05-15-2018, 10:59 AM | #177 |
215
Rep 989
Is there any fender rub at that offset? I'm about to go down to 5mm from 10mm spacers on the same offset 17x9
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
05-15-2018, 11:01 AM | #178 |
1567
Rep 673
My only significant rub up front is at full lock, turning left, inside the fender well.
05-15-2018, 05:13 PM | #179 |
115
Rep 1,004
would love more info on the ducting and mounting for the oil coolers, i have one setrab 19 row to start with and dont know if ill keep the stock and add this or just replace the stock and see how the single 19row performs for now. if you want to pm me some more info on the oil cooler i would really appreciate it. also looking for some 18x9 et42 or et38 arc 8's as we speak.
05-15-2018, 05:25 PM | #180 | |
1567
Rep 673
05-15-2018, 07:00 PM | #181 | |
Boost
1355
Rep 3,697
Drives: 135i M-Sport
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
05-15-2018, 08:05 PM | #182 |
115
Rep 1,004
my buddy builds nasa and scca race cars and thats where im doing the install, what you did not say was how much hose you needed and if you ran in parallel or series.
05-15-2018, 08:08 PM | #183 |
115
Rep 1,004
thanks, feel like splitting them up? i have 2 full sets of 1 series fitment arc 8s in black, one set being brand new. going to fish around try to find just a set. i have way too much crap laying around.
05-15-2018, 09:39 PM | #184 | |
Boost
1355
Rep 3,697
PM me
05-16-2018, 11:47 AM | #185 |
1567
Rep 673
Couple cool shots from Sunday's track day at Buttonwillow. There was a crowd of rich kids in the advanced group with us who kept going off and bringing dirt all over the track. I was puckering through Bus Stop into an almost blind cloud of dust. Good shot from my buddy Andrew (@buildjournal on IG)
05-16-2018, 02:47 PM | #186 | |
Professional Hack
96
Rep 379
Parallel would require two pairs of lines; two out and two return. |
05-16-2018, 03:33 PM | #187 |
707
Rep 2,450
Thanks for posting additional info on the oil cooler brackets, much appreciated.
Did you run any sort of rubber padding between the mount/oil cooler and car or is that not needed?
05-16-2018, 05:21 PM | #188 | |
1567
Rep 673
Sounds like you'll be in good hands then. This setup runs in series, one into the other. Order yourself like 15 ft of hose so you have leftover if you screw it up.
houtan707.00 |
05-17-2018, 04:52 PM | #190 |
California-bound
385
Rep 1,480
Car is looking good, brother. We need to have a lap battle. I ran :59.3 on the old SUR4, we can get 2+ seconds off your times with all that front end grip you have.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
05-25-2018, 01:29 PM | #191 | |
1567
Rep 673
I did realize that while I upped the front spring rate to remove crazy front compression and roll, I left the rears the same. 8k/12k is not a big enough split. I have my 16k springs from my E90, where I ran 8k/16k and that car felt great, so I'm going to give it a shot. I'm also sure I either installed the M3 rear sway incorrectly, because it doesn't spin freely in the bushings and has a ton of tension, basically tweaked. This is likely the cause of me not being able to get any power down in the tight stuff. I'm going to try to free up the bar and grease the bushings, or I might just toss in a smaller bar like the Eibach 15mm. The changes never stop haha. Fresh tires going on before I run Streets of Willow on the 3rd and I'll see how the car feels with some proper damper adjustments before switching out anything. In other, non-important news, I removed the arm rest / storage bin and loved not hitting my arm on it during shifts. Also, that thing weighs a surprising amount. It's got to be 10-12lbs. I hated the ugly hole in the back of the console, so I ordered the BMW delete plate that came on the european models with no arm rest. Wood trim is coming out next.
05-25-2018, 03:30 PM | #192 | |
California-bound
385
Rep 1,480
RE Sway Bar: You're experiencing sway bar binding. Most all OEM BMW bars are designed to bind. This will make the bar's affect be non-linear and result in snappier handling. Grind down the flat portion of the sway bar bushing until the bar can rotate smoothly in it's bushings.
05-25-2018, 03:39 PM | #193 | |
1567
Rep 673
05-27-2018, 08:12 AM | #194 | ||
113
Rep 682
My rear setup was an AD08R 285/30 on an 18x10 et55 (effective), then moved to an AD08R 265/35 because the 285/30 had a minimum 3 month wait from Japan. Currently also running a semi-slick 265/35 on the rear on the track. The rear semi-slick section width is 19mm wider than the front same-size semi-slick due to a 1" wider rear wheel - it actuality should only be ~10mm difference. berns, those SPL arms are a nice idea but they only push the bottom of the wheel/tyre out which doesn't really help clearance where it's needed. What's required is for the top of the strut to move even further inboard to provide additional clearance between the tyre and guard/fender lip and bumper tab. |
05-27-2018, 09:42 AM | #195 | |
1567
Rep 673
05-28-2018, 04:49 PM | #196 | |
15
Rep 33
What rack specifically did you use I want to do the swap and I found an 08 M3 rack is there anything that I need to look for? |
05-28-2018, 08:49 PM | #197 |
505
Rep 649
