BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > My CIC Combox 6FL retrofit log (and DIY focused on coding)
      03-16-2020, 11:15 AM   #89
SlimE92
SlimE92's Avatar
No_Country
186
Drives: E92 N54
Originally Posted by derbo View Post
I have the kremersino unit for Apple CarPlay.
Whats the audio connection between the unit and the vehicle? The ones I've seen are going over the aux connection.
The original unit I used was AUX and an external mic. The latest one they sell uses the combox Bluetooth audio for streaming and utilizes the factory BT for OE mic use. It's still a little wonky but they are confident they will be able to fix it in an update. They are from Shenzhen so the corona virus kinda halted them.
Originally Posted by FaxData View Post
I've read your thread, looks very interesting! Worth the price though?
It's about $300-$400 for the module. I had to upgrade to combox too so add another $200-250 for parts and your awesome guide.
My goal was to have somewhat an OE like Apple CarPlay feel. It is very close to what it is like in my Honda Civic and I'm happy I don't have to have an android unit screen replacement just for Apple CarPlay.
Interesting..
If the audio gets routed through the combox rather than the aux port, then I will definitely pick one of these up for the car play.
Let's see how it evolves.
      03-17-2020, 12:19 PM   #90
FaxData
98
Drives: 2017 330e (F30)
How seamless is the audio setup? Do you have to connect to CarPlay then switch the audio output on the phone manually?
      03-27-2020, 01:21 AM   #91
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
Sometimes it switches correctly. Other times it doesn't and you manually have to switch it. They fixed the nbt version so it's a matter of time I hope.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      03-27-2020, 02:17 PM   #92
FaxData
98
Gotcha. I also worry about not having a rear view camera, although maybe I could piggyback two units (rear view and CarPlay).
      03-29-2020, 03:20 AM   #93
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
The module can accept rear view camera directly or work with the diy OEM camera module. My brothers 335d has OEM style camera with a working CarPlay module.
IG:ruhrohz_m3
Journal: Link
      03-29-2020, 04:09 PM   #94
FaxData
98
Nice! Maybe this’ll be a project for when the pandemic dies down.
Appreciate 2
derbo3612.50
SlimE92185.50
      04-01-2020, 02:23 PM   #95
SlimE92
SlimE92's Avatar
No_Country
186
Drives: E92 N54
Report back when you do
      04-04-2020, 02:20 PM   #96
Hackintosh
Drives: E93
Hello.after cic retrofit on e93 2008 i have this problem with service.can anyone of you help me?
      04-04-2020, 06:33 PM   #97
FaxData
98
Have you default coded all the modules? Maybe the I-level of your car isn’t high enough? Has your car ever been dealer updated?
      04-05-2020, 07:12 AM   #98
Hackintosh
Drives: E93
I have not coded anything yet.i dont know about dealer update
      04-05-2020, 10:52 AM   #99
FaxData
98
Do all the coding first (at least the FA/VO default coding). Depending on what vehicle your headunit came out of, you can get some very strange behavior before coding. The unit needs to know how to behave in your car.
      05-24-2020, 11:06 AM   #100
bms5
11
Drives: 2010 335d, 2018 540d
Album art question
I’m reading conflicting posts as to whether my 2010 335d that i just retrofitted a combox media to, can show me album art over BT. My streaming works fine from my iPhone X but I’m not getting album art even when plugged in to the console Y-cable.
Awesome DIY, FaxData! Thanks for all your work.
      05-25-2020, 09:20 PM   #101
FaxData
98
Album art should come up with USB connection, although it’s been a while so I’m not sure if it requires bmw apps to work. I don’t think so though. I would try updating your combox to the latest version.
Album art isn’t available via Bluetooth at all, regardless of device. It’s just not part of the A2DP protocol.
      05-27-2020, 11:11 PM   #102
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
I noticed my combox crashes and reboots when I have the USB connection enabled with BMW apps running. I tried m laptimer and Spotify with same results. I thought it was interesting.
IG:ruhrohz_m3
Journal: Link
      05-28-2020, 10:39 PM   #103
FaxData
98
Huh, every time? I haven’t had that happen to me. I wonder if there’s something wrong with the combox itself. also, how do you know when the combox crashes? It’s not the CIC itself rebooting?
      06-05-2020, 04:47 AM   #104
Aus335iguy
Aus335iguy's Avatar
Australia
650
Drives: 2009 e92 335i MSport DCT
2009 BMW 335i  [10.00]
So today with the help of the guide I finally patched and activated.
Theres a PDF mentioned and it was more in line with my version of fstool2.
The hardest part is finding the software. The forum that used to share the links is closed to all but paying members. You can still find what you need though it is hard to be sure that the software you'll get will work.
Thanks to the OP for a great guide !
When you doppelkaplung you doppel your fun.
      08-13-2020, 08:07 AM   #105
lordchadski
Drives: BMW E93 325i Msport
Hi, noob here.
Help please!
I understand that this is primarily coding based and my issue MAY be hardware...but following instructions to fit CIC as above.
I have fitted CIC which plays radio when you switch it on, CID however is just white; NCS can see both units and CID thinks it's in an E60 despite being default coded - is this the problem or have I skipped a vital step?
What have I missed?
      08-18-2020, 07:00 PM   #106
FaxData
98
Originally Posted by lordchadski View Post
Hi, noob here.
Help please!
What have I missed?
It sounds like your screen is damaged (or possibly incompatible although I'm not sure why it woudl be). To my knowledge, in the e90 you cannot code the CID nor should it need to be coded. Also check your LVDS cable; being able to see the screen in standard tools suggests that the canbus connection is good but that doesn't mean your video signal is reaching the screen.
Also other posters on this thread (and myself) have received units with damaged connectors due to rough disassembly. It's worth inspecting all of it for signs of physical damage.
      08-20-2020, 08:52 AM   #107
lordchadski
Thanks @FaxData
Finally I won!!!
Thanks for the DIY, and the assist. CIC and Combox fitted, coded and operational.
Turns out that the CIC I bought was not 100%. Swapped out for another (£££) CIC unit and BMW logo appeared in milliseconds.
All other steps followed, VERY happy with new toy
Cheers...
      08-25-2020, 11:01 PM   #108
FaxData
98
That’s great, congrats and enjoy!
      11-15-2020, 02:58 PM   #109
vibroluxious
Drives: 2009 3281 X-Drive
Thanks For Your Detailed Retrofit Post!
FaxData, I just want to say thanks for putting all of this together in one, easy to read format.
I now have a fully functional CIC system in my non-iDrive car thanks in large part to your post.
Kudos to you!
Rich
      01-12-2021, 03:42 PM   #110
Duckyyst
Drives: e90 335d
Hi FaxData, sorry to bump an old thread. awesome write I wish I saw this before.
I have a 2007 e90 335d that had CIC and combox retro fitted before I bought it. when I bought it the navi was greyed out and voice control didn't work. the bluetooth would pair but not connect. after playing around with NCS expert the navi works but voice control and bluetooth doesn't no bt audio or calls. is it possible to have too man contradicting VO/FA codes that its confusing it? if so is there an easy way to reset the codes to factory?
Thanks again for write up
