02-12-2021, 03:10 PM | #89 |
570
Rep 512
Are people still looking for these bearings? I've got a line on some of the Sidem bearings which are Meyle in quality, for the cheapest price I've seen anywhere so far. (I'm not selling them, can just pass on the source). PM me.
slowdown_dan285.50 |
02-12-2021, 04:45 PM | #90 |
570
Rep 512
https://3dmmotorsport.com/collection...conversion-kit
There's some healthy profit margin in that kit. I got 8 of these (sidem) shipped for half the price of that kit ^^ that has only half the bearings needed for the full swap. Another 30 for the conical washers thanks to @bbanks. Huge thanks to the users who hacked this mod. |
02-12-2021, 06:34 PM | #91 | |
3922
Rep 4,185
02-16-2021, 06:28 AM | #93 |
3768
Rep 2,738
Many thanks to @Redd for making this thread! I just finished the first stage of my uniball swap and the info here was priceless. I used the Bav Autosport tool set which was worth its weight in gold I was able to easily swap all the bushings with the arms on the car. I have 8 swapped bushings so far for the Meyle Spherical’s. I just have the Bimmerworld Camber Bearing left, and then I’m replacing my toe arm with a SPL adjustable one (328i not M3 so need to swap that too).
Hope to get those done by the weekend. Can’t wait to see how the car feels after this is all done!
02-24-2021, 02:30 AM | #94 | |
166
Rep 478
Did this conversion during latter half of 2019, although without trailing arm and lower camber arm bearings. Along with powerflex black (monroe actually) upper shock mounts, solid subframe.. car is transformed, and that's coming from something with N54 spastic tq delivery, wheelbase etc. Still can be driftastic at the demand of my right foot but with far more precision, confidence and response.
OEM M arms tend to be lighter as well than aftermarket offerings. Quote:
If you guys are in a bind, maybe I can ship my Meyle set but I bet it'll be shipping prohibitive. But, this is one reason I don't like your local vendors. Salesmen at best with weak engineering. It's a shame Schirmer took note with their garbage launch.
Bilstein CS | Rays ZE40 | Solid/spherical front / rear.
YouTube |
02-24-2021, 09:37 AM | #95 |
504
Rep 1,055
Any chance you can measure the OD of cup #3 that presses the bushing? I have a different set I bought when I did the subframe bushings with various sizes and might be able to use one of those.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
Biginboca3767.50 |
02-25-2021, 01:42 PM | #98 |
just another M3
514
Rep 1,152
Ok. Did anyone take measurements from the Meyle bearing.
I ordered a Delphi version from rockauto. I think it's the right size since it's a replacement Bearing for the control arm in question. If anyone has the info please share. Here are the measurements for the Delphi bearing.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
02-25-2021, 06:02 PM | #101 |
3922
Rep 4,185
Meyle 3147100005 bearings
- Inner diameter: 12 mm - Outer diameter: 45.12 mm - Height: 48 mm tlrid3r your Delphi bearings look right. |
tlrid3r513.50 Matt Fojtik133.00 |
03-04-2021, 12:32 AM | #103 | |
just another M3
514
Rep 1,152
But also like to hear about what people think so far that have done it.
03-04-2021, 01:11 AM | #104 |
166
Rep 478
I have not done the rear trailing arm bushes nor the inner lower camber bush..
Night and day difference, far more response and less "snapback" on corrections enabling you to be more precise with inputs. I don't have any tyre data to show deflection changing/dynamic alignment etc.
YouTube |
03-05-2021, 01:18 AM | #105 | |
Rep 107
Whiteline subframe inserts, Whiteline lower camber/spring arm stiffer bushings Manzo toe arms with stiffer bushings Spherical bearings for trailing arms LSD with lock down kit M3 guide rods installed but haven't done spherical bushing on spindle side yet. Car makes 420whp/470wtq current issue under aceleration steering wheel starts feeling lighter and more loose, as soon as I let go throttle car feels more planted and steering wheel back to stiff again. Any suggestions from anyone? Alingment done recently Bolts are not loose on the arms Last edited by N54andS63TU; 03-05-2021 at 01:23 AM.. |
Matt Fojtik133.00 |
03-05-2021, 11:27 AM | #106 | ||
just another M3
514
Rep 1,152
Matt Fojtik133.00 |
03-05-2021, 11:36 AM | #107 | |
Driver
2692
Rep 2,714
E90M 6MT Slicktop Single Humper in need of a diet
03-05-2021, 12:27 PM | #108 | |
1261
Rep 2,495
2010 E92 M3 DCT
03-05-2021, 01:55 PM | #109 |
Derbo Tuning
3613
Rep 3,031
I've been told I was wrong and it is possible without removing the subframe
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
03-05-2021, 03:09 PM | #110 |
1261
Rep 2,495
It's definitely not possible. Runs right into the body of the car. Tried for like an hour before I said f it and dropped it.
2010 E92 M3 DCT
