04-06-2024, 08:27 PM | #1233 |
Rep 3
New to BMWs and about to pull the trigger on a 2014 X5 (F15). It drove straight and seemed to handle well, but squeaks going over speed bumps. It has 91,000 miles and the dealer (not BMW) has replaced the tires and aligned the vehicle. From what I am reading, the noises could be from the control arms or the “thrust” arms. Knowing this to be the case, should I try to get the dealer to knock more money off the price? Right now he’s asking $14,500…all opinions appreciated! Thanks!
04-24-2024, 08:49 PM | #1234 |
Rep 1
Hey Guys,
New here, just bought a 2017 x5 35i Drive but noticed the daytime running light was out. I looked under the hood and seem to be missing the module. Does it anyone where I can find the daytime running light module? |
04-24-2024, 11:33 PM | #1235 | |
Rep 5
Drives: F15 - 2018 BMW X5 35d - Stock
04-25-2024, 09:51 AM | #1236 |
2414
Rep 2,671
Rear air suspension sagging when parked in incline. $4000+ to fix at dealer. Covered by BMW extended warranty. That repair alone is more than how much I paid for my CPO Wrap warranty! It would have really sucked to pay that much out of pocket. 2018 50i with 50K miles...
04-30-2024, 11:42 AM | #1237 |
Sing your death song!
Rep 9
Drives: 2015 X5 xD35d | 2003 MB ML500
Howdy!
I haven't been on this site much since registering but I could use a little help. 2015 x5 35d mechatronics sleeve/gasket kit Do those exist for the 8hp transmission? The attached image file is a kit for a ZF 6HP transmission. I presumed there would be such a kit for an 8HP transmission. Thanks much! |
05-02-2024, 11:35 PM | #1238 |
Rep 13
Could use some guidance on what to look for:
Getting chassis Malfunction upon start up and multiple times thereafter. Somedays not at all. ISTA codes relate to the icm ride height and headlight beam throw (see pic) Is this a battery issue? do I need an ICM? what do I look for? I'm new to using ISTA. thanks in advance ! |
05-12-2024, 06:35 PM | #1239 |
Rep 1
F15 crank no start
What's up Bimmers, I recently made the mistake of jumping my E36 with my F15 and it killed it. She cranks but doesn't start. I just wanted to know if anyone knows if its a burnt relay or if I actually fried my computers.
Any information and options are appreciated |
05-14-2024, 01:11 PM | #1240 | |
1062
Rep 2,529
05-17-2024, 11:26 PM | #1241 |
Rep 4
Nbtevo_q update to nbtevo_y
I did iStep firmware flash today to update NBTevo_q to Y. Flshing went without a problem but my idrive is still at the old iStep version and NBTevo changed to Y. Is it because I did not select the VCM update in the E-sys option before starting Tal-Execution?
Is there any way I can force the Flash/update iStep? Thanks |
05-22-2024, 12:56 PM | #1243 |
cals
17
Rep 36
A/C Warm on Driver Side
Got the car during winter so truly testing using A/C until now
At lowest setting, 16C (60F), A/C blows Cold on Passenger Side but noticeably warmer on Driver side, both in Max A/C and /AC -vent dial setting are in cold (both sides) I had this issue on my e70 -but reversed, it was warm on Passenger- and ended up being due low refrigerant, however, as it was (and is) supposed to be a closed system so a leak was the true culprit. No codes present, already searched the forum but not many results Any other areas I should look at? |
05-22-2024, 12:59 PM | #1244 | |
cals
17
Rep 36
