04-22-2015, 09:19 AM | #89 | |
150
Rep 774
Drives: 21 X5 M50i
You're right:
Girl at bar: "Hey, nice to meet you. What do you do?" Me at bar: "Carbon Ceramic Brakes" Quote:
04-22-2015, 09:28 AM | #90 | |
150
Rep 774
Drives: 21 X5 M50i
Seriously, though, this is basically an exercise in freakonomics. You could probably buy a cheaper car, make it faster and more enjoyable at the track than an M3/4, but you didn't because you're an M enthusiast. Taking a step back, the same argument you're making about CCBs could also be made about your M. Next, you're going tell me and the rest of CA to move to a state without income tax or to shop exclusively at Target.
Brakes. You know why I did it? I guess because I can. Quote:
04-22-2015, 10:11 AM | #91 | |
356
Rep 1,749
an m3 is faster at any track than a 335. thats measurable. a ccb equipped m3 can get around a track faster than a stainless steel braked m3? prove it. a ccb rotor is worth the higher cost when used on track? prove it. i have found its by far more expensive. a ccb rotor is easier to use on track? prove it. its way more pain in the ass to keep measuring them for thickness and inspecting for rock chips. You can live wherever you wish. I lived in LA for several years. It was great but like any place it has its good and bad points.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
04-22-2015, 10:24 AM | #92 |
2006 TIME Person Of The Year
9720
Rep 6,445
CCB rotors definitely don't weigh MORE than steel rotors; they don't stop any LESS effectively, or have a LOWER thermal limit than steel rotors. CCB are absolutely not a step backward in performance. I subscribe to the theory that lighter rotational and unsprung weight makes speeding up, slowing down, and changing directions easier. Personally I believe the only valid debate is cost.
04-22-2015, 11:18 AM | #93 | |
///M Uber Alles
333
Rep 1,601
By your standard, you should disassemble the engine after heavy use to check for damage too. Because the engine is important. Just to be safe. Yes, there is a concern about pitting and chips with these brakes. The same service bulletin seems to suggest that damage from spalling or pitting can be replaced as a defective part during the warranty period. I'm not sure about chips but I happen to think that most vehicle comprehensive policies should cover it, if warranty does not. We do not have a good data set on problems with chips yet because, in spite of all the fear, loathing and alarms, there do no seem to be any reported problems of this nature with the F8x CCB's. At least not yet. The only reported problem, as far as I know, has to be with the narrow gap between the callipers and the wheel drum with standard 19" rims, where stones can get lodged and scratch the wheels. Meanwhile, there have been some bad experiences reported at the track and spirited driving with the conventional brakes. Not that they are unexpected. Melted my stock brake pads in 90 miles http://f80.bimmerpost.com/forums/sho....php?t=1117355 Stock brakes severe letdown http://f80.bimmerpost.com/forums/sho....php?t=1028958 F80 M3 brake judder http://f80.bimmerpost.com/forums/sho....php?t=1038273 Brake callipers changing from blue to green due to overheating http://f80.bimmerpost.com/forums/sho....php?t=1115447 Granted, the CCB's may be overkill with their larger diameter rotors, additional pistons etc given the available tire friction. But it is not a bad area in which to be over-engineered, no? Besides they look great, have no brake dust, and provide great pick-up lines when trying to impress the ladies.
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
04-22-2015, 12:25 PM | #94 | |
356
Rep 1,749
the stock steel brakes work fine. properly cooling them down helps with street pad material transferring and getting stuck. the oem pad is okay on track which i definitely tested but its designed for the street and proper endurance pads for a 3000+ lb street car really make it sing. the best thing about steel rotors is you have many many options in pads to fit your needs. the calipers discolor from heat and i have seen that on just about every caliper out there over the years. even mighty pccb calipers. the yellow on them turns to a more faded yellow. the color doesn't affect the performance however. from my experience. if the engine fails you don't go. if the brakes fail you can't stop. i will decide which of those components i'm most concerned with. measuring the thickness give you an idea of how quickly they wear down. not so much of a safety factor there but for me the ceramics on my car were expensive and I wanted to see the effects of tracking. you don't want to wait until the wear circles are visible. think how that affects resale for one. the fact is the steel brakes work well on this car and you have the usual myriad of pad choices to compliment the type of environment you want to be driving in. what choice do you have on ceramics? and if there is any sign of premature wear on ceramics what dealership is going to cover the cost of servicing them for you? bmw doesn't warrant the car or any of its components the second it touches a track. the most expensive wearable component to service is the ceramic rotors. no they don't last longer than steels to the point they justify their costs. and they certainly aren't has hardy as steel. just be extra careful every time you change out your wheels.
