Angel Eye Comparisons
06-13-2014, 01:11 PM | #947 |
Rep 39
Right bulbs?
Hey guys, I'm a little confused.
I'm looking to upgrade the bulbs that light my rings, but have been fed confusing info so far. Attached is a picture of the current bulb that's already in there, it connects using the white plastic clip. I'm looking at getting these: http://www.ebay.com/itm/321253464692...witem=&vxp=mtr Which are supposedly compatible with the vehicle, plug and play. But studying the wiring harnesses they include, it looks like they replace a standard blub and not this funky thing that I have a picture of. Am I just not seeing it correctly or am I looking at the wrong bulb? |
06-16-2014, 08:50 AM | #948 | |
BimmerPost Supporting Vendor
472
Rep 4,938
06-23-2014, 03:59 PM | #950 | |
472
Rep 4,938
07-10-2014, 09:20 AM | #951 |
182
Rep 1,031
Does anybody know, is there a way to test Lux v5 without installing them? I am buying a used set and curious if I can test them on a battery? I wont be able to test them in the proper location until later that night, which would be a little too late. Thank you
08 M Coupe • Ceramic Black Fabspeed Headers • MCS 1WNR • Poly FCAB • Stoptech BBK • Vibra-Tech • Epic Tune • Apex EC7 • RPI Scoop • Eventuri • Stromung • Rogue X Pipe • Varis Diffuser • CF E92 GTS Wing • CF Roof
07-10-2014, 09:29 AM | #952 | |
Rep 130
Drives: 2008 328i Sedan Sports
But maybe someone can chime in if the amperage is reduced by the point the power gets to the lights and the straight battery is too much. |
07-10-2014, 11:13 AM | #953 | |
472
Rep 4,938
07-10-2014, 11:41 AM | #954 |
182
Rep 1,031
I was able to test them off the car battery directly to see if they work. Thank you
07-11-2014, 12:24 PM | #956 |
21
Rep 238
07-11-2014, 12:31 PM | #957 |
Rep 53
07-11-2014, 12:34 PM | #958 |
21
Rep 238
07-11-2014, 12:45 PM | #960 |
21
Rep 238
07-11-2014, 12:54 PM | #961 |
Rep 53
07-11-2014, 12:59 PM | #962 |
21
Rep 238
LCI -> facelift
so it's sedan, like this one ? http://upload.wikimedia.org/wikipedi...328i_sedan.jpg if not, then it should be coupe e92 (this have different headlamp from e90/91 -> better for you ) http://i297.photobucket.com/albums/m...o/100_3628.jpg |
07-11-2014, 02:20 PM | #963 | |
Rep 53
Ahh I see, thanks lol. It's a sedan yes the first picture |
07-16-2014, 01:04 PM | #964 |
24502
Rep 191,503
@Ron1n
Please feel free to add our angel eyes too http://www.x-ph.com/80w-cree-led-angel-eyes-6000k/
08-12-2014, 04:02 PM | #965 |
Rep 21
Halogen Headlight Angel Eyes vs Xenon Angel Eyes
I have a 2009 328i with halogen headlights. Does anyone know the difference between the angel eyes on halogen headlights as compared to those on xenon's. I know they're not as bright and have been trying to figure out why. I recently coded my car to have them run as DRL's but they look super dim.
Are they designed differently? Do they use a bulb that is less bright? Are they coded to exist in the "dim" setting all the time and could be coded to a daylight mode? Is the voltage powering them lower than in cars with Xenon's, and if so can this be coded to increase output? I ask because I noticed that the LED bulbs people are using for their angel eyes are different for halogen headlights but I can't find an explanation as to why this is the case. I'm sure this has been covered somewhere in these forums but I haven't been able to locate it. Thanks in advance for any info! Dave |
08-13-2014, 07:41 AM | #966 |
Rep 39
If your car has just regular halogen headlights, the angel eyes are dimmer in general I think. Xenon and HID put out much more light. But there's nothing wrong with halogen, you can switch the bulbs to LED just like you would install another halogen bulb. The ones that come stock in the car are kind of yellow, and can only be seen in the daytime if you're like right on top of them. I went on eBay and found the Cree LED Angel Eye Bulb for my car (If you want the link I can PM it to you for an example of what to buy) and they are much brighter, and have the white/blue look that I think most people go for. Even though they are much more visible than before, they still aren't going to look as good as an HID upgrade, but considering the price difference and the payoff, it's totally suitable.
I've been wondering the same thing about the voltage on them, because the LED bulbs do come with a resistor wired in that can be unplugged from the bulb (I'm guessing it will make the bulbs much brighter without it, but I don't want them to die in a month because they're being pumped with current) - I've just left it alone. |
08-13-2014, 11:43 AM | #967 | |
472
Rep 4,938
08-14-2014, 09:08 AM | #968 |
Rep 21
Thanks for clearing that up. After looking into it a little further, I think I'm going to go the rout of using Lightwerkz or Lightmodz to do a xenon conversion and switch the rings for LED's.
