BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Official E92 Bulb Code List
      11-20-2012, 01:13 PM   #89
CHECKERED
ex deus machina
CHECKERED's Avatar
124
Drives: G30, F15, Audi S4
Originally Posted by Kev View Post
Rear:
Turn Signals: PY21W/1156
1156 is not correct as it has opposite mounting point, the correct bulb is 7507 with offset mounting points
Daily: G30 M550i, Bluestone, JB4, 1 step colder plugs, 6WB retrofit
Winter Beast: Audi S4 4.2L V8, Supercharger, brakes, suspension & exhaust mods
Wifes': F15 M50d clone, DUDMD tune, WMI, MPBK
Gone: E92 335i N54 468rwtq
      01-17-2013, 11:01 AM   #90
nickbutterz
Drives: Coming soon
Originally Posted by noovis View Post
Can anyone please advise what bulbs to buy instead of little orange ones in the corner of E92 headlights? I want to replace them with white LED. Ideally from this store: http://www.e92-lighting.com/catalog/LED_BULBS-26-1.html since i'm gonna get more stuff from there.
Thanks a lot
This, cant seem to find it anywhere, then again idk what to call them
      02-07-2013, 10:20 AM   #91
modulate
Drives: 2010 335i, E92
Will replacing bulbs void any kind of warranty?
      02-25-2013, 08:59 AM   #92
nitehawk
nitehawk's Avatar
102
Drives: e92 335i 6MT
Originally Posted by Mrbig View Post
For a 2013 335is reverse bulbs ? which are they ?
+1 are they the same as pre-lci?
      02-25-2013, 12:28 PM   #93
E92-Lighting
E92-Lighting's Avatar
860
Drives: Next Generation LED Lighting
pre lci e92 and e92 LCI have completely different reverse light leds
      02-27-2013, 01:14 PM   #94
stroberaver
42
Drives: BMW X3 G01 M40i
Trunk: 42mm festoon
I ordered a 42mm festoon LED from ebay to try out.
Took my boot light out to swap it over, and found this. What the...
      04-04-2013, 12:34 PM   #95
mbranth38
Drives: Black 2011 335xi
Halogen vs Halo Light vs High Beam
Great post on which type of bulbs are used for each light. I was wondering if the halo is the halogen bulb or the xenon. Is that different from the high beam? I just want to make sure I don't mix my stock bulbs with LED bulbs
      04-19-2013, 02:11 PM   #96
N8N
N8N's Avatar
170
Drives: 2009 E92 335i 6MT
Hi Guys,
Had to do some research to replace a brake light on my E92 (pre-LCI) and "W16W" as you all probably know is something that you can't go into the parts store and ask for... put together a list of Sylvania part numbers that you can actually buy in the US... hope this is helpful. I just did the exterior lights but will flesh this out if I need to replace any of the interior ones.
Lighting – 2009 BMW 335i E92 coupe (pre-LCI)
Application BMW ECE Osram/Sylvania Notes
Headlight (outer – low/high beam) 63217217509 D1S D1S
Headlight (inner – cornering lamp) 63217160779 H3/55W H3/55W
Front Parking/DRL (halo ring) 7119906503 H8/35W H8/35W
Front Directional Light 63217161306 PSY 24W SV 5200S “Silver Vision”
Fog Light (Except as below) 7119906503 H8/35W H8/35W
Fog Light (with P337 or S715A) 63217160784 H11/55W H11/55W M-Sport or M-Aerodynamics
Front fender signal repeater (silver) 63217165496 Osram 2827DC "Diadem Chrome" up to 01/2010, BMW p/n discontinued
Front fender signal repeater (yellow) 63217160798 WY5W 2827
Tail Light -- -- LED
Brake Light (fender) 63217160935 W16W 921 2 bulbs each side
Rear Directional 63217176025 PY21W 7507
Rear Directional (silver) 63217160897 PY21W SV Philips 12496 “Silver Vision” or Osram 7507LDA "Diadem" or Osram 7507DC "Diadem Chrome"
Reverse 63217160935 W16W 921
CHMSL -- -- LED
License Plate -- -- LED
Rear Fog Light/Brake Light (trunk lid) 63217160788 H21W 64136
Damn German cars... seems like every time I get a new one I have to do this whenever I need to replace a bulb
As per usual the Sylvania catalog at the parts store wasn't completely accurate...