04-22-2015, 03:32 PM | #95 | |
///M Uber Alles
333
Rep 1,601
Amen to that. I've been telling my dealership to be extra careful every time I've had them switch my tires. And thanks for the tip on the wheel hanger!!! I've been looking around for something and came up with goose eggs. Turns out "hanger" was the word I was missing.
Burgermotorsports has a handy $10 tool that I ordered. This is a link to it if anyone else is interested. http://burgertuning.com/wheel_hanger_pin_BMW.html I was also thinking about draping a few wet clothes on the top of the rotor to protect it during tire changes. Have you seen anyone do that? Quote:
Easy peasy lemon squeezy. This will be more attractive to some than others. It certainly is nothing to get hung up about.
04-22-2015, 04:45 PM | #96 | |
Large Member
951
Rep 1,749
People are worried about the value of CCBs when buying a premium brand sportscar to begin with is a complete waste of money. We get them all on this forum, that's for sure!
2008 E92 M3 (Engine swap completed), 2015 F82 M4
04-23-2015, 10:00 AM | #97 | |
356
Rep 1,749
yes, usually would put a nice thick towel over the rotor just to protect it. just jack up the car barely enough to slide the wheel off. on the rear wheels of the gt3rs this was a major hassle. that wheel is friggen huge! i even thought about getting some of those rolling platforms so i could just slide the giant wheel off. you get used to it. the one thing i can say about using ceramics for 4 years was i was more methodical when prepping the car than before and thats always a positive. you just get into a pattern. thank god the M3 doesn't have centerlock wheels. god those are a pain in the ass to another level. the pads on the M ccb's hold up to track use as well as steel i found. but really its so easy to swap pads. try RS-29's on the steel braked car and you will be amazed how they feel on a course lap after lap all day all night. oh get two wheel hangers. especially if you ever run a spacer. makes it so much more easier.
04-23-2015, 10:49 AM | #98 | |
356
Rep 1,749
The 991 GT3 RS is 180k track toy. I will bet 90% of them that are tracked heavily will be optioned with steel rotors. Do you think the folks ordering these cars are concerned with a $9000 option having value or not for the purpose of the car? You bet. If they were such an important factor to the cars performance why wouldn't it just be standard? PDK is since its just plain faster with it and also facilitates the rear wheel steering which makes it handle better. yet ceramic brakes are optional and even more so they aren't optioned by people that use the car on a track. so their merits are much more for show than go. to state otherwise makes no sense. Just about every club out there requires a technical inspection performed before driving on a track. Nothing wrong with inspecting your brakes before and after driving. When you start assuming that pushing a car on a track with other people is a safe activity that is when accidents happen. relating inspecting the ceramic rotors for their unique attributes and limitations and performing an engine tear down after a track session is nonsensical. I do however check for any fluid leaks. if someone doesn't take this seriously on the track then I don't want them driving anywhere near me. it sucks to have a preventable problem cause you to miss out on a session. it sucks more to have that issue happen while pushing the car and causing an incident. it really sucks when the person in front of you didnt do their job and causes you to have a bad day.
08-31-2015, 09:55 PM | #99 |
Rep 32
Anyone know if I can put my BBK Brembo from E92 on an M4? I want to keep the brakes if possible and change rotors as that is likely.
11-14-2015, 10:43 AM | #100 |
267
Rep 436
Refurbishing Process...
02-06-2016, 01:55 PM | #102 |
32
Rep 124
Complete brake solution for M3/M4 (Incl. CCB)
http://forums.racingbrake.com/showthread.php?t=1497
Option 2 is for dedicated track/racing, heavy duty (380x36mm) w/6pot caliper. Option 3 is for CCB conversion to Iron rotor. |
06-04-2016, 08:05 PM | #103 |
UnderminE
54
Rep 76
CCB Brakes "Advisory" !!!! Warning
I am posting from my experience and want to share my insight to anyone opting for the Carbon Ceramic Brakes (CCB).
