F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Help!!How to retrofit my new cluster into my F30
Extreme Powerhouse
      02-10-2015, 10:56 AM   #67
Terabyte
Austria
18
Drives: BMW F30 316d
Vithy
My car has already Xenon light.
But maybe I am thinking of retrofit the 6WA cluster, if I get a cheap one.
But I am not sure if my car has already the right FEM Module for this.
      02-10-2015, 07:48 PM   #68
vithy
56
Drives: 2016 F30 328xi
I think you will be fine. FEM Mid should accommodate 6WA. A friend of mine and a forum member is going to be installing one and I will be flashing it today or tomorrow. He's got FEM MID.
He got a used 6WA, so it's showing VIN mismatch warning. But when we installed it in his car with the MOST cable to NBT, it worked fine. Showed all the info and functioned correctly.
Short answer, you will be fine if you want to retrofit.
Originally Posted by Terabyte View Post
Vithy
      02-11-2015, 12:09 AM   #69
Terabyte
Austria
18
What is the part number for connecting cable 6WA to NBT?
How will you change VIN of 6WA? Is it enough to flash cluster with original VIN?
      02-11-2015, 01:30 AM   #70
franzzz
franzzz's Avatar
Italy
144
Drives: BMW M4
Sorry but is not necessary to allign the VIN of car ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      02-11-2015, 01:55 AM   #71
Terabyte
Austria
18
Sure it is necessary to write car's VIN to cluster
      02-11-2015, 10:26 AM   #72
vithy
56
Yes it is necessary. Which is why he got an Eeprom programmer to flash it with virgin file and then we have to flash with his VIN.
But it will still work with the Red tamper dot on the cluster and as long as the millage is lower than the car's. If not FEM will inherit the millage from cluster, which might not be good.
      02-11-2015, 10:39 AM   #73
Terabyte
Austria
18
Is this the right cable?
http://txpof.en.alibaba.com/product/..._Benz_BMW.html
      02-11-2015, 11:22 AM   #74
vithy
56
I think it looks right. Apparently the connector is a little different/smaller on the BMW one. My friend who got it here in Toronto had to order it directly from the dealer and it wasn't expensive. They come in a pack of 10 for under $20. I will let you know the part number. The optical cable should be good.
I would get this from this seller. My guess is it looks right and should work.
      02-11-2015, 11:25 AM   #75
Terabyte
Austria
18
Do you have a part number of the whole cable?
I can not find it in bmw part programm
      02-11-2015, 11:40 AM   #76
vithy
56
Not for the whole cable. I don't think they sell the whole cable, not sure about it, Cable and Connectors come separately.
Cable goes for $50 and connectors come in bulk.
But I will find out from him as he knows a dealer.
      02-11-2015, 12:13 PM   #77
Terabyte
Austria
18
50$ for the cable? Thats much.
Then it would be cheaper to buy the connectors from bmw and the cable from somewhere
      02-11-2015, 12:45 PM   #78
vithy
56
He just got back to me.
$40 per most cable. You need two and the ends are $5 each. And $20 each for Cable head (Copper head) for optical cable. Total price around $100 here. But in Canada everything is expensive for BMW parts.
You might want to check with the dealer. He doesn't have the part numbers with him, but will get back to me.
      02-11-2015, 12:53 PM   #79
Terabyte
Austria
18
Thank you vithy
Can you make picture of the ends and cable head?
      04-20-2015, 04:15 PM   #80
Chris@codemybimmer
BimmerPost Supporting Vendor
Chris@codemybimmer's Avatar
171
Drives: AW F30 328i Xdrive
Originally Posted by Megalo84 View Post
Hello everyone, someone has solved the problem of retrofit 6wa? Although it happened to me that is not detected in Esys 6wa and keep seeing bkombi. I have read that the problem may be due by FEM. you who have no idea?
delete bkombi in svt tree and read ecu again.
if you have the MOST cable connected you will see 6WA Kombi
      05-08-2015, 10:53 PM   #81
Coolala
Japan
38
Drives: 2013 F30
Hi 1lyfe,
Could you explain more? How to "delete bkombi in svt tree"? Open SVT-Editor, delete bkombi, save it, and then??
