02-08-2018, 05:12 PM | #177 |
242
Rep 714
Here's before and after. They weren't a performance shop, so no camber adjustments on the coil overs. I'm very low but it's strange that the rear left camber is at -3.4*. Assuming that negative camber is contributing to my car pulling slightly to the left on the road. Thoughts?
Current: 2009 Alpine White/Black e90 m3
Past: 2008 Interlagos/Black e92 m3 |
02-25-2018, 04:01 PM | #180 |
"Cool Prius" - Nobody
28
Rep 32
New member here on the forums. I'm taking my car in this week to be realigned and I was thinking about doing -1.5 degrees of camber all the way around and maybe .05 degrees of toe in for the rear. Any input on this setup? The car feels pretty loose in the rear even though I put a new set of Michelin PSS on the rear.
Currently running: KW Sleeves (1.2in drop in the front and 1.0in in the rear) with 12mm MS spacers all around. Wheels and tires are OEM ZCP specs. Thanks for the help! |
03-04-2018, 08:37 PM | #181 | |
Retired Curmudgeon
3000
Rep 4,075
You can run zero toe up front if you feel the need to run a lower toe setting somewhere on the car. It'll be more darty at the front, but it's a whole lot easier to control a front end that's darty than the rear. Also, set your camber up front at least 1/2 degree more (negative) than the rear. If you aren't tracking the car, just run it in the stock alignment range.
'19 X3 M40 Carbon Black/Oyster, '21 X7 40i AW/Black, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
03-07-2018, 02:01 PM | #182 | |
28
Rep 32
04-27-2018, 05:06 PM | #183 |
92
Rep 403
I had the guide pins pulled on my E92 ZCP today and the alignment came out like this:
F Camber -1.5/-1.5 Caster 7.0/6.9 Toe -0.05/-0.05 R Camber -1.9/-1.9 Toe 0.11/0.11 The car is driven a couple times a week and tracked five or six times a year. If I went to a camber plate system to get -2.0 camber up front would it make a significant difference at the track? Are there any camber plates on the market that don't raise ride height? I’m on 255/35/19 and 275/35/19 AD08R tires. Last edited by Dreamer99; 04-27-2018 at 06:20 PM.. |
06-27-2018, 06:31 PM | #184 |
78
Rep 966
Stock competition pack (before/after).
but with incorrect ballast And then with correct ballast Aside from less good alignment on first attempt, the difference between after on the first photo and before on the second is the impact of not ballasting the seats and boot correctly. Biggest impact interestingly is front toe falls closer to spec with correct ballast. And even without pulling pins. (Wonder how many pull pins and align without correct ballast) That said each step was incrementally better to drive. But now with hindsight the after is night and day compared to before any calibration Alignment. |
07-09-2018, 03:19 PM | #185 |
3553
Rep 2,824
Getting ready to pull my pins and get an alignment soon. ZCP E90, stock suspension, 255/275 PS4S. The car is a weekend/canyon toy; no daily driving/commute but also no tracking. I'm looking for a fun and spirited yet planted and stable setup that won't prematurely wear the tires.
I'm thinking this: -1.8* front camber (or max/equal) 1/32" front total toe-in [OR zero toe] Max/factory caster (not sure if there's any adjustment here with factory hardware; around 6.5-7*) -1.4* rear camber (or .3-.5* less negative camber than the front) 1/16" rear total toe-in [OR 1/32'' total toe-in] Thoughts? Suggestions? Last edited by wyatth; 09-06-2018 at 05:30 PM.. |
10-06-2018, 12:47 PM | #187 |
545
Rep 2,975
Yep, specs you listed look to be right. I'd shoot for zero toe up front - just make sure alignment place you go to is willing to give you the time. Most places now don't truly care about setting an equal balance side to side etc.
10-16-2018, 03:27 AM | #188 |
64
Rep 75
Stock ZCP wheels and suspension.
-1.7 camber front L/R (max negative, pins pulled) -1.9 camber rear L/R (within factory range, I should reduce this to -1.2) Even with plenty of spirited cornering on the street, the rear camber was too much. On the track, it would have been fine, but I’d have needed -2.4 up front for the track, and I can’t achieve that. New rear tires tomorrow; I’ll try to get it on the rack and bring the rear down some. |
07-10-2019, 07:16 AM | #189 |
4489
Rep 7,139
Reading through this thread but don't seem to be able to confirm if there is a difference between ZCP and standard alignment. Have an appointment with a shop who "should" know but always nice to have an idea when going in.
Getting my first alignment during my 5y ownership so will be interesting to see how much have moved if anything. Thanks |
07-10-2019, 01:26 PM | #191 |
4489
Rep 7,139
07-16-2019, 09:05 AM | #192 |
4489
Rep 7,139
Back from the shop with below result. Toe pretty far off but guess it could have been worse considering this probably was the first alignment since new/8 years.
The ZCP specs was different vs non ZCP according to the shop' data, seems to be slightly more aggressive compared to the specs on this thread. Ah well, steering wheel back to center and hope for a stable holyday trip on the road next week. |
08-11-2019, 03:43 PM | #193 |
353
Rep 1,005
Drives: GMC Sierra
Alignment done several months after coilover install. No before just after.
We grow food to feed the animals so we can eat the animals
08-16-2019, 08:12 AM | #194 |
4489
Rep 7,139
08-16-2019, 01:13 PM | #195 |
353
Rep 1,005
Drives: GMC Sierra
No tracking yet. Just maximizing stock mounts without camber plates & factory pins in place.
08-16-2019, 02:36 PM | #196 |
3996
Rep 3,414
Just had race alignment done for this weekend.
19x 9,10.5 Coilovers, camber plates Front: Caster 7.6, 7.3 Camber -3.1 Toe Neutral Rear: Camber -1.9 Toe: 1/8"
Not a Doctor, those are just my initials.
Timujin352.50 |
08-16-2019, 05:00 PM | #197 |
353
Rep 1,005
Drives: GMC Sierra
That's aggressive!
08-17-2019, 08:49 AM | #198 |
4489
Rep 7,139
