01-20-2020, 09:43 AM | #1 |
2805
Rep 4,454
New shocks/springs recommendation with EDC
Does anyone have a recommendation of what to replace the stock springs/shocks/struts with? For those who have already done this, who did it themself?
01-20-2020, 10:05 AM | #2 | |
1623
Rep 2,036
01-20-2020, 10:29 PM | #3 |
101
Rep 691
01-21-2020, 07:08 AM | #4 | |
General of the Space Forces
171
Rep 722
Current: 2020 X5 x40i M-Sport, Arctic Grey Metallic / Ivory White, Executive Package, Luggage Compartment Package, Integral Active Steering, Tow Package, Parking Assist Package, Driving Assist Package, M-Sport brakes, Tux Mats
01-21-2020, 09:35 AM | #5 |
2805
Rep 4,454
Sorry guys, I should have said I have EDC (Electronic Damping Control) Sport and Sport + adaptive settings which need the shocks with the appropriate fluid and electronic connector.
01-21-2020, 01:15 PM | #6 |
174
Rep 540
Drives: 2016 BMW X3 35i M-Sport
To my knowledge, there is no kit for X3 that will keep EDC. I ditched my EDC when I went to coil overs and I don't miss it.
2016 X3 35i |M-Sport|Megan Racing Coilovers|FBO+|BM3|Jordan Tuned|Valvetronic Designs|
1998 750iL V12|2017 440i|2019 991.2 GT3RS Weissach|2019 Model X|...and some others Instagram @TheCoolX3 |
01-21-2020, 04:17 PM | #7 |
889
Rep 2,556
Drives: Z4MC-X3-35i-525i, Corrado G60
What's wrong with you stock EDC set?
AFAIK, there aren't any aftermarket EDC struts/shocks for the F25. The stock replacement struts/shocks are $$$ |
01-21-2020, 04:40 PM | #8 |
2805
Rep 4,454
One of the springs broke and its just as much work replacing the spring as it is the strut and the car has 80K on it. No shocks are leaking and seem to work well, I was just wondering what others had replaced theirs with in case I decided to do it.
01-21-2020, 08:10 PM | #9 |
Father of Frankenfold
300
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
Either OEM or the KW DDC Plug & Play kit, which keeps EDC functional on their coilovers.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
01-21-2020, 10:15 PM | #10 |
889
Rep 2,556
01-22-2020, 10:59 AM | #11 |
2805
Rep 4,454
Well, there is the KW DDC Plug & Play kit, which does keep OEM EDC function and uses the OEM switch on your center console but it comes in at a price of $3,139.99. This is more expensive than just replacing with the OEM parts. The KW parts look a lot nicer though.
01-22-2020, 04:39 PM | #12 | |
889
Rep 2,556
Not sure where you'd find EDC OEM springs, struts, shocks and bump stops for less than the KW kit? Plus, the KW kit should be a performance upgrade over OEM parts. If that cost too much for you, do a EDC delete and go with normal stuts/shocks for much less. |
06-22-2020, 07:51 PM | #13 | |
Rep 18
pungo you mentioned the EDC delete, is that a difficult process? |
06-22-2020, 09:01 PM | #14 |
889
Rep 2,556
06-23-2020, 10:15 AM | #15 |
Rep 18
There is no noticeable difference when I choose sport mode. car doesn't corner well and pogo-y on high-speed bumps.
Do you know where I can get a canceler? assuming it's some kind of resistor. I'm not familiar with coding except Carly, which doesn't have that option. Is there another app? thanks |
06-23-2020, 11:34 AM | #16 | |
889
Rep 2,556
I doubt the cancelers are just a resistor since they cost $340. KW makes them. To code them out, use e-sys on a laptop and a $15 cable. coding software and instructions |
evilchargerfan271.50 |
06-23-2020, 08:16 PM | #17 |
Rep 18
Brilliant! thanks.
So, buy the kit or a windows laptop and follow all the steps (mac person). Sounds like the kit will be easier/faster 4me. The dhp is probably not working right. or I'm a non-subtle driver. My e83 MSport was so much better suspension-wise, I just want to get close to that. And yea, I've heard that model was "too stiff", so I know that what I have now is much more soccer-mom oriented, the target customer. Lowering is not an option, I live in CO and actually drive off road. I'll take my chances with the Konis and see. |
06-23-2020, 09:48 PM | #18 | |
889
Rep 2,556
BTW, You can install e-sys on a mac in a VM, but, you're right, the cancelers are the simpler, yet more expensive way out. |
06-24-2020, 09:21 AM | #19 |
272
Rep 595
Drives: 2012 F25 (N55), 2014 I01 (REX)
I started to read up on how to code, and it seems intimidating:
https://www.bimmerfest.com/forums/sh...d.php?t=983245 |
06-29-2020, 01:28 AM | #20 |
176
Rep 588
Bilstein B12 is my choice when the time comes. I have their B12pro on my M3 and it is amazing. B16 is supposedly PnP for our X3s and fairly close to OE
11-07-2020, 12:48 PM | #21 |
Rep 18
Update: got the Koni reds installed plus the cancellers. Ride is a lot better than any previous "sport" mode from my stock dampers. Corners a lot better and doesn't do the wave at higher speeds hitting bumps like it did.
Definitely notice smaller bumps more but I got used to it. Larger bumps are the same. Was it worth it? Well, now that I am a month or so away from all the cursing during install and credit card shock, I would say yes. |
04-23-2024, 09:19 AM | #22 |
Rep 24
