03-21-2024, 10:13 AM | #1167 | |
14
Rep 43
HotRodM4694.00 |
03-21-2024, 10:36 AM | #1169 |
14
Rep 43
03-21-2024, 10:41 AM | #1170 | |
694
Rep 608
The pic is my front wheel specs at 265/30-20. You can see my front wheel is 26.3 inches in diameter. So try your front wheel specs to get a better idea : https://www.calculator.net/tire-size-calculator.html
?18 M4 Comp
ItsPapa13.50 |
03-21-2024, 02:08 PM | #1171 | |
2485
Rep 5,974
So why was the RR toe adjusted so far in the toe-out direction? RR camber was barely touched and there should’ve been more adjustment in available camber. It seems they had no plan to adjust LR and RR specs to match. The RR camber should have been made more negative to match the LR. RR toe should’ve been made slightly more positive or not adjusted at all and had the LR toe adjusted to match RR toe. Why was RR toe adjusted to toe-out while the LR toe was adjusted to be more toed-in than RR? RR toe was adjusted the wrong way. LR toe adjustment should’ve stopped at +0.10 deg to match RR but went to +0.14 deg? RR camber should’ve been increased to better match LR camber or RR made more negative and LR made less negative to match at -1.8 deg. The RR adjustments don’t make sense (toe should have been increased or left alone but was almost made it toe-out, camber adjusted more negative which it was but by only 0.1 deg). Did you discuss with them target values you wanted for camber and toe? The results suggest there’s likely a bent suspension arm on the RR. Throwing adjustable suspension arms at the car may allow you to align your car to spec values but you could be masking a problem at the same time. |
03-21-2024, 04:05 PM | #1172 | |
14
Rep 43
03-22-2024, 08:30 AM | #1174 |
14
Rep 43
Sorry I forgot to ask earlier, where did you order the Euro Springs from? I've read that tunershop.com is a legit site but wanted to see where you got yours from since you just did it
03-22-2024, 08:40 AM | #1175 | |
694
Rep 608
?18 M4 Comp
03-22-2024, 09:12 AM | #1176 | |
14
Rep 43
I know there's been multiple different names for these springs (Euro, V1 etc) but this is the article number you got, correct? E10-20-031-09-22 (https://www.tunershop.shop/eibach-pr...e-f32-f82.html) |
HotRodM4694.00 |