Last edited by N8N; 05-10-2013 at 03:38 PM.. Reason: added silver WY5W info & Osram PY21W diadem/diadem chrome
      04-25-2013, 12:45 PM   #97
DaanBMW
DaanBMW's Avatar
Romania
84
Drives: 2007 328i coupe
OK, there is a bit of a confusion here: the brake bulbs - the OP lists H21W, while some of the other posts including the Sylvania list above have it as W16W.
Why ? Or it is the the W16W is actually the tail light not the brake but it's too common to call it "brake", and the H21W is the correct brake bulb ?
328i Sports Pkg, Michelin PSS on Staggered 18" OZ Ultraleggeras
. BMS Powerbox. Cyba scoops + Rev motoring intake hose + charcoal delete. Wavetrac LSD
. M3: subframe bushings + sways + control arms (fr & rr). Meyle rear toe arms. M3 diff fr bushings
. BMW Perf: v2 springs + v1 dampers. Valeo SMFW+clutch. 034 MotorSport engine mounts
. Short Shifter + Turner PU bearing + ZHP M weighted shift knob. CDV delete
      04-26-2013, 02:43 PM   #98
N8N
N8N's Avatar
170
There's three brake light bulbs per side - two W16Ws in the fender, which are the normal brake lights, and one H21W in the trunk lid, which only comes on under hard braking or as a rear fog if you have enabled them. The actual tail/running lights don't use bulbs, they're LEDs.
      04-26-2013, 05:25 PM   #99
DaanBMW
DaanBMW's Avatar
Romania
84
That is very useful info, thanks ! I think this should be clarified in OP.
Is there any way w/o any ohm meters and such to test out these bulbs ? For the reg brake you can in your garage but for the hard brake ones you can't...
      04-27-2013, 09:55 AM   #100
N8N
N8N's Avatar
170
Just turn on your rear fog lights
That sounds like a smartass answer but I'm still pissed off that BMW saw fit to not allow us to use them over here, that was the first "mod" I ordered for my car, literally the first weekend after getting it.
      05-10-2013, 03:19 PM   #101
N8N
N8N's Avatar
170
Just edited post #96; apparently Osram is still making "stealth" WY5W bulbs for your repeaters even though you can no longer buy them at your local BMW dealership. The package is simply marked WY5W Diadem Chrome. Probably have to order them online, I haven't seen any in stores (but have seen equivalents from more ricer-oriented brands, but I like to stick with names like Sylvania, Osram, etc.)
      06-26-2013, 11:18 AM   #102
N8N
N8N's Avatar
170
Prompted by another thread this AM, I finished up the interior bulbs, this is again for a Pre-LCI car (2009) don't know if LCI are different.
I could not verify the rear footwell lights as I couldn't get the lenses out with my hands and my plastic trim spoons are in a very safe place (I know where they are, it's just a PITA to get to them) but I'm pretty sure those are right based on pics found on the interwebs.
Dome Light (front or rear) bulb not listed separately W6W 2886X 12V 6W XENON (same size/shape as W5W or 194)
Front Footwell Light 63217160797 W5W 2825
Rear Footwell Light (2 bulbs ea. Light) 63217169186 W2.3W 2723 T5 12V 2,3W
Puddle Light (bottom of doors) 63217160798 W5W 2825 Error in catalog? BMW p/n is incorrect for W5W bulb
Map Light (front or rear) 63217160908 W6W 2886X 12V 6W XENON (same size/shape as W5W or 194)
Dome Light or Map Light Bulb Socket 63258389736 or ECS Tuning ES# 175023 – verified by E90post user MCM (not in catalog)
Mirror Lamp (above sunvisor) 63217160912 Osram K5618 41mm Festoon 12V 10W (6411 is same bulb)
Glovebox Light bulb not listed separately C5W GE 7546F 37mm Festoon 12V 5W (6418 is same bulb)
Trunk Light 63217160912 Osram K5618 41mm Festoon 12V 10W (6411 is same bulb)
Does anyone know how to take a spreadsheet and export it to a format that will allow me to post it here as an attachment, so if you wanted to print this nicely formatted and keep it in your glovebox or owner's manual folder you could?
