11-28-2019, 07:35 AM | #133 | |
798
Rep 1,736
Drives: 2019 BMW 540i xDrive
Low-temperature (front) or High-temperature radiator (behind) also is it possible to see the part number without lifting up? |
11-29-2019, 07:42 AM | #134 |
798
Rep 1,736
another thing, was the coolant suppose to be blue or green? I opened mine (which is brand new vehicle) for the first time and it's green, did BMW switch their OEM coolant recently?
11-29-2019, 09:07 AM | #136 |
798
Rep 1,736
Ok just spoke to an BMW independent shop (dealer service desk is like no one there the day after thanksgiving) supposedly 2019/2020 vehicle are all getting the new green coolant and it's not advised to mix... and no one sell that new part yet, so guess have to take to someone to drain first...
11-29-2019, 10:29 AM | #138 |
798
Rep 1,736
Oh and even better according to some guy on reddit BMW NA f'ed up on not getting EPA certification in time, so I definitely have to use the blue ones, they say it's ok to mix a bit (10%), guess I'll then drive to dealer to have whole thing flush then fill with the blue stuff...
11-30-2019, 07:43 AM | #139 |
798
Rep 1,736
So another update, talk to dealer they say I can mix they will flush the whole system when I bringing on Wednesday.
12-02-2019, 09:20 AM | #140 |
798
Rep 1,736
then another update, basically, is my dealer playing games?
they say they top of the reminder coolant and did a test (no leak) but wouldn't flush the system because they say the one I bought (non BMW but did say can be used for BMW since I was in a hurry) is ok and BMW wouldn't pay for flush, should I fight on this? edit: and can't give me any reason why coolant is green instead of blue or why coolant is low on a car <3000 miles and <1 year (other than wasn't filled fully up when left factory) |
12-02-2019, 10:48 AM | #141 |
2873
Rep 5,162
I'm no mechanic but I think you are fine. There is a record of your visit so I'm the unlikely event of any further issues, it's on them to resolve.
Doesn't the coolant get replaced at one of the future services anyway? Not sure when , maybe someone will know but thought it was in a similar way to brake fluid being replaced every x years as it will age. Does coolant age? |
12-02-2019, 11:36 AM | #142 | |
798
Rep 1,736
12-02-2019, 04:10 PM | #143 | |
37
Rep 56
12-02-2019, 05:26 PM | #144 | ||
798
Rep 1,736
12-02-2019, 09:52 PM | #145 | |
37
Rep 56
It would have costed me around $3000 for the fix according to the work summary left in my car which was covered by BMW warranty. |
clee1982797.50 |
12-02-2019, 11:08 PM | #146 | ||
798
Rep 1,736
12-08-2019, 02:32 PM | #147 |
1708
Rep 2,539
Sooo for anyone interested, the dealer found my main water pump leaking coolant during its annual oil change visit. By the way, I had to top off my coolant 2 weeks ago as I got the warning message before starting the car. The last time this happened was probably 8-10 months prior.
So there you have it. Leaky water pump getting replaced under warranty. Car has 27K miles. Glad they found the source of the coolant leak. Coolant is getting replaced, along filters and break fluid flush and change.
2017 BMW 530i, Sport Line,Alpine White, Canberra Beige Sensatec, 19 inch V-Spoke wheels, basic plain Jane build with no options whatsoever..... "Less is more".
Before: 2011 BMW 328i E90 sedan, Platinum Bronze Metallic, Dakota Brown leather, 17 inch wheels, 6-speed auto, N52 6 Cyl inline N/A goodness.... |
clee1982797.50 |
12-09-2019, 03:46 PM | #148 |
1708
Rep 2,539
In case anyone is interested, received my car back today. So in addition to the mechanical main water pump (Part 11-51-8-638-026) they also found turbocharger coolant line leaking as well(Part 11-53-7-643-094).
Let's see how long the new parts will hold. I am Also going to check if these are the same part numbers as the original factory parts or rather these are new part numbers that replace the originals. Bottom line: Mysterious coolant consumption is not normal and must be nipped in the bud sooner rather than later before if Becomes a bigger and costlier problem.
clee1982797.50 |
12-09-2019, 04:58 PM | #149 |
798
Rep 1,736
yup if it happens again I'm going to just complain to dealer no stop...
