The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > E91 audio upgrade with lots of pics: Mosconi, Gladen, stealth
      07-25-2013, 03:38 PM   #89
Mr Singh
63
Drives: E91 330D M Sport Auto
Originally Posted by Shaun69 View Post
You don't need dsp or coding but both option will give you better sound quality.
This. But I'd recommend the Hifi coding as the EQ curve is better to my ears, from the get go the upgrade will have you grinning from ear to ear anyway so doing that a later date once things have bedded in and your ears in tune with the sound is a better way to go about it.
After almost 12 months and selling like hot cakes I have just switched to a Gladen Mosconi ONE 120.4DSP, it didn't require much adjustment with the given level of control that's available I found the tailored file from Gladen for the E90 to be pretty much bang on!
      07-25-2013, 03:55 PM   #90
106turbo
Boost Junkie
Drives: 106 Gti T
Thats good because its confirmed what i thought. Run it as it is for now and let it wear in. When i get bored i'll add a sub in the boot floor and code to Hi-fi!
Thanks again for the help people this thread has been amazing!
Btw Mr.Singh thanks for pointing me towards monster audio. They've been very helpfull and got me my kit in great time and packaged well. Quite local as well so if i get stuck i can always make a day trip
      07-26-2013, 02:29 AM   #91
KAL M4
KAL M4's Avatar
35
Drives: F82 M4
+1
F82 M4 Competition San Marino
      07-26-2013, 02:10 PM   #92
106turbo
Boost Junkie
Drives: 106 Gti T
Well i've got so far,
Again this is an e91, same as the OP. Had a mare getting the seat bolts out so that set me back. Should have enough rear trim out to feed most cables in and I've loosened the pass seat and removed the speaker (also fitted the Gladen 8" in to the Bmw housing).
Tomorrow i'll take the dash bits out, fit the harness and run it down the pass side, then fit both subs and run cable to the rear and then fit the amp. Does anybody require any specific photos while i do this? I have a few general ones but i can take any you need.
Also i hope OP doesn't mind me posting in here but it might help others if its all in one place.
      07-26-2013, 03:15 PM   #93
anielsen71
Denmark
562
Drives: F36 435xd
Hi there
Yes, I would like to see some pictures of where you get the wiring to the headunit if you can shoot some of that?
Brgds
Allan
‘15 F36 435xd Gran Coupé
Ex: E46 330d, E91 330dA
      07-27-2013, 05:02 AM   #94
106turbo
Boost Junkie
Drives: 106 Gti T
Originally Posted by anielsen71 View Post
Hi there
I'm about to pull the dash to bits now so i'l' try and get some detailed pics for you.
106 Gti Turbo
Currently 311bhp Atf.. Soon to be 300bhp Atw
E91 320D Workhorse
      07-27-2013, 02:40 PM   #95
106turbo
Boost Junkie
Drives: 106 Gti T
Ok so an update with my progress...
Installed the gladen Quadlock including the little cables for my idrive system. It was a tight squeeze but it eventually went back in! I ran this down the passenger side up to the rear wheel arch and around to the amp.
I then ran two sets of speaker cable from the under seat gladens to the rear. Left sub down the left side, right sub down the right. The drivers sub contact were both cross threaded so woudn't screw back in. I tightened them as slowly and lightly as possible but they still got so tight then loosened. I had to improvise and use bigger screws eventually.
The underseats fit the existing holders perfectly and were a doddle to fit! Stripping the car took most the time.
It started raining so i called it a day before pulling the front doorcards off and fitting the fronts.
Anyway plugged everything in to the amp and let rip with the power. Constant hissing from the front passenger speaker. Underseat was working but again just like a speaker. Front drivers speaker working, nothing at all from the underseat
Too dark and wet to problem solve now. But for tomorrow can anyone give me some good settings for the manual adjustment below.
Also just to check. Ive got the four wires from the gladen harness in the top four slots, and then the underseats in the +/- of the respective sides along the bottom set.(left sub and right sub) this is correct? Cant see why the drivers underseat isnt working.
P.s WOW the gongs are loud! Can i turn them down or do i need to code them quieter?
Any help appreciated
      07-27-2013, 04:47 PM   #96
mob17
mob17's Avatar
400
Drives: E92 335D
A mid and underseat from my set were cross threaded too. Maybe we got the same batch!
      07-28-2013, 04:09 AM   #97
106turbo
Boost Junkie
Drives: 106 Gti T
I hope thats nto the reason the speaker sub isnt working
Just about to pull the doorcards off and fit the door speakers.
Update:
Ok so door speakers + tweeters are in. Drivers underseat still not working. When the rain stops i may try and swap underseats over to see if its the sub or the wiring.
Drivers side door speaker also sounds a bit quiet. Dongs are very loud and the sound cuts out when the dongs go. Seems i have some work ahead of me
106 Gti Turbo
E91 320D Workhorse
      07-28-2013, 07:54 AM   #98
mob17
mob17's Avatar
400
Drives: E92 335D
You should try and solder the wires onto the speakers whose terminals are cross threaded.
Also re underseats, did your original underseat wiring loom have 2 or 4 wires? Did you use jumpers?
