05-01-2024, 10:00 AM | #1 |
Rep 23
How cooked am I?
So I just got this f83 and it has a damaged oil cooler and the the metal rails that the oil cooler is mounted to is bent ig. However, besides that I didn’t notice any other damage to the car. The thing is that the car seems to have leaked out a lot of oil off of this damaged oil cooler and still is atm as it sits in my driveway. I just scanned it for some codes and this is what I got, from the codes would you say the engine is damaged due to low oil pressure or are these codes that came as soon as the pressure got to a certain point even if nothing was damaged? Would appreciate any opinion or help, thank you 🙏
05-01-2024, 06:06 PM | #2 |
344
Rep 558
Drives: F82 M4 BSM
Damaged oil cooler is what blows a lot of these cars. Did you turn the car on (if you haven't, don't)?
Codes don't look good. Looks like it was left running atleast for a little bit with very little oil (hence low oil pressure). If it's your car, insurance does cover hitting road debris and the following damage done because of it.
17' F82 BSM - Current Built Motor/PS2+
16' F82 Silverstone - Totaled FBO |
05-01-2024, 06:06 PM | #3 |
Rep 23
I cleared the codes and they haven’t came back except for the low fuel pressure code. The car still shows that the battery is low and it is discharged. Idk, ig I need a special lithium-ion battery charger? I also do have videos on how it sounds when I try to start it but I’m not sure if it allows me to post it or not
05-01-2024, 06:28 PM | #4 | |
476
Rep 628
05-01-2024, 06:30 PM | #5 |
Rep 23
It doesn’t run and never did to start with. When I try starting it, it tries cranking but Ig it can’t? And no I did repair it, it had a damaged oil cooler which I had replaced before trying to start it or anything else.
05-01-2024, 06:32 PM | #6 | |
Rep 23
05-01-2024, 06:49 PM | #7 | |
344
Rep 558
Drives: F82 M4 BSM
When I blew my motor, the motor seized and the car wouldn't turn over at all. Gauge cluster and everything illuminated as normal and when I went to start it, it just made an audible clicking noise and didn't turn over. You can try to manually rotate the crank bolt (22mm), and see if it's seized. You can upload videos to YouTube and post the links here. Below is how my old motor current sits, to be turned into a table soon 😎
05-01-2024, 07:11 PM | #8 | |
Rep 23
05-02-2024, 06:29 AM | #9 | |
476
Rep 628
White3401396.00 |
05-02-2024, 08:22 AM | #10 |
2914
Rep 2,788
Drives: 2020 M4 ZCP / 2023 X3 M40i
05-02-2024, 08:34 AM | #11 |
Rep 23
05-02-2024, 08:40 AM | #13 |
1953
Rep 879
You bought a damaged car and don't know how to fix it? This is probably mechanic's special and you are gonna dump a ton of money to get it running, and it probably has a branded title.
Good luck lol.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
05-02-2024, 08:41 AM | #14 |
Rep 23
05-02-2024, 09:25 AM | #15 |
76
Rep 152
Drives: BMW M4 and BMW M3 E46
100% of cars with problems end up at the auction. Not all cars at the auction have problems.
sae.ekiicii4.50 |