12-09-2019, 05:25 PM | #150 |
1708
Rep 2,539
There is a Puma case out for this too.
clee1982797.50 |
12-11-2019, 04:43 AM | #151 |
1708
Rep 2,539
Here is the PuMA measure in case anyone is interested:
PuMA measure B38, B46, B48, B58, XB1H - Check Control message: Top up coolant 63482185-05 - 16/04/19 Complaint: Check Control message (ID 166): Top up coolant The coolant level in the coolant expansion tank of the high-temperature coolant circuit is below the minimum. There may also be traces of coolant in the engine compartment or where the vehicle is parked. Cause There are various possible causes: The cooling system was not sufficiently bled initially. While driving the cooling system bleeds and as a result the coolant level drops in the coolant expansion tank. The cooling system is leaking (impermissible coolant loss). Measure +++ Revision to the previous version of the PuMA measure: Note: Bleeder screw: Observe tightening torque of 2.5 Nm. +++ In the event of a customer complaint, proceed as follows: Attention: Only perform the following work on cooled-down components. 1) Check coolant circuit for watertightness: See repair Instructions 17 00 009. Check the high-temperature coolant circuit for watertightness using test for loss of pressure. Test pressure of cooling system (excess pressure): 1.5 bar test period: 10 minutes 2) Observe pressure: No pressure drop: Continue with point 4. Pressure drop present: Continue with point 3. 3) Search for leak. Check coolant pump. The coolant pump has a reservoir. During engine operation the slide ring seal of the coolant pump needs to be lubricated. The coolant required for lubrication is collected in the reservoir. Slight traces of coolant could be visible on the lid of the reservoir. Slight traces of coolant on lid of reservoir (see attachment, figure 1): Clean the lid. Check if coolant leaks again at the lid if excess pressure of 1.5 bar is applied. - If coolant is leaking: Replace coolant pump. - No coolant leaking: Do not replace coolant pump. Search for leak and repair accordingly. Excessive traces of coolant on lid of reservoir (see attachment, figure 2 and 3): Replace coolant pump. After repairing the leak: Bleed cooling system and check for watertightness: See repair Instructions 17 00 039. Note: Bleeder screw: Observe tightening torque of 2.5 Nm. 4) Release pressure: Adjust the filling level in the coolant expansion tank of the high-temperature coolant circuit. In doing so, it is imperative to follow repair instructions 17 00 039. The filling level in the coolant expansion tank is adjusted either to the maximum mark or 200 ml above it, depending on the model. Notes on factory filling of high-temperature coolant circuit: The initial coolant circuit capacity of the high-temperature coolant circuit was already optimised in the vehicle factories. The introduction dates are: F20, F21, F22, F23, F30, F31, F32, F33, F34, F35, F36: 01 September 2017 G11, G12: 5 June 2018 G30, G31, G32: 01 February 2019 G38: as of series launch Invoicing: Processing and reimbursement must be conducted according to current warranty conditions. In case of defective cooling system bleeding, use the following defect code. Recommended defect code for GWK cases: 17 11 00 72 00 Use the following defect code for a leaking coolant pump. Recommended defect code for GWK cases: 11 51 07 48 00 For other leakages. Obtain the corresponding defect code from the "Commercial Service Data (KSD)". Validity information Model series:[F30, F21, F32, G31, F31, F20, G30, F23, G11, F34, F33, G32, F22, F36, F35, G12, G38] Engine range:[B58M, B48M, B46O, B48O, XB1H, B38M] Body style:[ALL] Fault codes:[] Production period:-
clee1982797.50 |
12-11-2019, 12:14 PM | #152 |
798
Rep 1,736
kind annoying my car is back already, though I have an oil change Jan next year maybe I'll just bring this up to them again?
12-11-2019, 12:31 PM | #153 |
1708
Rep 2,539
Well that's how they discovered the leaks, during the scheduled oil change/yearly maintenance. Do complaint about the low coolant so they can note it in the service ticket.
clee1982797.50 |
12-11-2019, 02:29 PM | #154 |
37
Rep 56
I got the car towed back to them using BMW roadside assistance (included with the car). I refuse to drive it when I discovered the reservoir was dry.
They had no choice but to do a full system check and agreed to the warranty claim and replace the expansion tank as per the report that was given to me afterwards. |
clee1982797.50 |
