Bimmerpost
4 Series
Technical Topics DIYs and Coding Discussions BimmerCode
      11-24-2019, 11:14 PM   #89
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
Drives: ‘20 330i,‘16 X3,‘18 SQ5,‘17 A7
Originally Posted by RedKloud View Post
I thought the phone connects to the adapter via Bluetooth.
Mine is the wifi adapter. It connected fine and I could access bimmercode. But after 5 minutes, that direct BMW thing popped up and gave me hell. Refused to go away after.
      11-25-2019, 01:10 AM   #90
blazesquall
30
Drives: G20 m340i, G30 m550i LCI
Originally Posted by VipinLJ View Post
So guys.
I have a weird issue. When trying to connect to my adapter via WiFi, my phone refuses to connect to it even in airplane mode. This is because something called direct-bmw 06276 connects via WiFi the moment I put it in airplane mode and turn wifi on. This prevents my adapter from connecting and accessing bimmercode. How do I fix it? I tried disconnecting it from direct BMW. No go. I also tried forgetting direct BMW but I cannot get my phone to forget it. It keeps connecting automatically. I cannot disconnect because the moment it disconnects, it reconnects again and that cycle keeps repeating.
Bluetooth is off. My car does NOT have wifi hotspot or wireless charging or anything of the sort. My phone is only connected to idrive via Bluetooth but I turned it all off and put it in airplane mode. Any ideas?
Your phone can still connect via WiFi direct to the car for Miracast, etc. Unpair the phone completely or forget that network
      11-25-2019, 06:04 AM   #91
Jbrock22
Jbrock22's Avatar
223
Drives: 2pw
BMW   [0.00]
So guys.
Turn off the auto connect. It will stop the automatic reconnecting.
      11-25-2019, 07:27 AM   #92
SCardamon
SCardamon's Avatar
49
Drives: 2019 330i
So guys.
Android Auto may connect via WiFi as Apple CarPlay does - make sure you have that disabled
      11-25-2019, 08:53 AM   #93
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
Thank you! I'll try that
I turned autoconnect of but it still kept connecting. Let me try what blaze asked me to try.
I don't have AA on my phone. I uninstalled it when I had the Audi. Plus I don't think our bimmers have AA? Only car play iirc
      11-27-2019, 04:19 AM   #94
Almaretto
Almaretto's Avatar
2376
Drives: Test Vehicles
Correct. BMW does not have AAP yet.
      12-08-2019, 11:01 AM   #95
homerjay
Drives: F15 X5 / G20 330i
I coded for an M instrument display and didn’t like that I lost my M display in the HUD and lost visibility to the Drive mode setting. So I coded back to the standard BMW option, but now it says “M40d” at the top of the cluster. Any ideas on how I could get it back to normal for my 330i...?
      12-08-2019, 11:36 AM   #96
Jbrock22
Jbrock22's Avatar
223
Drives: 2pw
BMW   [0.00]
Use the back up to get it back to "330i".
      12-08-2019, 01:22 PM   #97
homerjay
Yup, that worked. Thank you!
      12-14-2019, 06:57 PM   #98
IndotagSwizz
IndotagSwizz's Avatar
525
Drives: F30 320i
So guys.
Go to the WiFi networks on your phone click on the name that is connected and when you disconnect click on your phone to forget that device, then connect to your adapter and it should stay connected
Appreciate 2
      12-14-2019, 08:05 PM   #99
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
Forget device didn’t work for it. It refused to forget it and kept reconnecting. Only work around was to unpair it completely from the iDrive. And once I was done using it, re-pair it.
      12-30-2019, 04:33 AM   #100
krisa9977
krisa9977's Avatar
No_Country
48
Drives: M235i
After the update bimmerlink and bimmercode lost most of their functions. Now this app is useless. I asked support to return it back the way it was before, they sad it is not possible(((.
With the bimmercode I'm not able to change engine sound anymore and bimmerlink lost most of the sensor values.
Porsche GT3 991
BMW M4
BMW M235i
Corvette Z06
Radical SR3
      12-31-2019, 11:38 AM   #101
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
You mean this update?
