11-11-2023, 04:27 AM | #112 |
Rep 12
lpawelek
Siemasz, Mam x5 50 2019 Mam pare pytan odnodnie Bu- aSLA, TLA, itp Nie do konca potrafie to uzywac z cheat sheet Jak bys mial chwilke, I chicialoby ci sie To napisz mi w Pm twoj number Whatsappa Ja nie moge jeszcze pisac Pm Nie Mam wystarczajaca postow… Dzieki!! Sorry y’all I have few questions about bu I feel like my fellow polak might be down to answer me few questions |
12-23-2023, 12:43 AM | #113 |
31
Rep 78
Is possible to set a parameter that would stop the car ahead of location of the stop light?
That would help/ solve the issue that in US the traffic lights are after the intersection vs just before the intersection in Europe or other places. |
02-15-2024, 07:57 AM | #116 |
Rep 50
Hello,
Just updated OTA from 03.2023 to 11.2023. Impossible to put back TLA when it worked perfect before update. The option is available in the idrive put I can't select. I use BU and cheat codes does'nt work anymore for TLA. Thanks. |
sac0249.50 |
02-23-2024, 10:31 AM | #117 |
Rep 3
02-24-2024, 05:03 PM | #118 | |
213
Rep 452
Drives: 2017 X5, 2020 X5 & 2021 X5
Current: MY 21 X5 3.0d xDrive MSport
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive |
02-24-2024, 05:14 PM | #119 | |
213
Rep 452
Secondly when using the cheat codes to change, do one or two lines at the most Especially "Land masks" to "FF FF FF FF" execute one command at a time and save and check to confirm the file has been changed to the new value. I have found when trying to execute multiple lines in one step they are not always saved to the "new" values
MY 20 X5 2.5d xDrive MSport MY 17 X5 2.5d sDrive Last edited by Bambazonke; 03-09-2024 at 02:31 PM.. |
02-24-2024, 05:18 PM | #120 |
213
Rep 452
Yes BU can do all but you must put the vehicle in diagnostic mode (press start button quickly three times without foot on the brake) A message will come up on the instrument panel telling you your vehicle is now in diagnostic mode and will give you access to all ECU's
02-25-2024, 12:34 AM | #121 |
Rep 2
03-08-2024, 03:49 PM | #123 |
Rep 3
Bambazonke
There is a question about DEFAULT_EINSTELLUNG_STL_BEI_TFL. Are you sure this option applies to TLA? Esys contains such a comment: (ger) MenüDefaulteinstellung für Standlicht bei Tagfahrlicht (eng) Menu Default setting for parking light for daytime running lights |
03-09-2024, 02:26 PM | #124 | |
213
Rep 452
03-09-2024, 06:00 PM | #125 | |
Rep 4
What does the IntRxSWINVarianten parameters change/ impact? And to what value should these be set for a Feb 2020 G20 (software 03-2023)? I have coded aSLA, TLA and UCC to my 2020 G20 today. Most of the features are working. Although braking for traffic lights is very late (maybe because TLA is officially not supported in the Netherlands). And the green light alert is not working. So I am going over the coding again to check whether I missed something. Bambazonke Would be great to receive your cheat sheet. I have sent you a PM. |
03-17-2024, 05:08 PM | #126 | |
213
Rep 452
03-20-2024, 05:51 AM | #127 |
Rep 2
03-20-2024, 12:24 PM | #128 |
Rep 29
Drives: 2018 530E xDrive, 2021 45e xD
I've tried doing a quick search but couldn't find anything definitive ... which of these two options works on US cars? (I have DAP, '21 45e)
03-20-2024, 03:52 PM | #129 |
213
Rep 452
They may do, however in my X5 assembled in Aug 2019 i had a generic setting value which after coding verification and changing the build date to 07/20 (when TLA was first introduced to the GO5 in certain markets) the value changed to a model specific value. Normally code settings for window functions are to be found in the BDC modules not in the SAS3 & DSC_VIP ECU's. These values may be already set to model specific values in vehicles assembled after July 2020 if they are indeed related to non TLA features.
03-27-2024, 04:15 AM | #130 |
11
Rep 46
Hi, I am new Bimmer Utility user and I tried activate urban cruise control with some codes, BDC_BODY3, HU_MGU, SAS3, DSC_VIP_IB4 module. But I couldn't find any relevant codes in KAFAS4.
However, after coding, my steering wheel does not detect my hand. always blink after 5 second, and steering wheel icon change to grey color. I would like to share which codes I change all, but afraid that it should be violate forum's rule.... Any idea? |
04-05-2024, 06:49 AM | #131 |
Rep 4
04-05-2024, 07:25 AM | #132 | |
Rep 4
