06-29-2020, 04:07 PM | #89 | |
939
Rep 4,329
Drives: M340
Very very impressive work all around. This should be documented for future reference. Can you please share the details of your wiring as well? Thanks again!
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
07-02-2020, 08:31 PM | #90 |
373
Rep 464
My Euro light switch arrived today and now my Euro tail lights are fully functional.
Re wiring details, the wiring was pretty straight forward with most of the time required to remove/reinstall trim pieces to run 1 wire from the inner left tail light along the side of the vehicle to the front passenger footwell, where the BDC_BODY is located. You will need: 1) 1 X .35mm dia. wire (I used 20 AWG) approximately 20 feet long 2) 2 x connector pins (61138369696) or repair wires 3) 1 X Euro light switch with rear fog button (61319461141 or 61319461142) Wiring Details: 1) Remove the the trunk lid liner - https://www.newtis.info/tisv2/a/en/g...ter/1VncxwUczG 2) Assemble 1 of the connector pins to one-end of the .35 mm dia. wire and insert pin into position 6 of the inner tail light connector. Note the connector has a pin locking mechanism that must be released (flipped-up) before the pin can be fully inserted. 3) Route the wire from the rear inner tail light to the BDC_BODY, following the OEM wiring harness in the trunk lid and along the right side of the vehicle: i) Behind the right-side trunk panel - https://www.newtis.info/tisv2/a/en/g...als/1Vne3omLMM ii) Under the rear and front right-side door sill covers to the BDC_BODY in the front passenger footwell: - https://www.newtis.info/tisv2/a/en/g...nel/1Vne2z9CVU - https://www.newtis.info/tisv2/a/en/g...les/1VndrMi9O6 4) Measure the length of wire to the BDC_BODY connector (be generous) and cut-off any excess. Assemble the 2nd connector pin onto the wire-end. Insert the pin into the appropriate BDC_BODY connector/pin location. For my vehicle, the fog wire was inserted into pin 20 of connector A258*5B - https://www.newtis.info/tisv2/a/en/g...hts/1VnchjSa6D 5) Replace NA with Euro light switch. I did not follow the instructions provided since I was having difficulty unclipping the side panel - https://www.newtis.info/tisv2/a/en/g...sor/1Vndt4O7on. I was afraid I was going to break a clip or the panel itself. Instead, I removed the storage compartment below the light switch - https://www.newtis.info/tisv2/a/en/g...les/1Vne2HKUCV to access the spring clips on the back-side of the light switch. 6) FDL Code BDC_BODY --> CAFD 7083--> LCE_BEL_LIN_VAR --> 30_BEL_PL_FLC_NSL (rear fog only) or 34_BEL_PL_FLC_NSW_NSL (font and rear fogs). This coding is not essential since the switch will operate properly. ISTA+ will just report a BDC_BODY error until coded. Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold Last edited by larrylam646; 07-02-2020 at 08:52 PM.. |
07-02-2020, 09:26 PM | #91 |
Luxury at the redline :)
9108
Rep 7,563
07-03-2020, 02:51 AM | #92 |
307
Rep 572
Drives: BMW G20 330i X-Drive M-Sport
larrylam646 Amazing write-up!
Want to fly to the Netherlands to do this for me? I'm scared to do this to my brand new car... Popping out trim pieces and getting everything to go back properly has been nemesis over the years. To clarify, there's only one bit of coding that needs done? |
07-03-2020, 04:38 AM | #93 |
373
Rep 464
I wired up only one output of the BDC_BODY since the Euro taillights only have one fog light, on the driver's side. The schematic shows two connections, one each for LHD and RHD vehicles.
Larry
2014 Estoril Blue 435iX - sold |
Poochie9107.50 |
07-03-2020, 05:15 AM | #94 | ||
373
Rep 464
If your vehicle was manufactured for the European market, I am surprised it did not already come with a functioning rear fog lamp. Larry
07-03-2020, 06:26 AM | #95 |
307
Rep 572
Thanks again... Just picked the car up the other day.
