Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > F30 Performance brakes in E92 335i
      05-30-2015, 06:35 AM   #89
Tommix
Tommix's Avatar
Finland
42
Drives: F82 M4
Now the car looks like this:
In the front, yes there is some space
530e xDrive LCI and DCT, MHD Stage 2+ E30, xHP Stage 3, catless DP:s, NGK F8S
Previous: F20 M135 AWD AT 445 bhp, E93 335iA 450 bhp, E92 335iA 650 bhp, E60 535DA, E61 535DA, E34 530iA
      05-30-2015, 07:50 AM   #90
Jacblack
91
Drives: F80 COMP
What's the average price people are paying for these, when I looked them up, they almost cost as much as the stop tech bbk
      05-30-2015, 08:52 AM   #91
feuer
feuer's Avatar
4277
Drives: wife crazy!
$2k, for front and rear that is!
      05-30-2015, 08:57 AM   #92
feuer
feuer's Avatar
4277
Drives: wife crazy!
Originally Posted by Fundguy1 View Post
Anyone figure out if the front 6 piston M versions fit or not? I have 19" wheels as does the M4. Thx.
calipers yes, rotors no. because the nub is different on the new M3/4
for example:
f30 4 pot uses 370mm
f80 6 pot uses 380mm
same caliper that is, so that tell you that f80 hub mounting tabs are 5mm further away from the center.
      05-30-2015, 09:04 AM   #93
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
So the M3/4 6 pot caliper with rhe 435 rotor works then? Where's best supply of parts?
      05-30-2015, 09:06 AM   #94
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
If so yjsts my BBK.
      05-30-2015, 10:05 AM   #95
feuer
feuer's Avatar
4277
Drives: wife crazy!
No
      05-30-2015, 10:09 AM   #96
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
OK. So only the 4 pot standard f30 front brake? If this is the case would it be better than e9x m3 but not as good as BBK for example? Kind of like an in between standard and BBK option in terms of braking power and cost?
      05-30-2015, 06:30 PM   #97
feuer
feuer's Avatar
4277
Drives: wife crazy!
Q
BBK=big brake kit
Standard f30 4 pot 340mm
Standard e90 335i 1 pot 345mm
Snandard e90 m3 1 pot 355mm
f30 4 pot performance & sport 4 pot 370mm
So to answer your question f30 370mm is BBK to e90 335i 345mm and all e90 brakes for that matter.
Is absolutely better than any stock e90 brakes.
In term of cost yes, is between, but performance wise is similar to all other BBK.
      05-30-2015, 06:32 PM   #98
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
Perfect. Thx. A discount BBK. I guess rotor size is the critical thing here vs number of pots. 6 for BBK and 4 for F30.
      05-30-2015, 06:38 PM   #99
feuer
feuer's Avatar
4277
Drives: wife crazy!
Buy the front since the rears don't do much braking any how and install e90 m3 master cylinder. You wil be happy. Even with stock OEM pads can do similar to track ready stock e90 345mm brakes because of its size. 370mm is very close to 380mm from f80, caliper is the same and that tell you enough.
      05-30-2015, 06:55 PM   #100
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
Yeah. Not worried about the rears. Just going to paint them the same. Front is about 80% of braking. Also not tracking it but want a little more power and heat shedding for hard street driving with the extra power. I had a corvette get overheated and horrible brake fade once doing 110 mph. Once. Upgraded it next weekend.
      05-31-2015, 02:14 AM   #101
Tommix
Tommix's Avatar
Finland
42
Drives: F82 M4
You mean part no. 01?
http://www.realoem.com/bmw/enUS/show...diagId=34_1483
And it fits plug'n play?
      05-31-2015, 07:38 AM   #102
andrey_gta
andrey_gta's Avatar
301
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
+1. Do we need the entire assembly with resevoir and the black cylinder or just the Master brake cylinder item 34312283533
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      05-31-2015, 10:40 AM   #103
feuer
feuer's Avatar
4277
Drives: wife crazy!
Yes, just the cylinder, the resevoir and the booster (black drum) are the same.
      05-31-2015, 10:45 AM   #104
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
Cool. Get the cylinder and a new one ring I guess then.
      05-31-2015, 12:42 PM   #105
andrey_gta
andrey_gta's Avatar
301
Thank you!! I am greatful for the help.
One last question. The masterCyl are sometimes sold without the metal stick peace with one loop end and another end that connects to the Master Brake(I think this is the solenoid). This item goes into the black Booster cylinder.
Hope you help me understand, Your the type of resource this forum needs. Someone who is not afraid to experiment
      05-31-2015, 01:05 PM   #106
Fundguy1
Fundguy1's Avatar
2036
Drives: 335 e93
And do you have the largest caliper and rotor part numbers that will fit? Is there any choice in color? The orange looks hot but blue is also cool too.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
      05-31-2015, 01:13 PM   #107
Wlodi
Wlodi's Avatar
Poland
28
Drives: G16 840d xDrive
Will the new Master Cyl solve the "soft pedal" issue??? Any coding needed?
Do we need E90 M3 MasterCylinder or any e9x M3 Master Cylinder?
      05-31-2015, 01:38 PM   #108
Tommix
Tommix's Avatar
Finland
42
Drives: F82 M4
Originally Posted by Wlodi View Post
Is it ?
What rim type?
I think it's same:
http://www.realoem.com/bmw/enUS/part...&q=34312283533
      05-31-2015, 01:39 PM   #109
Wlodi
Wlodi's Avatar
Poland
28
E93 with 397 OEM Wheels
      05-31-2015, 01:55 PM   #110
Tommix
Tommix's Avatar
Finland
42
Drives: F82 M4
Thank you
No spacer needed?