First off they're great on the track, you won't have to worry about warping, they will definitely outlast your traditional steel rotors and out perform. Since receiving my M4 equiped CCB in August of 2015 I managed to rack up about 19K. I just replaced my pads, and as a warning if you trust the electronics in your car to tell you when to replace your brakes you will be replacing your rotors. The Brembo made brake kit fitted with a BMW brake wear sensor allows the friction material to wear down till the rivets holding that material to mounting plate is exposed which will cause grooves in your carbon ceramic brake rotors. Will you need to replace them, probably not, pads yes. It was a track day for me and I waited last minute to pick up a set of pads, my brake wear sensor never went off. I can only image the damage if I allowed the computer to notify me that I need to change my brakes. If you're the type of person to take your car in for service or have it modified by someone else, you might want to take into consideration if it's a place that will properly service it. Chances are if you have CCBs fitted to your car and you go in for service they may not even touch your brakes because of what the iDrive says. My iDrive reads front brakes 130,000 come in for service. If you care about the longevity of your brakes, steel or ccb, take a 4mm allen key might be different on steel vs ccb but use it to clear out the drills in your rotors, use caution keep the key straight, it should pass straight through on a clean drill, if it doesn't try to turn the key a little, don't move it side to side or up and down you can and will most likely cause damage. The purpose of cleaning these out is to allow proper air flow for cooling in hard braking situations, it is a good idea to check often to increase the longevity and performance of your brakes. One more negative, I was never notified by BMW regarding my CCBs of how they should be cared for. After owning 3 BMW's I didn't think that the same car wash would do any damage to my car however BMW Corporate referred me to BMW USA and did advise me after viewing photos of my CCBs that the white oxidation on the center hubs is from chemicals and that they would not warranty them. I owned my M4 for only 3 months garage kept, never driven in rain or snow. To my disappointment and probably yours too, be advised if you buy these brakes BMW does not stand behind them in any regard. If you bought the steels enjoy chemical car washes with out any issue, as many track days as they can take. Pass this on to your buddies, also if you do buy them you can coat the center hubs in a Ceramic Coating. I use Always Dry, works great on wheels. |
06-04-2016, 08:37 PM | #104 |
203
Rep 436
How many track days has the car seen with those pads before replacing?
Current Cars:
2017 GT350 2018 Mineral White M3 2015 ML63 AMG |
06-05-2016, 03:43 PM | #105 |
98
Rep 475
I have been to 7trackdays each 20min*2 and from the markers the front rotors need to be changed already, I will definitely need to weight them. The rears are holding on but given their markers status they don't have much left in them as well. My car is almost 24k miles on it. I can't understand the people who doesn't have problems with CCBs, I mean either they don't track or do something different which I don't know, to protect them I will try to post some pics of my rotors when I have time.
06-07-2016, 06:04 AM | #107 |
European Editor
10637
Rep 22,992
I wonder what the cost of a CCB brake job is? $20K ?
06-07-2016, 09:20 AM | #108 |
21
Rep 69
I still feel like there has not been many actual experiences with "normal" wear in the CCB's and service required. Track I get, there are too many variables to conclude exactly how many track days you will get out of the CCB's but we kind of know that, so track at your own risk, which is kind of the same for any part of the car.
As for daily driving/spirited road driving, do we have any actual experiences, either that they are not wearing at all after X number of miles or that they have worn to a certain level or needed replacing after X miles??? |
06-07-2016, 09:28 AM | #109 | |
21132
Rep 20,742
Drives: 2021 911 turbo
With track use, the CCB seem to wear out pretty fast, almost at the same rate as iron rotors (some reported even faster). With street only use (even very aggressive), the CCB will likely outlive the car itself.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 06-07-2016 at 03:21 PM.. |
06-07-2016, 09:30 AM | #110 |
21132
Rep 20,742
It is difficult to put an exact number of miles. On a street driven car, the CCB will likely outlive the car. On a car that sees the track, it all depends how many track miles it sees relative to street miles.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
