels out there…
SYT_Shadow11490.00 Gomeler500.00 ClubsportJunkie311.50 JustAnothaM4883.50 schnell325889.50 The_Werm212.00 |
04-16-2023, 03:21 PM | #21 | |
1364
Rep 1,335
mikerunt306.00 |
04-16-2023, 07:19 PM | #22 |
225
Rep 65
Just the cracked knuckle post and pics of which part to trim. Your photos were guidance for us as well. Thank you, we did just as you guys did.
