03-01-2012, 01:05 PM | #89 | |
689
Rep 6,845
Drives: 2018 Audi RS5 coupe
that means you are only getting one channel worth of input double check the 4 wires going into the plug
03-01-2012, 01:08 PM | #90 |
BimmerPost Supporting Vendor
308
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
03-01-2012, 01:56 PM | #91 |
2312
Rep 13,023
03-01-2012, 02:02 PM | #92 |
308
Rep 13,093
03-02-2012, 08:35 PM | #94 |
You got my money?
3244
Rep 4,711
Drives: Ice Cream Truck
Great! Now my subs are down on power and sound like crap! Sounded fine and now the bass is just gone. Sounds distorted too. Not happy. I suspect it's the lc2i.
Joy!
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
03-04-2012, 07:22 PM | #95 | |
308
Rep 13,093
The question that has also continually come up in my mind in addition to a component issue is that since we have to use speaker level inputs is that any changes we make on the equalizer and tone settings in the iDrive affects the signal going to the LC2i. What bothers me about this is that whatever signal is being fed to the oem subs are being fed to the LC2i. So if we increase bass at all via iDrive either with the bass setting or eq settings, we are therefore altering the signal to the LC2i. I am not sure how this plays out once we start changing the settings on both the LC2i and whatever amp you use. I am wondering if we are effectively filtering the signal twice which could then effect the output we are getting. All-in-all, everything works ok now but not exactly to my satisfaction. I am still not happy as to how much I have had to turn the gains up. ILSMKU, if you are free this week, maybe we can get together and troubleshoot things. |
03-05-2012, 12:01 AM | #96 |
You got my money?
3244
Rep 4,711
I got some help from Technic and for me, turning the threshold dial from OFF to full blast and back worked!!!
Now let's see if it holds steady. Im pretty sure they slowly lost power last time. I'll monitor and report back. Tech I'll hit you up on PM. Thank you Technic.
03-05-2012, 08:02 AM | #97 | |
2312
Rep 13,023
The main reason of the LC2i with the EPS system OEM amp is its capacity to withstand 40V peaks at its inputs. Your OEM amp woofer outputs are capable of peaks in the 30V range.
This is what could happen with a passive LOC in the long term even when it is custom-build to withstand 30V: I retired that LOC more than a year ago and moved to the LC2i just for this particualr reason. My suggestion is: - set AccuBASS gain to minimum - set AccuBASS threashold to fully clockwise That should give you "normal" bass. I do not like any of the Audiocontrol bass manipulation circuits (Epicenter and now AccuBASS) because they do not serve any purpose in our BMW. Actually, they cause problems like the one you are experiencing. And after doing this adjustment you will notice why: the AccuBASS seems to be adjusting itself after time, getting to the point of attenuating all the bass. This is quite difficult to find out under testing as I do not test devices for days, less so for weeks to catch up crap like this. By setting the threashold to max -according to Audiocontrol- the bass level is "locked" and no AccuBASS effect is applied. Quite confusing but that's Audiocontrol. Quote:
03-05-2012, 09:28 AM | #98 | |
308
Rep 13,093
Unfortunately for me, the AccuBASS threshold was already at full clockwise and the AccuBASS gain was already at full counterclockwise. What about my mention of the signals coming from the OEM in the first place? If the signals being sent to the OEM subs are already being filtered by the iDrive either via the Bass setting or the EQ, do we need to compensate somehow when adjusting the settings on the amp for the aftermarket sub? Is there a higher end unit than the LC2i even if it's made by another company? On the LC2i, I am currently using the Main Output for the RCAs since the sound increased when I swapped between using the Bass Output and the Main Output. Is this what you suggest? |
03-05-2012, 10:28 AM | #99 | |
You got my money?
3244
Rep 4,711
Well that didnt last long! Got in my car this morning and bass was totally missing. I pulled over, pulled an RCA out and back in, it kicked in a little bit. but nothing close to what it was the day before. I then checked the LC2i and guess what... its smells funny. Like burnt electronics. WONDERFUL JOY!
03-05-2012, 10:40 AM | #100 | |
308
Rep 13,093
03-05-2012, 10:45 AM | #101 | |
2312
Rep 13,023
The OEM amp output signals are being split between the underseat woofers and the LC2i. Therefore any iDrive bass adjustment will affect both paths. That's the way it works regardless of the LOC used in any sub install just because of the signal split. |
03-05-2012, 10:46 AM | #102 |
308
Rep 13,093
A quick searched netted the Audison bit one. Not sure if that will work for us or not. Looks like a much nicer unit though.
03-05-2012, 10:49 AM | #103 | |
308
Rep 13,093
I will try the Bass Output per your suggestion. Does this mean that I need to use the Main knob or Bass knob to make my adjustments? |
03-05-2012, 10:54 AM | #104 | |
2312
Rep 13,023
The only units that I know can withstand 40V are... Audiocontrol. |
03-05-2012, 10:59 AM | #105 | |
2312
Rep 13,023
http://www.m3post.com/forums/showpos...3&postcount=74 |
03-05-2012, 11:05 AM | #106 | |
308
Rep 13,093
Seems like the mobridge DA1000 is the ticket. Last edited by THE TECH; 03-05-2012 at 11:14 AM.. |
03-05-2012, 12:07 PM | #107 | |
2312
Rep 13,023
03-05-2012, 12:09 PM | #108 | |
308
Rep 13,093
03-05-2012, 02:03 PM | #109 |
2312
Rep 13,023
03-05-2012, 02:20 PM | #110 |
308
Rep 13,093
So you are saying that for the same $700 instead of buying the mobridge that it would just buy the aftermarket amps? Or am I confused?
