Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > (G11) 7-series General Discussions
      03-17-2024, 10:10 AM   #1
77777
Drives: Bmw 750li
Windshield water not pumping
Hello windshield water is not pumping anymore on my 750 g12 2016. But the front headlight cleaner works perfectly. What could be the issue?
      03-17-2024, 11:52 AM   #2
Raimo5
183
Drives: BMW 740d xDrive (G11)
Most likely culprit would be windshield washer pump. Headlights and windshield are supplied by separate pumps.
      03-17-2024, 12:12 PM   #3
M_Bimmer
M_Bimmer's Avatar
583
Drives: G12 B7, G07 XB7, F02 B7, 991.1
....and a pain to replace.
TIS procedure attached, if you are inclined to replace the pump yourself.
Might be worth checking to see if your pump is running when activated by the steering wheel stalk and if so, and still no fluid, to verify that all the hoses are all connected, or do not have a leak prior to the windshield nozzle, prior to starting the pump replacement procedure.
File Type: pdf BMW_G12_Washer_Pump_Remove_Replace_Procedure.pdf (3.83 MB, 23 views)
      03-18-2024, 11:44 AM   #4
Qsilver7
Qsilver7's Avatar
4446
Drives: F06 650ix GC / F15 X5 50i
Can you hear the pump when initiated but no fluid is sprayed from the jets? Or do you hear dead silence when initiated?
If you can hear the pump...perhaps the jets are clogged (calcified). Take a straight pin and gentle try to clean any crud from the nozzles.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      03-19-2024, 03:39 AM   #5
77777
Drives: Bmw 750li
Nope its dead silence. Looks like a real pain in the ass replacing it
      03-19-2024, 02:08 PM   #6
Markr
Markr's Avatar
483
Drives: BMW 740d Xdrive M Sport
Maybe check the fuse first - just in case.
Current: 2018 BMW G11 740d MSport XDrive
Past: 2015 Audi 3.0tdi A8L, 2012 Audi 3.0tdi A8L, 2009 Audi 3.0tdi A8, 2005 Jaguar 4.2V8 XJL, 2000 Jaguar 4.0V8 XJL + many others
      03-19-2024, 09:48 PM   #7
M_Bimmer
M_Bimmer's Avatar
583
Per the TIS:
The windscreen washer pump is connected to the Body Domain Controller (BDC) via a two-pin plug connection.
The BDC activates the windscreen washer pump.
The Body Domain Controller monitors the power consumption of the windscreen washer pump (locking protection).
BDC is powered by three fuses:
1. F504 on Z3 (Panel on top of the Battery), 60A, Hangs off the Terminal 30 voltage rail
2. F40 on Z44 (Front right panel distribution), 60A, Hangs of f the Terminal 30 voltage rail
3. F28 on Z44 (Front right panel distribution), 20A, Hangs off the Terminal 30 voltage rail
      03-21-2024, 04:52 AM   #8
77777
Drives: Bmw 750li
Thanks guys it was the pump. Replaced it but didnt have to remove to side panel so the trim wasnt damaged like it shows in the pdf file
      03-21-2024, 10:59 AM   #9
M_Bimmer
M_Bimmer's Avatar
583
77777, do you mind letting us know the short cut? I'm sure the rest of us will be changing this out soon....
Assuming you removed the front right wheel, and the corresponding front wheel well rear liner, were you able to slide out the washer fluid tank without removing anything else?
Thanks!
      03-25-2024, 07:26 AM   #10
77777
Drives: Bmw 750li
Thanks!
Yes removed the wheel and the liner after that I removed the plastic trim around the engine bay, removed the cover (where you pour the washer water) and then using a flashlight and a slim tool I managed to reach in where neck is located (the top is connected to the bottom tank) that connection is right where the fender is. Basically you need a long, slim tool that you'll use to get in and disconnect the top part from the bottom and then the entire tank comes out from the bottom. If its not clear ask questions ill explain
      03-25-2024, 12:47 PM   #11
g11hoonigan
820
Drives: BMW 740i
Clear as mud!
7post
