F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 Log Review Thread
ARMA SPEED
      09-27-2021, 08:34 AM   #2003
vektorprime
43
Drives: 440xi
Originally Posted by zbraptorsdr View Post
Hey there, long time lurker. Would someone more experienced check my logs? I have done plenty of looking at other poster's logs and coming to my own conclusions, but I think its time for a 2nd set of eyes.
This Log is from a several months back while on the stage 1 OTS
https://www.bootmod3.net/log?id=6045...729b5994d9f21a
This log is from the OEM MPPSK tune included with my bootmod3 license taken today. Its quite warm, but the corrections seem less extreme
https://www.bootmod3.net/log?id=6119...90c6768b3aff0f
Looking at the timing corrections has me a little concerned. I rolled back to the OEM MPPSK since I was a little annoyed with the stage 1 tunes surging on part throttle in day to day use. I just changed back to the OTS Stage 1 to see if a different surging goes away from the stock tune (seems to be somewhat normal behavior on b58 engines according to some others saying similar things in this forum https://f30.bimmerpost.com/forums/sh....php?t=1541584) Ive tried finding better fuel here is CA but 91 from shell seems to be the best I can fine that is close to me. Next time I find myself near 100 octane I plan to add a little and trying the log again.
Do either of these maps look safe to run for the long haul?
Thanks for looking!
You sure that second log is OEM? I see you hit 19.3 PSI on the stock turbo.
      09-27-2021, 04:22 PM   #2004
wacoles
Drives: BMW 340i xDrive
Data Log MHD Stage 2 E30
Could someone look at this data log I did Saturday night? Seemed to me that there was a bit of a drop in rail pressure near the top end, but I don't know if its enough to be concerning. Also slight timing corrections, but once again not sure if they are very substantial. I don't know too much of what I'm looking at but want to make sure everything is fine since I'm about to put in a TU pump. Thanks
https://datazap.me/u/wacoles/92521-s...og=0&data=4-24
2016 xDrive 340
Mods:
MHD Stage 2
VRSF Catless Downpipe
XHP Stage 3
5th Gear pull on E30
      09-27-2021, 07:41 PM   #2005
vektorprime
43
Drives: 440xi
Originally Posted by kern417 View Post
no
Interesting. Why doesn't the high timing cause issues here since it's high load? What reading or learning should I look into to realize the differences here?
After some reading, I believe the answer to this is due to the lower pressure in the cylinder we need more timing.
      09-28-2021, 07:30 AM   #2006
kern417
Cheapskate
4464
Drives: 2018 440i |2016 340i | 2010 X5
How much timing you can run is a dependent on of a lot of things including octane, combustion temperature, boost levels, etc. Usually it's a sensitivie balance, because boost that's too high will create extra heat and reduce how much timing you can add (unless you have more octane to compensate for it). Ultimately the stock tune's boost levels are so low that high timing can be achieved.
Originally Posted by umizoomi View Post
As long as 3-pedals are an option, I will exercise my right to suffer the handicap and indignity of slower shifts and reaction times.
Youtube/Instagram/TikTok: @kern417
eluded3071.50
      09-28-2021, 10:07 AM   #2007
T_H_O_M_A_S
192
Drives: M140i
a smaller turbo wil put more heat into the air for the same amount of air at a certain pressure , compared to a bigger one . thats why increasing the boost beyond a point where iats skyrocket is useless . You need to upgrade your turbo .
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      10-02-2021, 11:58 AM   #2008
lixiang7349
lixiang7349's Avatar
284
Drives: customE50Tune
Hi Kevin and all,
I'm seeing corrections on cy2 as high as -5. Is this due to the lower LTFT (.94)?
Sometimes, shortly after powering up, I would feel the car slightly shake (like it's trying to clear its throat) and trying to cut power on ~75% throttle. And when I get on the highway to do WOT, it disappears again.
https://www.bootmod3.net/log?id=6158...90c67cf114c3d6
      10-05-2021, 03:56 PM   #2009
kevmk81
Drives: 2016 340i, 2016 Odyssey SE
I'm wanting some feedback on these two logs. I'm still not following how to make sense of these too well. I see a lot of corrections as I have been since I've been logging (can't seem to find a correction free gas here in central IL - even adding 1 to 1 1/2 gallons of e85 to top off a full tank). I'm wanting a tune that I can trust and I'm not sure which one of these I can stick with long term.
MHD stage 1 91 octane map
https://datazap.me/u/kevmk81/log-163...a=27&zoom=0-56
MHD stage 2 91 octane map
https://datazap.me/u/kevmk81/log-163...4&zoom=199-250
One thing that happened on the stage 2 map that makes me a little nervous - after the run - I smelled what seemed to be a burning electronics stench. No codes according to MHD. When I arrived home - I popped the hood and figured out that it's the sensor that is plugged into the charge pipe - the smell was pretty strong. I believe it's the charge-air pressure sensor. Again - no codes thrown or anything. I guess I should probably replace that sensor? I'm not very keen on how those wear. That smell has always told me of electrical equipment burn.
ETA: the sensor could have been the IAT sensor. hmmm. or maybe the boost pressure sensor? i'll take a pic and upload
ETA x 2: it's definitely the MAP sensor that smells like burnt electronics
ETA x 3: ok removed the MAP sensor - that doesn't stink like burnt electronics. I do believe the smell is coming from the valvetronic actuator :-|. What are the signs of those going bad? I see those aren't cheap.