My car is US-spec as I'm not an EU citizen and I plan on bringing this car back to the US with me in a few years. Technically I don't have to change the tails, but I'm not a big fan of the red turn signals and lack of rear fog. My Tennessee built VW Atlas has proper tail lights FFS. |
07-03-2020, 01:27 PM | #96 | |
9108
Rep 7,563
I prefer the symmetry of two lights burning, simultaneously but that's just me. Regardless, thanks a lot for your contribution to the subject |
07-07-2020, 06:59 PM | #97 | |
939
Rep 4,329
Drives: M340
Only if I can get the turn signals to function properly. The rest seems easy but a bit PIA based on what it used to take to do this mod. Everything was plug and play F and previous generation cars. Heck for most cars, all we had to do was to get rear fog switch in the and the rest was plug and play.
Poochie9107.50 |
07-07-2020, 10:17 PM | #98 | ||
9108
Rep 7,563
Now, I just have to figure out where in the ROW has left and where might have the right taillight, with the required inner rear fog lights LED clusters. I was told today that Mexican-spec vehicles comes with rear fog lights standard and uses the Euro-style taillights, so that's now an option also and might be easiest to source, one would assume.. And yes, on the F-Series generation, it was a cakewalk to do this mod. I did so may mods similar to this, it kind of spoiled me. My M2 doesn't even come with front fogs but I had coded the front fog button to toggle-control the US Side Markers, on cue.. So cool but the G-Generation adds so much complications, I'm seeing it's not going to be that easy again.. Front Fog Light Mod https://f87.bimmerpost.com/forums/sh....php?t=1646587 https://www.bimmerpost.com/forums/sh...php?p=23962722 Thanks to @Larry for at least giving us a glimmer of hope, by being the first to take the plunge, retrofitting the wiring. |
07-12-2020, 02:56 AM | #99 | |
30
Rep 27
Drives: 2020 330xi
I would really like to do this. I mess around a little with BimmerCode but this is over my head and can't find many of the parameters you mention. Can this be done via BimmerCode or remote coding? Thanks for all the awesome info. Very nice of you to take the time to do this. |
07-12-2020, 10:11 AM | #100 | |
373
Rep 464
I am sure it can be remote coded. Perhaps reach-out to one of the members that offer remote coding as a service.
07-12-2020, 10:26 AM | #101 | |
373
Rep 464
Complete set on ebay that appear to have fogs in both inners - https://www.ebay.ca/itm/BMW-3-SERIES...wAAOSw93pe-wgZ FYI, you will need to code BDC_BODY so that both left and right rear fogs wires are energized ie. both rear fog solid-state relays (transistors) are turned on. A quick analysis suggest modifying the werte for CAFD 5665 LIC_NIVEAU_OVERRIDE_INDEX
2014 Estoril Blue 435iX - sold Last edited by larrylam646; 07-12-2020 at 10:38 AM.. |
Poochie9107.50 |
07-13-2020, 07:42 PM | #102 |
346
Rep 751
When you swapped to the ECE headlight switch, did it look like the US blanks would be easy to pop out like on the E/F series? I'd love to mod them for some custom hidden functions.
07-13-2020, 07:57 PM | #103 |
373
Rep 464
First thing I did after I installed the ECE tail lights was to see if I could modify the NA light switch. The G20 light switch does not have blanks that can be popped out so not possible.
siegester346.00 BigMofoFrog187.50 |
07-21-2020, 07:14 AM | #104 | |
307
Rep 572
I'd hate to go through all the hassle with ESYS just for this. |
08-21-2020, 09:26 PM | #105 |
Rep 11
08-22-2020, 01:16 PM | #106 |
Rep 3
Hi Folks,
Is anyone here familiar with the rear outer tail light on the 340I? I have a faulty signal. I've removed the housing but can see an obvious way to replace the bulbs? Does anyone know? Link to the part below https://www.carparts.com/details/BMW...E&gclsrc=aw.ds |
10-19-2020, 09:08 PM | #109 | |
939
Rep 4,329
Drives: M340
Bumping this up to see if anyone has been sucessful with either remote coding or with Bimmer code. (I wonder if Bimmercode updated their software to make necessary changes) The way the tails function is pretty much the only thing I hate on this car.
helmet91306.50 |
10-20-2020, 02:57 PM | #110 | |
Rep 22
I've tried UNK_PARAM_28. The result was stop lights off with blinkers, but get hyper flashing Then I've tested UNK_PARAM_22, result: stop light no blinking, no hyper flash, but only outer lamps works So I'm still looking... |