Thanks!
      12-14-2015, 06:17 AM   #82
everywill
everywill's Avatar
Drives: E90, R56, F30
Originally Posted by mougwai View Post
Hello,
We did it, installed a new EPPROM with O Km and reset all occurency of VIN by FF...
I was able to code the kombi (e sys), kombi got the good vin, and is working fine.... but the red dot still there (fyi service can be reseted, and kombi is working corretly).
I run ISTA and check the box Kombi was replaced... IsatP (5.4), do the job key alignement on the kombi with success... but the red dot still there
i checked in INPA, NO ERROR about Kombi !
I do not understand !
Hi mougwai,
Have you addressed the red dot problem? If so, how did get this done? By flash the KOMBI with your VIN?
I'm still quite confused. If, as you've mentioned, one long VIN & 3 short VINs in EEPROM have been blanked, and mileage been cleared. It should no different from new cluster. However, other members did say that you should only need to change SVT and write it back then inject CAFD, coding.... So why flash is necessary?
      01-18-2016, 08:57 AM   #83
beanbaguk
beanbaguk's Avatar
Spain
458
Drives: BMW G30 520d M-Sport
I'm half considering this. I've got a dealer quote for 550eur (+ VAT), for the cluster.
(I'm having a bit of a spend-a-thon at the moment so considering all my options).
Is there a straight-forward way of retrofitting a S6WAA cluster?
Short of the long, I have a Business Navigation with no extended bluetooth (no combox), but it would be rather nice to upgrade my cluster to an extended version. Primarily for navigation as I like the idea of having that there, but it also looks a lot nicer.
Question is...if I buy a brand new, unused unit, how simple is it to install? I've read through this forum and it's another language!
  • I know how to install the unit. Very simple to do that.
  • I know the EEPROM has to be flashed to my VIN, but how does this happen?
  • How does the mileage update correctly?
  • How do I get it coded to my car? I've read Shawn's summary which sounds straight forward but I see some people have had problems and the dreaded tamper dot which I would like to avoid.
Thanks all!
      04-06-2016, 03:56 AM   #84
larry_bml
larry_bml's Avatar
Romania
194
Drives: BMW F30 Sport Line 320ded
Success
Yessss, last night I retrofitted my 6WA instrument cluster on my F30 04.2012.
After most connection, I had to code them, there was a little bit problem, when E-Sys doesn't saw Kombi, after adding 6WA to FA, but after saved SVT, deleted BKombi, write STV to car, and read SVT from car again, E-Sys saw Kombi module. Then injected CAFD and VO code it. All is OK, no red DOT, correct KM, service etc.
After done with Kombi, I had to code with 6WA in FA, HU-NBT module, and all OK. Now I have navigation instructions on instrument cluster, ED stats in HU-NBT, everything is working OK.
It is a nice retrofit.
Thank you all , for your help.
I can help others, if they need.
      05-17-2016, 10:32 AM   #85
ttxuky
ttxuky's Avatar
Spain
Drives: bmw f30 316d
I have the same problem.
How do i delete bkombi?
      05-17-2016, 11:23 AM   #86
shawnsheridan
shawnsheridan's Avatar
10545
Drives: 2018 Alpina B6 650ix GC
Do you Read ECU rather than Read SVT?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      05-17-2016, 11:53 AM   #87
larry_bml
larry_bml's Avatar
Romania
194
You will need to read svt, save it, delete bkombi from it, write it to car vcm, read ecu after that and you will see kombi.
      05-17-2016, 11:58 AM   #88
shawnsheridan
10545
You do not need to delete existing ECU from SVT to see new ECU. Using Read ECU ignores SVT stored in VCM and actually queries all system buses, and populates SVT based on actual ECU's connected to bus.
f30post
