Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Official Bulb Code List (E90 sedan)
      10-21-2009, 11:06 PM   #67
i own an e90
chief general
i own an e90's Avatar
72
Drives: e90 white on black manual 6spd
ok a bit confuse.. i have a 2006 325xi sedan ...what is my fogs size ? h8 or h11...im gettn h8's and h11..which one is correct ... if so, is it the same size as HID fogs too??
      10-21-2009, 11:07 PM   #68
UdubBadger
No_Country
635
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
H11 is the standard fog size
      10-21-2009, 11:10 PM   #69
i own an e90
chief general
72
h11 is the standard size ...... so im guessing HID for it is the same SIZE ?
i have 325xi 2006 sedan
      10-21-2009, 11:39 PM   #70
UdubBadger
No_Country
635
2011 135i  [7.46]
2008 328xi  [8.76]
yes, size has nothing to do with what component you're putting in there.
      10-22-2009, 09:29 AM   #71
i own an e90
chief general
72
so im guessing h8 is the wrong size .... cuz i put h8 hid fogs in ....and still works ... but shuts off on me...is that the reason why ?
      10-22-2009, 11:08 AM   #72
UdubBadger
No_Country
635
2011 135i  [7.46]
2008 328xi  [8.76]
H8 is the size you use for Xenon high/low blubs so yes... you need H11's
      11-06-2009, 07:11 AM   #73
Derek Zoolander
90
Drives: 09 E90 M-Sport
Is there a LCI bulb list floating around?
      11-06-2009, 08:43 AM   #74
E92-Lighting
E92-Lighting's Avatar
860
Drives: Next Generation LED Lighting
let me know if you have xenons or halogens and i will give you the official e90 lci list
      11-06-2009, 08:57 AM   #75
Derek Zoolander
90
Halogens, thanks!
      11-17-2009, 03:47 AM   #76
Nikos120i
Nikos120i's Avatar
Greece
Drives: BMW 320si
Hello all!
I have a 320si with adaptive xenons, 2006 model. I want to know the type and wattage of the "ring" light and if I can put one of a higher wattage to use them as daytime running lights.
This is the part: http://www.bimmian.com/images/specials/SPE200062.jpg
Thanks!
      02-12-2010, 05:29 AM   #77
midzata
Drives: e90
Hello, I was wondering if you might help me with a problem I have.
The eyelids on my BMW E90 are not turned on.
Is there code that will activate them when the car is running? Also I would like them to be turned on when the car is not running but the key is inside.
We have another problem that is not connected to the eyelids. The contacts under the seat were loose so the red airbag bulb was turned on. I've put the contacts right but the airbag bulb turned into yellow. I've checked the airbag with Launch X431 and it says there is not problem.
Is it possible the error to saved in the car's key, and should I erase the error from the key so I can fix this problem.
Regards,
Mile
      02-16-2010, 08:10 PM   #78
flymosquera
22
Drives: 328i
hey I want to know if someone knows what CC-ID 163 is?? I am getting this error from an exterior light.
      03-01-2010, 10:57 PM   #79
MrZ
MrZ's Avatar
Belarus
19
Drives: 330i
For pre-lci e90:
Angel eyes bulb. Can be bought as an assembly light bulb+reflector from a dealer for $82+tax in Canada. But it is quite easy to take the existing one apart and just replace the burnt bulb. The bulb is:
Philips 12082 12V 10W (impossible to find, at least in Toronto)
can be replaced with Osram 64113 - only found it at NAPA @ Dundas&427 (Toronto).
Picture:
http://www.donsbulbs.com/bulbs/g632/...40h%7chmb5.jpg
      03-04-2010, 11:41 PM   #80
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
Does any body know what the bulb in the rear fog lamp/hard brake lights are?
      03-13-2010, 09:56 AM   #81
SteveMD
SteveMD's Avatar
198
Drives: 2016 F10 535i MSport
The LCI E90 Angle Eye lamp is a 35W H8. May want to update the list.
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      03-15-2010, 09:12 PM   #82
BMWjames
BMWjames's Avatar
81
Drives: E90
+1
      03-15-2010, 09:13 PM   #83
Mike@F1 Autohaüs
Mike@F1 Autohaüs's Avatar
195
Drives: ❤
Originally Posted by BMWjames View Post
+1
BA9S
      03-18-2010, 09:25 AM   #84
E92-Lighting
860
+1. h8 35w for fogs as well. e90 lci
      07-01-2010, 09:46 AM   #85
WilliamX050
WilliamX050's Avatar
Drives: LeMans Blue 335is
So just to double check for xenons if i want to change the ae's to a diff color i would have to get an h7 bulb? Would it affect the light from the projector bulb?
      07-01-2010, 10:01 AM   #86
E92-Lighting
860
if you want to change your xenons, its a D1S bulb type, the H7 for e90' sedan is your DRL.
      07-01-2010, 12:02 PM   #87
WilliamX050
By xenons do you mean including the projector bulb or just the angel eyes?
      09-14-2010, 11:41 AM   #88
iBoost335STi
Drives: 2007 335i
why are there 3 different bulbs listed for the step/courtesy lights (under the doors when u open them) which do i need or do i need all 3??
Im also looking for the LED dome lights and spot lights on the interior but i dont see the bulbs listed...
oh and also where can i get some HIDs 6-7k for a decent price? What about angel eye led bulbs..
Im very bad with bulbs, thanks in advance
-430AWHP Fully Built, Big Turbo & Meth...RIP Subie
-E90 335i
