European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3 / M4 Photos and Videos
      07-21-2022, 08:17 PM   #89
bokchoi
Drives: '18 sbm F82, '23 sbm G82X
Dang, I saw some guy at a meet a while back who had this in an F82 but he sold for '20 TT RS
      07-21-2022, 08:28 PM   #90
McBobby Jr
McBobby Jr's Avatar
212
Drives: '18 240i xDrive
I think you're referring to @kleaperm4 on Instagram.
current
'18 F22 240i xDrive - FBO
'16 F82 M4 ZCP - FBO
previous
'08 E90 335i Montego Blue
      07-23-2022, 06:58 AM   #91
Clevocapri
Clevocapri's Avatar
Australia
19
Drives: BMW M4 CS, BMW M2 Comp
Do you limit peak torque as you tune or will the rods live at whatever torque it can make at 900rwhp?
      07-23-2022, 10:09 AM   #92
chetrickerman
ECUTek Master Tuner
chetrickerman's Avatar
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
I ramp the torque up, so im not trying to make a ton of peak torque in the midrange. This helps reduce the stress on the rods because they are able to transmit the torque better when the engine is rotating faster.
Torque is a measure of an engine's ability to do work; Power is the rate at which work is done
      07-23-2022, 07:57 PM   #93
McBobby Jr
McBobby Jr's Avatar
212
At 900whp, that should take the record for highest horsepower on a stock block S55. It's cool to see this platform keep developing.
current
previous
      07-28-2022, 03:12 PM   #94
Wanted_M
Wanted_M's Avatar
773
Drives: Frozen Blue M4CS
Any updates??
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf
      07-28-2022, 06:25 PM   #95
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Originally Posted by Wanted_M View Post
Any updates??
Yep, I installed the head, just have to put the rest of the parts on, then I will fire it up.
Appreciate 4
      07-29-2022, 06:07 PM   #96
M3ZCPNYC
622
Drives: M3
Fire that bad boy up
      08-02-2022, 03:01 PM   #97
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Its running well now. Im going to put some miles on the new parts to let them get broken in.
I also installed a turbo speed gauge so I can see if I have any headroom with my turbo to push the boost even higher.
Appreciate 3
      08-08-2022, 12:21 PM   #98
Solo_G
69
Drives: F80 M3
I love well documented threads like this, I wish they were more common! Keep posting updates, this is an epic build!
Appreciate 3
m3less130.00
      09-02-2022, 11:17 PM   #99
WhatM4
WhatM4's Avatar
Drives: '15 DCT M4
Wow awesome build
Appreciate 2
      09-19-2022, 09:43 PM   #100
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
No big updates yet, the car is driving well and is pulling hard. Im going to wait until the winter to hit the dyno because I want to make another downpipe. This one will use a concentric expansion going from 3" to 4" which the small angle of expansion should increase turbine efficiency allowing faster spool up and easier breathing of the engine.
Here is how the engine bay looks as of September 2022.
As another project, I also picked up another S55 block. This one had part of the connecting rod impaled into the oil galley, so I got out my Makita die grinder with some carbide bits and removed enough aluminum to get the piece out and leave a fresh surface that I can weld and repair. The block will be getting sleeved.
Appreciate 2
      09-19-2022, 10:03 PM   #101
Wanted_M
Wanted_M's Avatar
773
Looking good. Yikes, that rod definetly left its mark!!
M4CS Frozen Blue
      09-19-2022, 10:07 PM   #102
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Here is how it looked before I got the piece out
Appreciate 3
      11-01-2022, 09:01 PM   #103
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
The downpipe is done and it is glorious. I was able to use the long concentric expansion to maintain attached laminar flow uniformity better to further improve turbine efficiency. The first almost 3 feet of the downpipe is 4 inch stainless tube, which then necks down smoothly to 3.5 inch to accelerate the exhaust flow and reduce pressure drop. I then went through the rest of the downpipe and exhaust and cut out the tight radius bends and replaced them with smoother more gradual bends to help keep exhaust velocity as high as possible.
You can see in the side by sides how much smoother the new downpipe is. I took it for a test drive after finishing it and could immediately tell a difference in spool up and response. I will update later how much faster the turbo gets to full boost compared to the old 3.5 inch downpipe. If you have a single turbo setup, definitely get the 4 inch downpipe if there is the option!
I also added an external wideband so I can see the true AFR average of both banks so I can be absolutely certain the AFR is within a safe range. I chose to use the Zeitronix ZT-3 which has the CAN Bus option so I will be able to see the ZT-3 AFR in my datalogs through the ECU.
Appreciate 7
Hxngs176.00
DaiLyCS166.50
Wanted_M772.50
TopJimmy5537.50
      11-03-2022, 07:50 AM   #104
DaiLyCS
First Class
DaiLyCS's Avatar
167
Drives: M
Always loved Chet build, you always put a lot of effort into the build, I followed you since the evox build and got it tuned by you also.
Im excited to see where this go
      11-03-2022, 05:34 PM   #105
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Thank you!
      11-04-2022, 07:01 AM   #106
cmcintosh339
cmcintosh339's Avatar
26
Drives: BMW F80 M3
Question. As a non engineer, slightly ignorant individual, why go from a dual turbo system down to one? More turbos = more boost, yes? With your knowledge and availability with parts, why not just change the current twin turbo system, try for better airflow and move from there.
OR, was this a passion project to test your own limits? All very impressive stuff, great work.
Cheers!
      11-04-2022, 04:16 PM   #107
chetrickerman
ECUTek Master Tuner
10447
Drives: F80 M3 YMB
2016 BMW M3  [9.00]
Good question. Usually OEM or aftermarket companies will use twin turbos since two turbos usually have a lower polar moment of inertia than one larger turbo, which means the two smaller turbos should have faster transient response and spool up quicker while having the same power potential as a single large turbo.
With the advent of the Borg Warner EFR turbos, they utilize a Gamma-Ti turbine wheel which has half of the inertia compared the exact same size turbine wheel made out of Inconel or Mar-M. This dramatically affects transient response, and with their redesigned compressor wheel that flows a lot more, I chose to go this route.
The sound, response, power and simplicity this setup produces is found no where else on the market, hence why I decided to make it myself.
Appreciate 2
      11-04-2022, 05:11 PM   #108
F30_320D_UK
F30_320D_UK's Avatar
215
Drives: BMW F30 320D M-Sport
Those pipes look great and will flow so much better than before.
Interesting about the Gamma-Ti turbine wheel!
      11-04-2022, 06:26 PM   #109
DaiLyCS
First Class
DaiLyCS's Avatar
167
Drives: M
Good question. So usually OEM or aftermarket companies will use twin turbos since two turbos usually have a lower polar moment of inertia than one larger turbo, which means the two smaller turbos should have faster transient response and spool up quicker while having the same power potential as a single large turbo.
Single big turbo always have good sound, good intakes sound, turbo spools sound and most important exhaust note on it
      11-04-2022, 06:30 PM   #110
DaiLyCS
First Class
DaiLyCS's Avatar
167
Drives: M
Also weights saving, I wonder how much did you shave the weights from going single turbo?
f80post
