08-27-2020, 12:40 AM | #111 |
450
Rep 992
That happened to my MPSS too when I was sliding the front tires a bit too much. The tech support at track told me overheating often causes that and I was advised to end my day due to those. You might want to check with an expert if it's safe to keep tracking with that.
08-27-2020, 01:55 AM | #112 | |
18872
Rep 14,143
Drives: G82 M4C X-Drive
edit: Also, it looks like you are on MPSS. MPS4S has beefier shoulders and different compounds on the inner vs outer shoulder. This could be why they wear different than the MPSS.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 08-27-2020 at 02:02 AM.. |
08-27-2020, 09:17 AM | #113 | ||
264
Rep 769
08-27-2020, 09:26 AM | #114 | |||
18872
Rep 14,143
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
08-27-2020, 09:29 AM | #115 | ||||
264
Rep 769
08-27-2020, 11:12 AM | #116 |
142
Rep 606
Got GC camber plates installed finally. I was going to go with a street alignment then knock them out for track use but I was told that's not really feasible due to the strut tower brace
But the alignment I think looks good so I'm excited to try it. Running A052 stock sizes. But lots of street use in between. |
08-27-2020, 11:56 AM | #117 |
319
Rep 317
Just installed my Vorshlag camber plates & Fall-Line rear toe arms w/ eccentric lockout and got aligned.
F: -2.7° camber | 1/16" toe out/side | 7.8° caster R: -2.2° camber | 1/8" toe in/side - Vorshlag camber plates are really nice, easy to adjust, and hopefully that huge spherical on top lasts a long time. No issues accessing the full adjustment range with the brace installed. - Toe arms look nice too and sealed bearing should last a long time, got rid of some acceleration bushing deflection. - Next up will be camber shims so the eccentric stops moving at track days. Adding front camber has completely changed how the frontend of the car holds the road, it finally feel like a sports car. |
08-27-2020, 01:18 PM | #118 | |||||
18872
Rep 14,143
08-27-2020, 02:21 PM | #119 | |
1019
Rep 859
The last year or so I have not been daily driving my car much as well as pushing the car more so I’ve gone to a more track focused alignment and adjusting when I get to the track for further benefit, approximately -4.0° at the track. It’s surprisingly easy to go back-and-forth and as long as you get the toe settings done in your street position. The toe will change when you adjust camber, but it changes for the benefit when adjusting for the track - toe out. Again, important that you get something close to 0 toe for street driving. Edit: strut brace does not get in the way, not sure what your shop means by this. You do have to flip two of the four bolts into the outboard position when going above approximately 2.6° of camber Last edited by fanatic1; 08-27-2020 at 02:24 PM.. Reason: Add |
08-29-2020, 11:55 AM | #120 | ||
142
Rep 606
What do you mean about flipping the bolts? I can try to get some pictures at some point maybe. |
08-29-2020, 03:54 PM | #121 | |
1019
Rep 859
EGbeater116.50 |
08-29-2020, 03:59 PM | #122 | ||
142
Rep 606
08-29-2020, 04:20 PM | #123 |
1019
Rep 859
08-30-2020, 08:32 AM | #124 | |
142
Rep 606
When you do the basic alignment do you put the camber plate in about this position and then bang it to max for race? Or do you try to keep the camber plate in the minimum position? If you leave it where it's at for the basic alignment how do you know where to go back to when you go from track back to street? Just make a mark on the plate or something? Also do you recommend removing the rubber covers etc? Right now my plates make no noise or NVH at all I don't want to mess that up. |
08-30-2020, 11:32 AM | #125 | |
1019
Rep 859
Yes, pretty much set to minimum possible with bolts in race position, Approx -2.6, then bang it to max at the track, approx -3.8 I did remove the rubber covers, but Southern California doesn’t get much rain. |
08-30-2020, 01:10 PM | #126 | ||
142
Rep 606
I think I'll let this sit for this season then next season get it realigned like you said to minimum negative in race position and at least all bolts will be accessible. He won't charge me more to access it which is good. Not sure if getting a vice grip around it to loosen it just a bit so we can slide it back out and remove the bolt is possible? Might be worth trying. |
fanatic11018.50 |
08-31-2020, 12:34 PM | #128 | |
1019
Rep 859
What works well for me is setting up my street driving settings with zero toe and moderate camber. Then adjusting at the track for additional negative camber which results in tow out: desirable for the track. For street driving, -2.6° of camber and zero toe is acceptable. At the track, depending on tires, I’ll go as high as -4.0° |
08-31-2020, 12:36 PM | #129 | ||
264
Rep 769
09-01-2020, 12:18 PM | #130 |
319
Rep 317
Something is wrong -- prior to camber plates i had -1.8 camber 0 toe in the front and -2.2 camber 1/8" total toe in for rears and my tire wear is just fine -- if anything my outer shoulder on the fronts wore down because of the lack of front camber and 2 track days.
09-08-2020, 04:09 PM | #131 | ||
264
Rep 769