      06-26-2013, 02:13 PM   #103
N8N
N8N's Avatar
170
By the way if you are looking up bulbs for your car and the ECE number is listed in the owner's manual, this Wikipedia page has some of the numbers you can find in the US listed for the more common bulb types
http://en.wikipedia.org/wiki/List_of...ght_bulb_types
I added some of them myself as I've got bulb charts for three different German cars saved on my PC, as I've stated before this isn't the first time I've done this. Had I found that page (if it existed) years ago would have saved me some slogging through catalogs and reading of faint little numbers on bulb bases!
      07-10-2013, 02:09 PM   #104
E90bedi
45
Drives: 2016 F82 M4
anyone know what type of bulb the rear fog light is?
      07-10-2013, 02:41 PM   #105
N8N
N8N's Avatar
170
For pre-LCI E92 (and presumably E93 as well)
BMW 63217160788
ECE H21W
Osram/Sylvania 64136
Don't know what it would be for E90 if it is the same or not. I guess if you are trying to pick one up at the parts store look your car up on realoem and see if it uses the same BMW part no. bulb.
      07-11-2013, 08:59 AM   #106
E90bedi
45
Drives: 2016 F82 M4
BMW 63217160788
ECE H21W
alright thanks for the info. im trying to get it on a LCI e90. i just got the rear fog light mod so i wanted to change my rear fogs to LED.
      07-11-2013, 09:18 AM   #107
N8N
N8N's Avatar
170
I think this is the thread you want
http://www.e90post.com/forums/showthread.php?t=46758
What would be nice is if we could come up with a master list for all different E9xs... I could see possible differences between
E90
E91
E92/E93
then there's pre- and post-LCI
Now this is something that I'm usually good at pulling together because having worked on scads of old Studebakers I've actually cross-referenced tons of Stude factory part numbers to trade numbers or aftermarket part numbers (esp. for things like fan belts, generator brushes, things like that.) But that is a rabbit hole I don't really need to go down today when I should be looking for a job instead... I've already done the best job I could with the pre-LCI E92 which I actually have at my disposal to inspect (and what I actually need the bulb chart for...)
Anyway here I believe is the diagram that you want
http://www.realoem.com/bmw/showparts...74&hg=63&fg=20
and assuming that the rear fog is #6 in the diagram then yes that also is a H21W bulb.
      07-29-2013, 01:41 PM   #108
bmorebblick
Drives: '13 e92 m-sport
I've been searching for a while now and find so many different values.
I'm looking to swap side markers and reverse lights on a '13 LCI E92. (want white side markers and much much brighter reverse lights for use behind tinted windows in the city)
Has anyone determined the final type of bulb? I've read H21W, which doesn't seem too specific. I've read 921 on websites like E92-Lighting. I've read P26WY (or w/e that one is, which isn't LED so I'm pretty sure that's not it). edit - i've now seen 921 and 194 as potential side markers? though some sites suggest 921 are reverse lights too?
Searching through I only found a couple of "lists" but none seem to be up to date!
Any help - greatly appreciated =)
      08-30-2013, 01:30 PM   #109
exmowner
exmowner's Avatar
689
Drives: 22 M3X / 14 GTR
Amber bulb
Hi I was wondering If it's possible to remove the amber/yellow bulb threw coding or If not does a replacement bulb exist?
After installing the lux v4's it's been bothering me.
Thanks to EAS for the picture!
2022-G80 Xdrive BG
2014-GTR BE FBO
2016-HURACAN 610-4 (SOLD)
2021-G82 BASE (SOLD)
      01-12-2014, 09:02 PM   #110
datbimmer
Wastegate Rattle
114
Drives: 335i m6t nav sport
guys, I've been looking and looking, and still didn't get an 100% answer, what kind of bulb lits up the 3 horizontal bars in the 2007 (pre-lci) tail lights ?