      10-06-2021, 12:50 PM   #2010
vektorprime
43
Drives: 440xi
I'd look for an ebay part or getbmwparts after you've confirmed it's a problem. Could be plastic burn/melting?
      10-06-2021, 02:37 PM   #2011
kevmk81
I drove the car today and it seems to be ok. No odd noises, no CEL's. The smell is starting to go away. I wonder if there is a way to test the eccentric shaft as well as the valvetronic motor to determine if they are working properly or about to fail. Driving around it seems to be working properly but I'd like to know if the part(s) are going bad.
      10-06-2021, 02:39 PM   #2012
kevmk81
Following up on my ask. One thing I'm noticing in the logs is that when the torque at the clutch hits 400 ft lbs it sort of flattens out a bit. I wonder if I'm hitting a torque limit for 4th gear? Been reading that I believe the limit is roughly 400 ft lbs. I do have XHP installed but only stage 1 - which I don't believe removes the torque limit for 4th gear?
      10-09-2021, 09:55 PM   #2013
talontdone
talontdone's Avatar
175
Drives: 2017 BMW 340Xi
Log Review
Was hoping for a little more power on the dyno with the VTT GC ... made 508 WHP / ~ 550 TQ on Pump 93 with WMI on a Cary Jordan custom tune. We ran about 25 PSI but only got up to 11.5 degrees of timing - thoughts on the log and dyno chart????
Log attached:
https://datazap.me/u/talontd911/log-...36&tmax=133.20
17 BMW 340iX / DAW UF/ DS2 HPFP
      10-11-2021, 03:13 AM   #2014
Kay177
Drives: M240i
Hi guys
I have a m240i and recently installed meth
I have a decat
.022 Gapped plugs
Tu pump
Im using 99 ron uk vpower + meth . Running MHD stage 2 HPFP 102RON
After speaking to MHD they said i can run the 102 ron map with meth. I gave it a go and the logs are below. Im not the best with logs. How do they look to you guys?
Also do you think id have further gains if i got a custom meth+pump map?
4th gear meth:
https://datazap.me/u/khalid1770/102-...og=0&data=3-20
5th gear meth
https://datazap.me/u/khalid1770/102-...g=0&data=3-20/
      10-13-2021, 09:36 PM   #2015
talontdone
talontdone's Avatar
175
Log attached:
Anyone have any thoughts???
      10-14-2021, 06:26 AM   #2016
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
well , looks perfect i think
Bmw M240i Xdrive , Dorch Stage 1 , pure turbo 800 , Midpipe , Remus exhaust. Bootmod3 , 100+ E5
      10-14-2021, 10:19 AM   #2017
frankjr20
Drives: 2013 bmw 328i sedan
Red face bootmod3 license
hey i got a bootmod3 license for sale thinking about going a different route asking 550$
      10-15-2021, 03:47 AM   #2018
alpinweiss340
alpinweiss340's Avatar
88
Drives: 340i
Ouch. A bit steep. I tried selling my full map pack for $350 and no biters. Plus wrong thread to post for sale.
      10-15-2021, 06:56 PM   #2019
talontdone
talontdone's Avatar
175
Thanks!!
      11-07-2021, 09:16 AM   #2020
harkes
harkes's Avatar
China
1092
Drives: M135i, E39 M5, NSX and AE86
Hi
What is that 1048576 torque limiter. I get a bunch in this log. Is it because of these torque limit settings? I feel the car is being hold back...
0-100 in 4.1sec RWD M135i
https://datazap.me/u/harkes/0-100-la...15-30-34-35-36
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      11-17-2021, 03:41 AM   #2021
Glemm1970
Glemm1970's Avatar
Russia
316
Drives: BMW M140IX.
Originally Posted by harkes View Post
hi
what is that 1048576 torque limiter. I get a bunch in this log. Is it because of these torque limit settings? I feel the car is being hold back...
0-100 in 4.1sec rwd m135i
1-600
2-700
3-800
4-1100
5-1100
6-550
7-600
8-600
M140IX. Turbo Pure 800 Cast.
      11-20-2021, 04:19 AM   #2022
Jnat
DisplacementReplacement
Jnat's Avatar
440
Drives: 2020 X3M
Any feedback on the newer MHD Stg 2+ 93oct map?
Thoughts on performance differences between MHD Stg 2+ 95oct / E40 maps?
2020 X3M /// MHD Tune
Prior Bimmers
2017 240XI Hybrid / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
      12-11-2021, 01:41 PM   #2023
Devious340i
Drives: 2017 340i
Just installed the tupump in my gen1 340i running E30 now.
Mg Flasher 2.5
How's my log looking?
https://datazap.me/u/gotemf30/e30-tu-pump?log=0&data=11
      12-12-2021, 03:44 AM   #2024
Scott340
21
Drives: BMW 340i F31
Mg Flasher 2.5
Timing looks good, close to boost target throughout the rev range too. Your WGDC, it's touching 93/94 at the top end of the rev range, which is quite high and indictaes your turbo being worked pretty hard, but would explain why you're achieving 20psi+ still near 7000rpm. BM3 generally taper at the top end down to 18/19 psi and WGDC topping out at 89/90.
No right or wrong, your stressing your turbo a bit more, but going faster as a result. Pay to play and all that!
f30post
