06-09-2016, 12:20 AM | #111 | |||
Plenipotentiary
2614
Rep 3,046
On a somewhat positive note, Brembo/SGL is releasing oriented long strand CCM direct replacement rotors for BMW MCCB. These will last slightly longer under hard use and can be refurbished to extend the service life. They won't perform as well on the street however without a change in driving style. The calipers will also need to have the Pistons (which are an odd size) upgraded and possibly refinished as the paint is only good for color up to 180C and will begin to delaminate and eventually melt around 210C. I've been playing around with some AP Racing Endurance cooling ducts that do fit the rear calipers but aren't a direct fit on the front for F8x MCCB....yet Last edited by lemetier; 06-09-2016 at 12:28 AM.. |
paliknight2192.50 |
06-09-2016, 07:04 AM | #112 |
///M3
387
Rep 1,123
If you look around at what most Porsche drivers prefer for the track it is steel brakes. The cost to replace the CC rotors/pads is far greater than the steel counterparts.
I have unintentionally banged the steel rotor many times while swapping tires at the track. If this happens with the ceramic rotor, I probably would have chipped it many times already. Also, the steel allow for an 18 inch wheel which saves on tire costs. Just my $.02 |
06-09-2016, 09:45 AM | #113 | |
Plenipotentiary
2614
Rep 3,046
Take a look at the Pagid Friction graphs. The RSL1 has far more deceleration ability than the RSC1 and RSC3 MCCB compatible pads. |
06-17-2016, 12:26 PM | #114 |
47
Rep 210
Does anyone know how much it costs to replace rotors?
Would it be conceivable to replace the ceramic rotors with iron ones for track use, ore are the piston sizes specific to ceramic? |
06-17-2016, 12:30 PM | #115 | |
47
Rep 210
Completely true!
And, the cabon beakes brake differently too. Less initial bite and then much more when theyre really hot. I like steel bcz Im old school and thats what Im used to... Quote:
06-17-2016, 12:54 PM | #116 |
1117
Rep 1,904
For someone who claims to know so much about the pros and cons of CCB rotors - How is it you don't know that YOU DON'T MEASURE CCB ROTOR THICKNESS to determine if they are worn out? (You weigh them - they don't actually get any thinner - the carbon burns out from inside the matrix...)
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 |
08-25-2017, 09:37 AM | #117 | |
Rep 4
For BMW CCB rotors yes, but for some Audi discs you have to measure the thickness of the discs
08-28-2017, 09:40 AM | #118 | |
1117
Rep 1,904
AFAIK: You have to weigh them unless you have a Carboteq instrument. The Carboteq instrument is expensive ($6500) but it is the definitive method to check the rotors and you don't have to take them off the car. I know both BMW and Porsche stamp their rotors with the same Values the Carboteq is reading. Weighing the rotors is the next best way to check the rotors if you don't have access to a Carboteq. I wouldn't know any reason why Audi would be any different then Porsche... So, please enlighten us with a reference that indicates that the Audio CCB rotors get measured. I'ld like to see and learn from that! What are the max/min values for measuring thickness on Audi CCB rotors?
08-28-2017, 06:37 PM | #119 | ||
Plenipotentiary
2614
Rep 3,046
CanAutM321131.50 |
08-29-2017, 02:09 PM | #120 |
1117
Rep 1,904
You mean CFRC Formula 1 and Aircraft brakes? I was unaware that Audi sells those on their cars.
08-29-2017, 02:49 PM | #121 | |
Plenipotentiary
2614
Rep 3,046
The Audi discs being referred to are these which are one of the CCM variants. P.S. Did you ever read my PM regarding the updated TIS F8x brake documentation? |
09-15-2017, 10:08 AM | #122 |
1117
Rep 1,904
What PM? I don't see any PM from you...
09-16-2017, 01:49 AM | #123 |
Plenipotentiary
2614
Rep 3,046
09-16-2017, 06:05 AM | #124 |
21132
Rep 20,742
Drives: 2021 911 turbo
Can you share them on the forum?
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
09-16-2017, 08:52 PM | #125 |
1421
Rep 2,561
Drives: Rapidly from A to B
Front rotor for one non CCB is 565 at ecs and 3600 for the ccb equivalent. Do the math. If you plan on tracking the car you're better off financially without the ccb since it's unlikely that the ccb rotor will last longer than 7 non ccb rotors. If you are street only you are also better off financially without since it's unlikely that you'll have to replace your rotors enough times to offset the $8150 cost of the option. Bottom line is that they are great technology but at current price points hard to justify other than that they bring lower unsprung weight.