      07-28-2013, 08:11 AM   #99
106turbo
Boost Junkie
Drives: 106 Gti T
I connected 1 to 2 and 3 to 4, both sides of the car. Working perfectly on the passenger side. Also the drivers door speaker is working so I'm guessing the jumper cables are working but the speaker is either dud or the wiring is.
Heres how I've fitted the cables (sorry for the scruffy pic I've banged it all together to make sure it all works, it will be tidied up lol)
The top two are the left and right of the Gladen harness.
The bottom two are the left and right sub in the positive and negatives.
Update:
Soldered them on to the contacts and unscrewed the screws and its working fine! No cutting out now either! LOTS of bass just need to play with the settings and also find the source of the hissing when no music is being played. I suppose i'd better put my interior back together. Thanks for the input
      07-28-2013, 11:30 AM   #100
mob17
mob17's Avatar
400
Drives: E92 335D
Good to know its all working and now you can enjoy the bass!
Did you cut both cable loops on the xover as Gladen suggest? Apparantly if the original system did not have tweeters then you should cut them, which should cut noise.
      07-28-2013, 01:06 PM   #101
106turbo
Boost Junkie
Drives: 106 Gti T
No i did not. I read that in the manual, but then decided i'd have a listen first as the tweeters dont hiss but the actual speakers do. The doorcards are coming off for some sound deadening next so i might snip them and see. I can always join them back together.
Edit:
O.k so i've realised my bluetooth isnt working. Have i missed a cable out somewhere?
106 Gti Turbo
E91 320D Workhorse
      07-29-2013, 11:53 AM   #102
Mr Singh
63
Sorry I'm late, the terminals have not been an issue for the last dozen or so sets that have gone out, so doesn't appear to be a bad batch.
Re Bluetooth. Did you install the quadloop harness, and are you sure the MOST connector was transferred over to the quadlock harness OK?
      07-30-2013, 06:19 AM   #103
106turbo
Boost Junkie
Drives: 106 Gti T
The connectors were only threaded in one Sub, all the rest were perfect. My Tweeter surrounds haev arrived at sytner so tonight i will fit those and check the rear of the radio to make sure all cables are connected as its such a tight fit something may have come loose. I will report my findings later.
BTW the bass is awsome. So much better than the boggo stereo! well worth the purchase.
106 Gti Turbo
E91 320D Workhorse
      10-13-2013, 02:08 PM   #104
-Ju-
Drives: E93 335i
A really nice write up on the Gladen upgrade Andy, so nice in fact that I have gone down the same route.
I was looking at the Alpine upgrade initially but due to the fact you still have to add the subs, my car has the DAB tuner where the Alpine kit goes and some of the reviews were mixed I decided to just go the extra and get the Gladen kit.
It's all in now and I can confirm in the E93, the amp fits where the BMW one usually goes with the addition of a shallower storage bin. It's not a cheap upgrade but does make a big difference!
I'm still getting to grips with the setting up of the system as I've been used to half decent factory fit systems in the past so any help would be appreciated, but for now I'm happy
Julian
      10-13-2013, 02:24 PM   #105
-Ju-
Drives: E93 335i
Also thought I'd mention, I had a threaded connector on one of the mids too!
      10-18-2013, 10:12 AM   #106
CTR_Paul
Drives: 320d Sport Plus
Interesting thread (long time lurker!), I too have a 320d Sport Plus and the stereo really frustrates me, but I'm too damn scared of damaging something, so I'll probably not touch it.
*right that's my first post done - 24 hours until I can start a thread about my cars grinding noise issue I'm hoping you guys will be able to diagnose*
      10-19-2013, 09:32 AM   #107
TheBlondeFella
England
40
Drives: E93 320i M Sport
Any chance you could post a photo of where you installed the amp, I had to bolt mine to the rear partition in my e93?
      10-21-2013, 05:20 PM   #108
-Ju-
Drives: E93 335i
Yeah it's in the same place as the OP put it.
I had to order the shallower storage bin @ £45 to refit everything perfectly but everything is hidden as oem.
I took this pic before finalising the install with an mdf colour matched base but it shows the amp in position
      11-10-2013, 12:40 PM   #109
ecs0set
Drives: E93 335i
I'm almost ready to buy the Gladen kit. However I'm concerned about issues reported about volume of the bongs, PDC and Bluetooth. I also have front PDC which I guess will complicate it further as the front PDC will be amplified and the rear will not be.
Ive googled a lot but I'm finding it difficult to ascertain if there is a solution. Then theres the question over coding, to code or not to code (pre-LCI).
Can anyone give me some confidence that the Gladen kit will not break half the toys on the car?
      11-11-2013, 04:44 AM   #110
andyrap
Drives: E91 320D M Sport Plus
I think that as you say, front PDC will be amplified but the rear won't. How much of an issue that might be for you I'm not sure.
Hifi coding is more of a problem potentially if you are still running the rears off the head unit (eg, install the 4-ch gladen to drive the front speakers and underfloor subs as most people do). The problem is that the rear speakers would then be driven at line level (unamplified) so the rear PDC will be a lot quieter. One reason I'm not coding mine.
