      05-19-2013, 04:36 AM   #133
yawn
No_Country
57
Drives: M2 Competition
This should be ok, right?
http://www.ebay.com.au/itm/Castrol-E...item2ec20ec82e
      05-19-2013, 05:07 AM   #134
froop
froop's Avatar
Australia
171
Drives: 08 AW 6MT E82
Originally Posted by sharkatron
Yeah it's definitely fine. It's BMW LL-01 approved so it's ok. I actually did an engine oil and filter change yesterday and went from BMW 5W-30 to Castrol Edge 0W-40.
Runs nice and smooth when the engine's cold and it's nice and smooth when warmed up too. It might be thicker at normal operating temperatures compared to the 5W-30 but if you're tracking often it's probably the better option.
      05-19-2013, 05:18 AM   #135
flinchy
128
Drives: E82 135i
Originally Posted by skycat
Originally Posted by flinchy View Post
as long as you run a really high quality oil in general it should be pretty right?
few BITOG/evom/SAU etc. threads have done a ton of UOA's on oil that's been used with E85 for 9-10kkm and haven't found any further breakdown/loss in viscosity etc. of just about any brand/weight high quality synth oil - a lot of TALK about needing special oils from the last few years.
you'll have your oil smelling like whatever fuel you use anyway?
Is that right ?
Was partially asking you (if you'd had other experiences) haha, or had some analysis's showing bad oil after e85
I just had a read of bobis forums more than anything - there's a lot on e85 and oil, people using various redline's, motul 300v's, and the analyses all came back acceptable, just like running unleaded
I couldn't find any analysis' showing e85 having a large negative effect, but a LOT of talk of it being a thing
      05-19-2013, 05:22 AM   #136
John_01
John_01's Avatar
Australia
234
Drives: E90 325i, E82 135i
I switched over to Castrol Edge 0W40 A3/B4 (LL01 rated) on the first oil change at 3000km in my N55. The difference in specs between 0W40 and 5W30 is small and it appears on the approved oil list for my car.
      05-19-2013, 05:29 AM   #137
kenson
Drives: 135i
Newb alert!
Just posting to say thanks for all the info re: engine oil.
Just picked up a used 135i and plan on changing the engine oil and brake fluid this weekend.
Might pass the coolant change to a workshop, sounds like a pain.
      05-19-2013, 06:39 AM   #138
sparoz
sparoz's Avatar
Australia
192
Drives: VO 1///M; Macan Turbo
Originally Posted by skycat View Post
Motul say to use 6100 when using E85.
E85 finds its way into the oil and will break it down super quick, we had a Nissan GTR with a dry sump system running E85 you could smell the E85 in the oil at the oil tank, it would burn your eyes and this is after only 2hours running.
Read and you shall find?
Macan S Diesel - Carrera White
Macan Turbo - White
1///M - Valencia Orange
      05-19-2013, 06:57 AM   #139
flinchy
128
Drives: E82 135i
sorry i read around the internet a bit more, as well as, yes, that post... other results (BITOG included) said the same thing when they contacted the manufacturer, but when UOA's came back of 300v it showed no ill effects from the E85 in terms of deposits or fuel in the oil (roughly the same % of E85 found in the fuel as 98RON in prior tests)
is what i meant to say
      05-19-2013, 05:58 PM   #140
Kiwi Peter
Kiwi Peter's Avatar
New Zealand
164
Drives: E92 M3 2012 Edition 500
Any oil with ESTER will turn to jelly when you use E85 I have seen this happen with 300V, best to use a synthetic fortified oil as recommend by Motul.
We have built many race cars in the last 5+years that only use E85 so what I know about this issue is from the real world.
      05-19-2013, 07:30 PM   #141
flinchy
128
Drives: E82 135i
fair enough
i get that 300v and redlines ester stock mainly? - but as long as it has decent amounts of acid neutralizing detergents - not all are the same, obviously, in terms of additive packages - there's a lot of different versions of 300V
http://forums.evolutionm.net/alterna...lysis-e85.html
5 UOA's.. on mobil 1, redline (which is something like 80% ester based but has an appropriate detergent package apparently) and 300v - not sure if you can view without signign up though
ah here's the big thread
http://www.gtrlife.com/forums/topic/...85-conversion/ regardless of base stock, it just matters that you have a high TBN detergent package.
ethanol produces a ton of acid as a combustion byproduct, if you have an oil that doesn't counteract this, then, yeah, the oil wouldn't last? regardless of dino or base IV/V synthetic.
http://www.skylinesaustralia.com/for...nd-oil-choice/
another good thread saying basically the same thing
just change it every couple of trackdays like you would anyway, or 5000 street km... and or conduct UOA's regularly, because they're cheap, and can save your engine.. wouldn't that be the best suggestion?
ED: another (VOA this time) http://www.bobistheoilguy.com/forums...Number=2107073 for 300v showing it should be pretty solid for E85 use. higher TBN than redline by a decent amount.
I like redline so far though on all my other engines, so i'll give a higher weight one a go wih the E85 and get a few UOA's done to make sure.
1addicts
