10-15-2016, 10:23 PM | #133 | |
2056
Rep 1,984
10-16-2016, 12:35 PM | #134 |
589
Rep 1,094
I actually passed on the install when they confirmed it was the same part as the revised version. However, the SA did say it was 'Index 03', which leads me to believe the third version of the plate may be now available. Luckily, I haven't gotten one since, but I'm prepared to push the shields back to remedy. As for the new shields, I'll discuss it with them when I go in for my 1200 mile break-in service.
12-29-2016, 05:15 PM | #135 |
59
Rep 237
Drives: F90 M5, prior F80 M3, E60 M5
intermittent car noise
I have had my F80 for about 9 mo now and enjoying quite alot. Periodically, however, during random driving times (straight, turning, etc) I hear a noise that can only be described as metal scraping like what happens when you go over a speed bump on a lowered car. It doesnt happen all the time and I am not sure if it happens only in sport/sport plus. Doesn't seem to affect performance and only lasts a few seconds?
Any ideas? |
12-29-2016, 05:43 PM | #137 |
248
Rep 389
Maybe a pebble/stone caught between the brake dust shield. It's a very common issue with the F8x's.
Do a search in the future, you'll find tons on the topic.
IG: westbankm4
2019 F82 CS 2003 E46 M3 |
12-29-2016, 06:29 PM | #138 |
53
Rep 167
As posted above, its probably a rock stuck between the brake dust shield. It happens on my 2017 periodically and like you it only last a second or two before going away.
12-30-2016, 06:56 AM | #139 |
1843
Rep 4,203
Just a small something I found....if you up under there with the wheels off and you lean on or bump one..... it can be slightly distorted just enough to scrape. I found that out when I installed my coil overs
01-17-2017, 08:08 PM | #140 |
Rep 25
Recurring 'stone-and-the-rotor-shield' problem
I seem to find that any time i drive over a road with any amount of small pebbles/stones on it, I invariably hear the dreaded grinding from the stone getting between the rotor and the shield. It lasts for only a couple of secs but it does get on my nerves. Anyone else having the same issue?
Another problem that I have found is a creaking sound that comes from the passenger side front end and this is only when the steering is turned right close to lock. What could this be? |
01-22-2017, 10:48 AM | #141 |
75
Rep 382
Same issue here, on multiple F8x too...super lame but seems to be the 'norm'.
Probably my biggest complaint about the car.
F80 M3 ZCP - Current...E28 M5 1/30 Blk/Blk US Spec - Current...17' 911 - SOLD...E90 M3 - Sold...F82 M4 - SOLD...F02 750Li - SOLD...Austin MINI - SOLD...E82 135is - SOLD...E89 Z4 - SOLD...F10 535i - SOLD...E30 325is - SOLD
01-22-2017, 11:19 AM | #142 | |
256
Rep 928
I have been told just pull back the heat shield in order to release the rocks.
Gone but not forgotten:
2007 E63 M6 SMG, 1999 996 Carrera Cab AT, 2007 & 2008 E90 335xi AT, 2011 E93 M3 DCT, 2X 2002 E46 M3 SMG & 6MT, 2016 F80 M3 DCT |
02-09-2017, 01:23 PM | #143 |
Rep 1
worst sound ever
It was happening on my 2017 and brought it in for a non related issue and they did have the new shields so they swapped them out and no noise so far... its been a week..... lets see
02-11-2017, 11:17 AM | #144 |
Commander-In-Chief
2206
Rep 8,950
Drives: 2023 M2 Coupe, 2020 GLE 450
Rear rotor shield update
I had updated shields installed on my '15 (7/14 delivery) in August '15. This much improved the symptoms, but did not completely eliminate them, especially lately when they put down gravel on the roads for snow events. Had some rocks removed when my car was in yesterday for alignment and they ordered the second generation replacement shields for me - should be in next week.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-19-2018, 07:56 PM | #145 |
Rep 2
Know this is old & the f80 forum but anyone have the same issue regarding a grinding noise from the d/s rear? I’m taking it into the dealer tomorrow so they can take a look to see what it is! Here’s a link to a video I found where it sounds like it has the same exact problem but I’m not sure what it could be!?
06-27-2018, 04:23 PM | #146 |
75
Rep 125
I have a 2016 ZCP M3 with Carbon Ceramic Brakes. I have had this issue happen 2 times, rock gets stuck and makes a awful sound. Pushing the heat shield back and it fixes it. I take my car to the BMW dealership and had them look at it. They said there is a TSB for the rear dust shield but it does not apply to CCB cars. I tried calling BMW NA and they don't have anything regarding this issue. I am not sure what to do at this point.
2016 M3/6-spd/ZCP/CCB/Mineral White on Black HEX Tuned - Stage 1 by VF Engineering IG: @JAYT_M3 |
07-18-2018, 07:35 PM | #150 |
122
Rep 595
Finaly had time to pick up my car at the service center.
Both shields upgraded to latest version and a bunch of little bits and odds also replaced with it. |
07-22-2018, 10:39 PM | #151 |
125
Rep 244
Hey guys,
I have had a persistent (and very annoying) squeak like noise coming from my front CCB brakes. I just removed the wheels and tried to find jammed rocks/pebbles, but could not find anything. The noise can be heard with the windows up while cruising at low speeds. I originally thought it was the suspension, but the sound is clearly tied to the rotation of the wheels and you can hear it spin up as you increase speed. As soon as you press the brakes, the noise instantly goes away. It's a 2018 M3 with 6K miles. : Has anyone experienced this or have any potential tips? |
09-12-2020, 10:00 AM | #152 |
29
Rep 90
I'm having my car go in for service next week and one of the issues I am having is the issue discussed here. My warranty ends end of October so I'm trying to get anything addressed while I have coverage. I see lots of people mentioning a technical bulletin. Does anyone have details on the buletin or actual doc?
04-24-2022, 11:16 AM | #153 |
2362
Rep 4,255
Same part number? Can anyone share the Bulletin? Have a friend with this issue and I'm coming up short on finding this "updates" heat shield part.
///M Power