As an aside, my buddy with a Porsche and factory ccb replaced them with non ccb as he tracks his car a lot and couldn't rationalize the cost.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
Dackelone10639.50 |
09-19-2017, 10:47 AM | #126 | |
1117
Rep 1,904
I ran the CCB's on the track for one season. I went through two sets of front pads, one set of rears and a full set of rotors. My yearly expense was over $12K all said and done... My track has three locations each lap where its necessary to brake down from over 100-130 mph to 30-40 mph for some pretty demanding corners. So its pretty hard on brakes. HOWEVER! This year I tried the RacingBrake CCB replacement kit which swaps out the CCB rotor with an iron rotor and includes "Track" pads. This kit is "advertised" to allow swapping out the CCB Rotors and Pads while maintaining the original calipers. Complete and Total Failure! I burned through the front set of "TRACK" pads in less than a day and a half at the track (about 180 miles). The pads actually went metal-on-metal with the rotors and the car departed the track. I sent all the stuff back to RB and had to go to Amex to get a full refund on the kit. Maybe their rotors were OK but their pads were crap. Brake pads should last more than a day at the track. I went back to the CCB's... They won't be any more expensive than changing out the RB pads every single track day all season long... (Or as much as a PITA...) CCB's are expensive but at least they are reliable! The M3/M4 is a pretty heavy car and front brake cooling is a real challenge. INd is going to work with Fall Line this winter to see if they can design a proper brake cooling kit for the car (one which does NOT use CF for brake shields). The other challenge is getting enough air to the front brakes and I'm told (by a German BMW Engineer) that you can't really move enough air through the coolers in the front fender wells - you need dedicated scoops. I've asked if they could make some easily detachable, very thin scoops for mounting under the front lip which could be removed when NOT at the track (for clearance). I'm also planning to mount an AP brake kit this winter to see how well it performs/lasts. However, the CCB brakes have been the best solution I've found so far!
09-19-2017, 08:06 PM | #127 | |
1421
Rep 2,561
The nice thing about Carbotech is they will put any compound on any size backing plate. You can order exactly what you want at no extra cost. So if the CCB pad size that fits the stock caliper does not have many off the shelf alternatives from Hawk or others, then you can go to Carbotech and have a set made. My rear pads are about 50% worn after 11 track days - XP8. The fronts are getting about 7 days per set - XP10. In any event glad the CCBs are working out for you. Maybe we'll run into each other at Road America. |
09-20-2017, 09:26 AM | #128 | |
1117
Rep 1,904
The RB kit was supposed to be convenient and affordable because it let you use the existing CCB calipers. The problem is finding ANY metallic pads to fit a CCB caliper - so that sort of marries you to the RB pads if you use their kit. (However, I was told that the F8X CCB calipers can use pads for 2016 M5 std calipers on the front and 2010 Audi R8's on the rear but after the utter failure of the RB kit I was in no mood to start any experimentation...) The other problem with the RB kit (pads specifically IMHO) is that the circumference of the "holes" in the brake pad backing plate crossed directly under the circumference of 2 of the 3 pistons on the front calipers. This means that fully half the circumference on 2 of the 3 pistons was pressing down over an area on the pads with no metal backing plate underneath. In fact, after removing these day-old pads, that went metal-on-metal, it was easy to see that the backing plates actually bent and twisted in these specific areas as might be expected. In any case - I was done with this "solution".... So, yeah, I'm going to try a proper AP kit when the car is pulled off the track for the season and see how that goes. I REALLY, REALLY, like the CCB's on the track. They have great initial bite, completely linear modulation, and virtually no fade. But they are expensive! At some point, however, it becomes necessary to ask how much am I willing to spend, and how much time am I willing to invest, in finding a less expensive comparable solution? Save money no matter what it costs? ;-) Let me know if you ever get down to AutoBahn CC!
09-20-2017, 06:35 PM | #129 |
1421
Rep 2,561
I'm at Autobahn CC too! Next event for me this year is Road Atlanta in November.
10-02-2017, 01:04 PM | #130 |
1117
Rep 1,904
BTW - Here are some photos of the major RacingBrake CCB Retrofit Kit Failure!
This is what happens when you package substandard pads with a kit. The folks at RB seem to think its fine to put void space (a hole) under a portion of the contact area for the caliper piston rims. The CCB Caliper piston rims land right over a couple of large holes in their backing plates. Not only did their brake pads completely fail in just over a single track day and send my car into the weeds, but you can see how the backing plate buckled right where the holes were. It should be noted that they would not give me a full refund for this piece of crap (I had to go through Amex), but I also found out this weekend that it also ruined my stock CCB rotors! (Another $3K!). I was seeing some very uneven wear in the front pads and when I pulled the pads to replace them, this is what I saw. The piston you see in the picture mushroomed where the limited contact area was and then left a tooth where the void space was. Not only did this ruin the pistons, but it also ovated the piston bore in the caliper as the pressure was not evenly balanced over the rim of the piston. Who designs crap like this? Am I the only one who thinks you should have a solid contact surface below the ENTIRE Circumference of your caliper pistons? (Apparently not, as the BMW CCB pads don't have this issue...)_ This kit was crap! Buyer beware!
10-02-2017, 02:53 PM | #131 | |
21132
Rep 20,742
It really seems like this kit is poorly engineered .
10-02-2017, 05:07 PM | #132 |
1117
Rep 1,904
Yup! No doubt about it! Trash! Who "designs" brake pads like that? ...and they only last ONE full track day before the pads completely wore away. (I actually waited an extra 6 weeks for their "Track" pads!)
(I have LOTS of photos of their failed kit if anyone needs more evidence!) RacingBrake wouldn't even refund the full price of their kit! I guess there was a little wear and tear on their rotors (No kidding!). Luckily Amex covered the balance of the original kit cost. But now I'm out the cost of the two CCB rotors that their kit effectively destroyed. I think that's about another $3000 out of pocket for me... Lousy Product, Bad Company! Anyway, I'm now onto a full set of Front/Rear Essex/AP Radi-CAL Brake Rotors/Calipers/Pads. All that should be here in a couple of weeks when I get back in Country. Once I get the AP kits installed, I'll get on the bench replacing/rebuilding my OEM CCB Calipers... I know I'm going to need at least one new caliper, maybe two...
