M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 6MT fluid change
      01-16-2024, 11:38 PM   #133
chris719
7394
Drives: '08 M Roadster
Originally Posted by 3t3p View Post
Redline doesn't seem available in NZ. No Doubt could be imported at cost, does fcp euro stock? Have ordered from them before.
Liquimoly has a presence here and my garage use their oils, it's LT5 spec and appears as based on rather than fully synthetic?
https://products.liqui-moly.co.nz/du....html?sku=3640
My car is now 38,000 miles.
Occasionally get the can't get into first problem. Car is daily, no track, short commutes but engine does get to temp. Driven in anger now and then at a weekend. Thanks
Can you get Ravenol PDK Fluid?
https://www.ravenol.de/en/product/ge...-atf-pdk-fluid
Some compelling data here even if it is from Ravenol:
https://www.ravenol.de/en/oiltests/r...enol-pdk-fluid
Note it should be this PDK fluid not the other DCT fluid they offer. This one lists BMW-MTF-LT-5. I would try this or genuine Pentosin FFL-3 if you can't get the other fluids. Actually, I like this fluid better than the regular Motul DCTF on the spec sheet anyway.
I am running the Motul High Torque DCTF and it seems to have made my cold shifting worse but hot is better. I can only say seems because I did change it as temperatures were dropping.
F87source7367.00
      01-17-2024, 12:54 AM   #134
F87source
F87source's Avatar
No_Country
7367
Drives: Bmw M2
Yikes that's not good to hear, the motul high torque dctf seemed so promising especially in Jimmy's car and use case.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242
      01-17-2024, 01:14 AM   #135
chris719
7394
Yeah I'm not ready to conclude anything yet. It does seem better once the car is up to temp, and I did change it just before it got really cold here.
F87source7367.00
      01-17-2024, 02:06 AM   #136
F87source
F87source's Avatar
No_Country
7367
Drives: Bmw M2
Let the car idle a bit longer before you drive it. Because even in neutral the gears in the gear box are being spun and that warms up the oil.
But imo a good synthetic oil shouldn't have issues in the cold. On the stock fluid I noticed it performed significantly better in the cold weather vs. then hot summer, so that probably means the stock oil might be getting too thin in the hot summer. I'm hoping redline dctf will be able to bridge the gap and keep the performance good in the summer and the winter.
chris7197393.50
      01-17-2024, 03:02 AM   #137
3t3p
New Zealand
455
Drives: M2
Ravenol doesn't seem available either. Need to move to Australia lol!
      01-17-2024, 03:27 AM   #138
chris719
7394
Yeah I don’t know really. I thought the stock fluid was better warm for me too lol. The Motul HT is actually a tiny bit thinner than OEM fluid at 40 C and has a -69 C pour point so you’d think it’d be at least as good in the cold. The viscosity index is lower, so at some super low temp they will cross over, but I think the shift feel is possibly more dependent on friction modifiers etc since they are all thin fluids.
F87source7367.00
      01-17-2024, 11:41 AM   #139
F87source
F87source's Avatar
No_Country
7367
Drives: Bmw M2
Yeah most likely, not sure why the motul behaved worse.
      01-18-2024, 04:16 AM   #140
doughboy
doughboy's Avatar
1546
Drives: 2018 M2 Comp 6MT
Or try motul dctf.
Liquimoly is junk. Just fashion oil, like a cheap shampoo in fancy packaging.
      05-10-2024, 03:40 PM   #141
Apexeater
Apexeater's Avatar
43
Drives: 21 BMW M2 Competition 6 speed
Just looking for any updates from people using the Redline DCTF in a manual trans. I'm at 23k and gear changes have become a bit notchy (more than normal). I occasionally need to put it in neutral to engage 1st gear.
      05-10-2024, 05:59 PM   #142
David.m
449
Drives: M2 LCI 6MT BSM
Adding to my last post here https://f87.bimmerpost.com/forums/sh...&postcount=128
I'm now at 135K km and still the issue selecting 1st gear when stationary hasn't happened once with the Redline fluid (last 50K km).
I haven't researched what change intervals should be but I first put it in at 85K, changed at 110K and will probably do again shortly even though I don't feel any deterioration in shifting.
Appreciate 2
F87source7367.00
      05-11-2024, 12:12 AM   #143
vrooooom
New BMW owner
vrooooom's Avatar
Philippines
328
Drives: 2018 BMW M2 LCI
23k only?! Might not be a fluid issue coz the transmission fluid is supposed to last longer than that.
      05-11-2024, 12:06 PM   #144
Apexeater
Apexeater's Avatar
43
I would read the rest of this thread. It seems to be common to replace around the 20k point.
      05-11-2024, 03:23 PM   #145
No_curebimmer
~Spyder
No_curebimmer's Avatar
Sweden
645
Drives: '19 M2C Hockenheim 6sp
As another data point: I changed my MT fluid this past Sept ‘23 with Motul High Torque DCTF, (my ‘19 M2C had ~ 10k)…and I too noticed a slightly rougher shifting when engine was cold. However, once everything warmed up - perfectly smooth, but not overly. The OE transmission fluid ‘seemed’ smoother during the first 10-15 min, but I had somewhat frequent shifting issues (N to 1st, or 1-2). Nonetheless, it isn’t a drastic change, and certainly nothing that would bother me - hard to really have an objective conclusion w/o doing back to back tests, but I reckon that, with any change or or upgrade we do on these cars, the more in tune (or sensitive) we become w.r.t. any deltas - good or bad.
Note that I also have AutoSolutions SSK, which is, IMHO - one of the best mods you can do for this car!
Shout out to F87source who has been an invaluable source (to me personally and many other forum members)
Skål från Sverige...via Texas y-all
Appreciate 2
chris7197393.50
F87source7367.00
      05-14-2024, 12:46 AM   #146
MSH_
MSH_'s Avatar
137
Drives: 20 M2C
I just changed mine last month to Redline DCTF at about 24500 miles at same time I did my diff oil. I can’t believe I missed seeing FCP euro stocks the Redline because I’m sure I checked when I ordered the diff fluid and more motul xcess 5-40/filter/etc.
Anyway, it seems to have helped a touch on my car but I didn’t have the notchy issue you do. I did have the turner rear bushing installed at time, which tightened everything up to begin with but as of a couple weeks ago that came out (went back to stock rear bushing), as a autosolutions ssk went in along with e90 clutch slave cylinder. Anyway with the fresh dctf, the ssk, and cdv delete the shifting is fantastic.
      05-14-2024, 01:41 AM   #147
F87source
F87source's Avatar
No_Country
7367
Drives: Bmw M2
I just bought 2 bottles of redline DCTF and it is coming soon, so I will try and remember to report back once all of my servicing and mods are installed this year.
      05-14-2024, 08:32 AM   #148
MSH_
MSH_'s Avatar
137
Drives: 20 M2C
I know you had mentioned FCP carrying Redline DCTF in a prior post. Do you know if this is a recent addition to FCP's offerings? When I ordered my diff fluid, etc back in October last year I did a search on the website and could not find it, so I ended up ordering the DCTF from ECS instead I always try to order anything I can through FCP.
      05-14-2024, 01:45 PM   #149
F87source
F87source's Avatar
No_Country
7367
Drives: Bmw M2
No it wasn't a recent addition, it's probably been on FCP Euro's site since September. You just couldn't search for it by name since they didn't add it properly, you could however search for it via part number 31004.
MSH_136.50
m2
