      04-03-2024, 03:32 PM   #177
Chimnino
Drives: F40 128ti
Hi! New 128ti owner here!
Does anybody know a way to code US lights on a EU/German version of the F40?
      04-09-2024, 02:31 PM   #178
F40 120d
Drives: 120d xdrive
I appreciate a lot of what has been talked about in this thread is mainly for enhancing the 135i but I have a 21 plate 120d xdrive auto with comfort pack etc, does anyone know if any of this coding would work on mine? Changing the way the gearbox and engine behaves and also dash set up? Don’t like to repeat previous posts but nobody has mentioned anything about the old dirty diesel!
      04-09-2024, 04:30 PM   #179
cjn
122
Drives: 2021 F40 M135iX
You can get a quick overview of common simple coding changes by looking at the BimmerCode website: https://bimmercode.app/ and looking at what's available for the F40, which should be generally applicable for all this series.
      04-10-2024, 02:09 AM   #180
F40 120d
Drives: 120d xdrive
Nice one, thanks for sharing 👍
      04-10-2024, 02:42 AM   #181
cjn
122
I hope it's useful. However if you are looking for engine /transmission enhancements then the normal coding systems (BimmerCode, Bimmer Utility, E-Sys) won't really help. You'd need specialist assistance.
      04-10-2024, 05:01 AM   #182
F40 120d
Drives: 120d xdrive
Yes very useful thank you, I take it the OBD readers recommended by BimmerCode will give access to the options listed on their site?
      04-10-2024, 05:28 AM   #183
cjn
122
Yes. I'd recommend using ENET with an Ethernet adapter for your iPhone or Android. It's generally cheaper, faster and more complete than some of the other OBD connectors. It also supports BimmerLink if you want that app as well.
      04-10-2024, 07:00 AM   #184
F40 120d
Drives: 120d xdrive
Lovely, thank you very much for your help 👍
      07-02-2024, 03:32 AM   #185
RacingSlow
Drives: E46 330D, E82, F40 M135i
Anybody had any issues with ASD being turned off after coding the default drive mode?
Changed the default drive mode to Sport last night and now appear to have no ASD, although i have not changed anything to do with ASD.
      07-03-2024, 07:11 AM   #186
Manboy
Manboy's Avatar
Sweden
479
Drives: 2020 M135i Misano Blue
I tried that a year ago, from what I remember there was no changes to ASD.
      07-04-2024, 02:43 AM   #187
Erebor
Erebor's Avatar
1767
Drives: M135i F40
I was not even able to deactivate ASD when I wanted to. The artificial burbles in sport mode were still active.
2023 F40 M135i xDrive in indiv. Tansanite Blue
      07-04-2024, 05:27 AM   #188
RacingSlow
Yeah it shouldn't in theory, but it certainly seems like i have no ASD! I have even restored the backup with no luck.
Maybe its just a placebo but even when using bimmerlink to turn ASD on/off I notice no difference. Strange!
      07-05-2024, 04:45 AM   #189
Manboy
Manboy's Avatar
Sweden
479
Did you look in the iDrive menu? Maybe you just need to turn it on there?
      07-05-2024, 07:53 AM   #190
RacingSlow
Its deffo turned on, got it on the top option. Its also turned on within Bimmerlink.... Strange...
      07-05-2024, 03:23 PM   #191
Manboy
Manboy's Avatar
Sweden
479
Any related error codes in Bimmerlink error memory?
Maybe the module needs a hard reset, or disconnet / re-connect battery?
      11-12-2024, 03:19 PM   #192
mkiruc
Drives: f40
hi
i buy bimmercode but my car not have navigation and carplay. how can i active carplay. i was doing carplayy full screen okey. but i cant see carolay in menu
      07-07-2025, 01:29 PM   #193
zdufs
Drives: BMW F40 118d
Originally Posted by fiche335 View Post
I started a new post, had loads of views but no responses.
Does anyone know if it's possible to code in the M-Display rev counter in the HUD of the F40? There seems to be success over on the G20 and G01 pages but little info here.
I have bimmercode installed which I used on my F80 but will need to get a new cable/dongle or should I move to Esys?
Thanks
Did anyone manage to configure this?
      07-31-2025, 02:26 AM   #194
Pier00
Drives: BMW F40 118I
Originally Posted by Spyros E81 View Post
The solution is the Bimmercode app.Buy a compatible adapter to OBD port ( you will find the right adapter to your car in the app) after download the app and then you can find some codes that you can do.
Ciao, io dovrei installare un volante con le palette nel bmw 118i F40, come faccio a fare la codifica alla centralina con bimmercode?
Quali sono i codici che devo inserire e cosa devo modificare?
Grazie.
      07-31-2025, 02:32 AM   #195
Pier00
Ciao, ho comprato un volante con palette per la mia bmw 118i F40, devo fare la codifica alla centralina, come faccio?
Mi hanno detto di usare il software bimmercode, come si usa? quali codici devo inserire?
Se qualcuno mi può spiegare.
Grazie
      07-31-2025, 03:32 PM   #196
mrtfool72
Drives: 128ti
I have the M135i dash in my 128ti. Bimmercode also do an Alpina dash.
      11-27-2025, 03:02 AM   #197
brno100
Drives: Bmw F40
Any useful codings besides loading screen for ID and some other things?
      02-01-2026, 05:30 AM   #198
pan_pedro
Drives: BMW
I’m getting the "Pedestrian Protection System" fault on my dash. I suspect the sensors or actuators are done, and since the car is out of warranty, the repair costs are high.
I want to code this system out permanently. I have E-Sys a ready. Can anyone guide me through the process?
