04-22-2022, 06:43 AM | #177 |
61907
Rep 19,989
Both Ferrari's are out on the track and Lec spins! His car looks a handful on the wet track it's all over the place.
Sainz and Ocon have had new PU's fitted. |
///M Power-Belgium64759.50 |
04-22-2022, 08:26 AM | #178 |
#buildnotbought
11141
Rep 4,934
It looks like the Ferrari's are fastest in pretty much every circumstance.
BTW the one odd thing the FIA changed in the sprint races, is that the outcome of the sprint race gives the grid positions for the GP race on sunday, except for the pole position. The one who gets the fastest time in Q3, starts both the sprint race as the GP on sunday from pole. Thoughts anyone? Changing the points in the sprint race I can understand. It's quite a lot of risk for just starting grid order and max 3 points (and only 3 times per year)
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
04-22-2022, 09:20 AM | #179 |
64760
Rep 24,963
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
M5Rick61906.50 Killed by Death13221.00 |
04-22-2022, 09:27 AM | #180 |
61907
Rep 19,989
04-22-2022, 09:37 AM | #181 |
61907
Rep 19,989
///M Power-Belgium64759.50 Killed by Death13221.00 |
04-22-2022, 09:45 AM | #182 |
61907
Rep 19,989
Pirelli Cinturato wets and inters hmm .. any secret tyre tests done with Ferrari beforehand??
04-22-2022, 09:51 AM | #183 |
2757
Rep 4,445
Imola Upgrades
Mercedes
Fin in front of the cooling inlet: A third element on the chassis side improves flow to the cooling inlet. Rearview mirror housing: A new shape better separates the flow and optimizes the flow towards the rear of the car. Tear-off edge on the underbody in front of the rear wheels: Improves the flow towards the diffuser and increases downforce at the rear. Deflector end plate in the rear: more downforce on the diffuser roof inside the rear wheels. RBR New wing on the underbody keel, which is slimmer at the front: more downforce. New rear brake vents: Better cooling for calipers and brake discs. McLaren New lower rear wing (Beam wing): More downforce, good timing for rain soaked tracks. Alpine New Underbody: geometry changes to improve downforce. New lower rear wing (Beam wing) Alpha Tauri New Underbody: The front end of the floor has been changed in shape and height to make downforce more stable over different ground clearances. In addition, to avoid bouncing, a new slot was cut into the edges of the floor and the tear-off edge of the floor in front of the rear wheels was redesigned. Both to generate more contact pressure on the base plate. Changes to the front diffuser vertical baffles. Front Brake Vents: The inlet is now a "D" shape to better control the air turbulence from the front wheels. Aston-Martin Halo: Back to the first spec. Rear view mirror bracket: Back to the first spec. Floorplate Bracket: The cable that connects the floor to the gearbox has been moved further forward to prevent the floor from bending in this area and reduce bouncing. Williams Rear wing: Small changes to the flap for better efficiency and better use of the DRS effect. Front Suspension: The wishbone fairing has been changed to give the pushrod more clearance and improve rearward flow. Front Brake Vents Alfa Romeo New underbody: A new geometry of the floor and the vertical baffles in the front diffuser produce more downforce. Wider fairing in the rear wheel area. Rear brake vents: Improved cooling, small aerodynamic gains. Haas Wings on the edge of the base plate: The new geometry is intended to suppress the bouncing that had returned in Melbourne.
M5Rick61906.50 ///M Power-Belgium64759.50 |
04-22-2022, 09:52 AM | #184 |
2757
Rep 4,445
5 spins from the Maranello team.
Not a fan of the sprint weekend, rain makes this even more of a circus. Aston Martin is already using bits from the trash bin.
///M Power-Belgium64759.50 M5Rick61906.50 |
04-22-2022, 09:57 AM | #185 |
61907
Rep 19,989
04-22-2022, 10:11 AM | #186 |
61907
Rep 19,989
04-22-2022, 10:34 AM | #187 |
61907
Rep 19,989
It's battle between Lec and Max as they go into Q2, thank goodness it's dried up.
04-22-2022, 10:46 AM | #188 |
61907
Rep 19,989
Sainz crashes! His tracking is out.
04-22-2022, 10:50 AM | #189 |
64760
Rep 24,963
Just read that Sainz is crashed in the tyre wall ...Game over for Sainz .
The last 10 min. from QF-3 has started ...
M5Rick61906.50 |
04-22-2022, 10:55 AM | #190 |
61907
Rep 19,989
04-22-2022, 10:59 AM | #191 |
61907
Rep 19,989
04-22-2022, 11:08 AM | #193 |
61907
Rep 19,989
04-22-2022, 11:15 AM | #194 | |
64760
Rep 24,963
RED FLAG !!!
M5Rick61906.50 |
04-22-2022, 11:16 AM | #195 |
61907
Rep 19,989
04-22-2022, 11:25 AM | #197 |
61907
Rep 19,989
Phew... BOT's got stuck again lol just as Max went top!
04-22-2022, 11:26 AM | #198 |
64760
Rep 24,963
MAX is P1 ...With 3 min. to go !
M5Rick61906.50 |
