Coby Wheel
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      01-30-2024, 03:59 PM   #1
markw10702
119
Drives: GTMore Anyone?
Swapping Out KW Springs for Swift Springs
GTS suspension question - looking to upgrade to Swift springs and noticed that the Swifts are 60mm ID while the KWs are 61mm. For those of you who have performed this swap, what spring perches and isolators did you use?
Thanks.
      02-02-2024, 03:28 PM   #2
daveishi
daveishi's Avatar
243
Drives: M4 GTS, G05 X5
Just the stock perches. The Swift's are flat top and bottom though so you should remove the plastic/rubber adapter. FYI the stock springs that come on the KW's are actually Eibach.
      02-02-2024, 03:34 PM   #3
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11490
Drives: E90M/E92M/M4GTS/M4GT4/X5M
I'd love to see some part numbers for replacement springs on the GTS
I'm sure the stock valving can go up 150lbs front and rear, but what are the lengths and part numbers?
      02-02-2024, 03:53 PM   #4
markw10702
119
I am also interested in the spring specifications (above).
SYT_Shadow11490.00
      02-02-2024, 03:54 PM   #5
markw10702
119
So if Eibach - that would presume they are 60mm vs my assumed KW 61mm or are the Eibachs a 2.25" spring?
Thanks.
      02-02-2024, 04:28 PM   #6
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
You can ask kw directly, I bought a set of springs a few days ago.
SYT_Shadow11490.00
      02-02-2024, 04:55 PM   #7
daveishi
daveishi's Avatar
243
Here are the part numbers for the Swift's I went with, 8" rear and 7" front however if I were to do it again I'd do a 6" front because with the Swift assist springs I put in the front is as low as it will go and I could use a bit more adjustment. As far as rates I did 16k rear and 11k front which puts them right about 200 lbs over stock which is what KW says will work with stock valving:
Z60-178-110
Z60-203-160
Appreciate 3
SYT_Shadow11490.00
Samo6556130.50
      02-02-2024, 04:58 PM   #8
daveishi
daveishi's Avatar
243
Pic for comparison (front springs)
Appreciate 4
SYT_Shadow11490.00
JimmyS70.00
      02-02-2024, 10:22 PM   #9
SYT_Shadow
SYT_Shadow's Avatar
11490
Super useful, much appreciated
      02-02-2024, 10:24 PM   #10
SYT_Shadow
SYT_Shadow's Avatar
11490
In the US, KW is not well supported. I called a couple dealers asking for the springs, they treated it like a request for enriched uranium.
+200lbs gets us into better territory. The kw 3w is a good suspension, but the spring rates in the GTS are ridiculously low
      02-02-2024, 10:35 PM   #11
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Why didn’t you increase the F and R springs the same % from gts stock rates? Your front rate is 69% of your rear rate whereas stock gts it is 58%. Are you concerned about adding understeer?
      02-02-2024, 11:47 PM   #12
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Z60-178-110
Z60-203-160
According to conversation with kw, the rear springs are 16kg
I speak directly with kw department, the dealers have no idea about spring rates
SYT_Shadow11490.00
      02-03-2024, 12:03 AM   #13
M3SQRD
M3SQRD's Avatar
2164
I thought the OEM GTS spring rates were 400/685 lbf/in and the CS 3-way kit from KW has 500/800 lbf/in?
      02-03-2024, 03:14 PM   #14
SYT_Shadow
SYT_Shadow's Avatar
11490
From what I remember:
GTS comes with 400lb/in front and 685lb/in rear springs.
Stock KW CS 3W are 575lb/in front and 800lb/in rear.
When I reached out to a kw dealer, they reached out to kw and got this: "According to KW, you would need 457 lbs/in front springs and 914 lbs/in rear springs"
      02-03-2024, 03:38 PM   #15
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
When I rea he'd out to a kw dealer, they reached out to kw and got this: "According to KW, you would need 457 lbs/in front springs and 914 lbs/in rear springs"
I would like to know where you got that information from, kw has given me other info
      02-03-2024, 03:46 PM   #16
SYT_Shadow
SYT_Shadow's Avatar
11490
From one of their dealers. Who knows if it's right! But the regular cs 3w should be real information
      02-03-2024, 04:05 PM   #17
Track/S
Track/S's Avatar
1364
Drives: M2C, M4 GTS
Yes kw cs v3 I know it is correct because a friend has them and he increased the springs rates by 20nm.
      02-03-2024, 04:15 PM   #18
M3SQRD
M3SQRD's Avatar
2164
iND got the M4 GTS spring rates when KW originally released their CS 3-Way. Supposedly the GTS spring rates came directly from KW.
      02-05-2024, 01:08 PM   #19
daveishi
daveishi's Avatar
243
That's the main reason, I have been trying to dial out the understeer since I got it (mostly with alignment and square tires) especially since I started out tracking in the very oversteer-y S2000. These rates have worked well for me, but always open to hearing other's experience and feedback.
      02-05-2024, 01:46 PM   #20
M3SQRD
M3SQRD's Avatar
2164
I’ve owned three s2000s and I loved the stock balance. I had upgraded the suspension with a Tein Super Racing setup on one of them. It was such a blast to drive!
If you’re trying to dial out understeer you’d want to raise the rear rate more than the front rate. You increased the front rate by 11% relative to the rear. I’d expect something closer to 50% F-R ratio vs. the GTS stock 59%. However, with stock ASBs, the higher front rate could be providing better front role control and better maintaining of the front camber curve, therefore reducing understeer? With my MCS 2WR I’m currently running F/R 700/1100 lbf/in rates and the balance is great with 63% F-R ratio which supports the increase in front rate relative to rear, does dial out understeer. Have you had a chance to really test the new spring rates?
      02-06-2024, 12:45 PM   #21
Samo6556
131
Drives: 09 BMW M3
Any feedback changing to these springs? Compared to prior rates.
      02-11-2024, 05:17 PM   #22
Samo6556
131
Drives: 09 BMW M3
Z60-178-110
Z60-203-160
I gambled and bought these exact rates. And did a 6inch front with the swift assist. Thanks for posting the information.
JimmyS70.00
f80post