      01-01-2020, 01:42 AM   #102
krisa9977
krisa9977's Avatar
No_Country
48
Drives: M235i
Yes, that was the update. I've got the massage from tech support about 3 weeks ago, they promised to return some of the functions back with the new update. They returned one of the function, but with incorrect max value settings. If you check, for example, engine oil level, it doesn't show anymore.
Porsche GT3 991
BMW M4
BMW M235i
Corvette Z06
Radical SR3
      01-02-2020, 08:06 PM   #103
Kurkeyy
Drives: 2020 bmw m340
BimmerCode for g20
BimmerCode For G20. will we have more stuff in the future or these are going to be the only options for ever?
      01-03-2020, 02:20 PM   #104
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
So I tried using Bimmercode today after a while because my auto start stop memory stopped working and I have a couple of new issues.
A bit of history first. I tried flashing my car with a BM3 tune a few weeks back and it was like opening Pandora's box. It messed up the ECU settings (and my car didn't get flashed either). I have an "i" on my instrument cluster which is a check control message saying car cannot be started in gear and also throws a similar message/notification on the idrive (this also happened when I tried flashing my car and now that message does not go away). Since it doesn't affect drivability or anything other than that annoying message every time I start my car, I thought I'd let it be and wait till the first service. Unfortunately for me, today I had a Eureka moment and thought I'd restore the old DME settings to try and get rid of the "i" since I thought it was related to me enabling ASS memory and restoring settings would get rid of it.
I connected Bimmercode and tried restoring settings. It said restoring failed. I tried a few times and same thing.
So I went into the Engine control unit option and saw that ASS memory was not active. I had also activated sound on engaging reverse gear (since I had it in my VWs long ago and I liked it). I set it to active and hit code. It coded it, restarted the ECU and bam. It erased everything in the cluster memory and said Service indicator not found (basically, the message on the instrument cluster that says Service in xxxx miles when you turn the car on). Also, I found 4 new notifications saying brake fluid change in _ _ _ _, oil change in _ _ _ _ and service in _ _ _ _. The blanks are supposed to be the remaining miles before service but it erased it. So now, not only did the "i" check control message not go, I also lost all service reminders.
My question is. How do I get it to show the miles before service, brake fluid etc on the cluster? Any idea? I don't want to take it in to the service centre in case they dig deep and find out I've been messing with the car big time. But if there's no other option, I'll have to wait till the first service I guess.
Also, is there any app that can read and clear error codes on a BMW? Can esys do that? VAG has obdeleven which is extremely useful and I could clear codes as well as do coding on my A4 and other Audis. So so so much better than Bimmercode.
I'm at my wit's end. Sometimes I wish I could go back in time and not try and flash my car
      01-12-2020, 07:16 PM   #105
Jbrock22
Jbrock22's Avatar
223
Drives: 2pw
BMW   [0.00]
It's time to go to the Dealer. Easy fix for them.
VipinLJ1950.50
      01-14-2020, 08:23 PM   #106
RedKloud
RedKloud's Avatar
741
Drives: BMW i4 M50
Any new updates in Bimmercode?
      01-14-2020, 08:49 PM   #107
Crazy Penguin
117
Drives: Jet Black
Yeah the service interval will populate once they perform service and update.
VipinLJ1950.50
      01-14-2020, 08:50 PM   #108
Crazy Penguin
117
Drives: Jet Black
Anyone code the alpina cluster? The speedo ratio is an incorrect scale. Only digital is right
      01-14-2020, 10:20 PM   #109
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
Thank you Jbrock22 and @[Crazy Penguin]. I let the car sit for a bit and it came back by itself. I forgot to update it here since I forgot I mentioned it here in the first place.
And bimmercode seems to have got a new update yesterday. Updated the app via google play but when I open it, it asks me to update it again in order to continue using it. When I try updating it via the app, it gets stuck at 0% and then says failed. Looks like it’s $38 down the drain?
Current:
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      01-14-2020, 10:21 PM   #110
VipinLJ
Petrolhead
VipinLJ's Avatar
1951
Yup. Other people have complained about the same issue. I don’t like the alpina or m cluster. I prefer the stock cluster so I left it as is.
Current:
g20
