F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
ARMA SPEED
      12-25-2015, 11:22 AM   #89
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
Originally Posted by SoCalDave
I'm running square 225/45/18 397s. Can I run a 255 on the 18x8" wheel in the rear without issues and mix it with 245s in the front without messing up the speedometer?
thanks!
I wouldn't recomend a 255 on a 8" wide wheel.
245 square will be a good fitment!
      12-25-2015, 11:24 AM   #90
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
Originally Posted by Sbatty
I'm wondering what ET means in relation to wheel offset?
ET and wheel offset is the same.
BMW also use IS for offset on OEM wheels.
      12-31-2015, 02:39 PM   #91
Sbatty
Drives: 2013 328xi
Thanks .BMW.
So ET35 would simply mean 35mm of positive offset.
So what's the foolproof 19" staggered setup for stock xDrive? No rubbing, no spacers etc.
      12-31-2015, 05:59 PM   #92
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
Correct.
A good fitment would be:
F: 8.5x19" ET32-35
R: 9.5x19" ET40-45
      01-03-2016, 09:39 PM   #93
Sbatty
Drives: 2013 328xi
Correct.
F: 8.5x19" ET32-35
R: 9.5x19" ET40-45
Thanks for the good information!
      01-09-2016, 08:56 AM   #94
Sbatty
Drives: 2013 328xi
I guess the other half of the equation is tires, so for those wheels what tire combo clears everything and fills up the wheel wells nicely? Any one have pics of such setup on their car?
      01-09-2016, 09:36 AM   #95
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
F: 8.5x19", 235/40-19 (2% taller than OEM)
R: 9.5x19", 275/35-19 (2% taller than OEM)
or
F: 8.5x19", 235/35-19 (2% shorter than OEM)
R: 9.5x19", 275/30-19 (2% shorter than OEM)
Both setups have matched front and rear diameters which is important with xDrive.
I would probably have picked the first option, with higher profile tires. It fills the wheel wells a bit better on your xDrive.
      01-09-2016, 02:12 PM   #96
lacrimarum
lacrimarum's Avatar
Russia
68
Drives: 2015 F30 320xi lci
Hello!
I want to replace the rims for a set of winter tyres (205/60R16) on my 320i xdrive. Therefore i'd like to know an offset on oem 16*7 rims and possible variation in this parameter.
Thanks in advance!
      01-09-2016, 02:22 PM   #97
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
OEM 16" for F30:
7x16" ET31
For aftermarket wheels you can look for ET 20-30.
      01-09-2016, 02:37 PM   #98
lacrimarum
lacrimarum's Avatar
Russia
68
OEM 16" for F30:
7x16" ET31
Thank you very much!
      01-16-2016, 11:01 AM   #99
Bosspeed
Drives: BMW 328i m-sport
Offset et 30/35?
Hi guys
I want to buy Breyton CS wheels for my F30 335i msport
19x8.5 et 30 front / tires 223/40
19x9.5 et 35 rear / tires 255/35
Will they fit or they will rub?
Thanks
      01-28-2016, 12:32 PM   #100
nlopes
Drives: BMW 320d F31
Wheel upgrade from 16" to 18"
Hi guys
I would like an opinion.
I recently bought M437 replicas for my BMW 320d 184hp F31, and the factory settings says the measures should be 18x8" ET34, BUT the replicas I bought are 18x8" ET30.
Will these be ok to ride on as the offset is different positioning the wheel outwards and extra 4mm?
Does this not put any extra pressure on all the components compromising security of the veicle?
Thanks for your help guys!
      01-28-2016, 08:43 PM   #101
nlopes
or
Hi there
Thanks for your help!
      01-29-2016, 03:39 AM   #102
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
4mm is nothing to worry about!
Many members here run 10 or 12mm spacers on the OEM front wheels.
      02-01-2016, 05:36 PM   #103
nlopes
Thanks for your help.
Already have the rims and just waiting for the car to arrive.
Thanks again
      02-18-2016, 08:04 AM   #104
coldfyre22
Drives: 2013 335i MSport EBII
I have a 2013 335i M-Sport with the staggered 400M wheel setup. Its time to replace the Pirelli RFT's. I want to go wider and non RFT.
Does anyone know what's the widest tires I can put on these wheels?
Thanks!
      02-26-2016, 09:32 AM   #105
Polo08816
1616
Drives: 2014 335i M Sport
Thanks!
Widest on front is probably a 245.
Widest on rear is the OE size which is 255.
      03-12-2016, 12:36 AM   #106
paperplanes415
paperplanes415's Avatar
No_Country
13
Drives: 2021 M8 GC
whats the offset of the 400m's for 2015 328Xi M Sport Wagon? my tires are 225/45/18 all around need to know cause I need to buy 2 wheels that where bent.
      03-12-2016, 03:57 AM   #107
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
8x18" ET34
      03-15-2016, 04:57 PM   #108
K320
Puerto Rico
132
Drives: G01-X3 30i MSport
so for 18" Double Spoke Style 397 (Sport Line wheels) - 18x8" ET34 recommended max width is 245/40/18?
Why tirerack show optional size like 225/45/18 front and 255/40/18 rear?
Can it be 225/45/18 front and 245/40/18 rear?
      03-16-2016, 01:19 AM   #109
.BMW.
.BMW.'s Avatar
Sweden
1865
Drives: BMW F11/F31
225/45-18 front and 255/40-18 rear is the OEM staggered tire sizes for F30.
But since style 397 are square wheels, 225/45-18 is the OEM size (both front and rear). 245/40-18 square will fit fine as well.
      03-23-2016, 09:06 PM   #110
RedKloud
RedKloud's Avatar
741
Drives: BMW i4 M50
I have 407 wheels on my 340i, 19x8 front and 19x8.5 rear. Can I put 245/40-19 tires both front and rear?
Tags
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
f30post
