05-19-2009, 02:21 PM | #68 |
Rep 436
Drives: 2011.75 e92 M3
Subscribed.
05-19-2009, 06:00 PM | #69 |
BimmerPost Supporting Vendor
8312
Rep 18,880
Drives: BMW
Modules are now available:
TVinMOTION Control for 3-series (e9x) http://www.europeanautosource.com/pr...oducts_id=2320 Thanks to everyone for being patient.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 05-19-2009 at 06:45 PM.. |
05-19-2009, 06:21 PM | #70 | |
Groin Grabbingly Trascendent
44
Rep 431
05-19-2009, 06:44 PM | #72 | |
8312
Rep 18,880
Drives: BMW
05-19-2009, 06:53 PM | #74 |
4 * General
58
Rep 644
Nissan GT-R (Sold) E92 M3 + 335 (sold) F10 535 (sold) When Driving Nice Whips It Helps To Have Nice Kix!
05-19-2009, 07:29 PM | #75 |
8312
Rep 18,880
Drives: BMW
Not yet. Can't activate this feature if DVDs are not an option in the first place on MY08.
We're going a different route for the 2008 models and will report when closer to completion.
05-19-2009, 10:23 PM | #77 |
213
Rep 3,836
Drives: Jerez E90 M3
On my the mod list for my new car for sure! Nice work guys @EAS!
11' E90 M3 6MT | Jerez Black | Black Ext./Carbon | ZCP | ZCW | ZPP | ZTP | 302 | 403 | 507 | 5AC | 655 | 6FL | 752 |
15' F80 M3 6MT | Black Saphire | Black Full | ZEC | ZLP | 2VF | 2VZ | 5DL | 688 | |
05-19-2009, 10:29 PM | #78 |
8312
Rep 18,880
Drives: BMW
Installation procedures for MY09 M3
Detailed function description (* = Factory Setting):
Function 1 - Module Mode ( 0=OFF / *1=ON ) When disabled (setting 0), the module becomes completely inactive and behaves as if it was not installed. This is useful if you need to take the car to the dealer or garage for inspection or repairs. The module can not even be seen by and does not interfere with the manufacturer's workshop tester. InstallAID™ LED: This module is equipped with our unique installation help and status indicator LED. The LED signals a correct installation and shows the status of the module in a clear and easy to understand way. LED OFF Ignition OFF: CAN bus and module are in low-power standby mode. This is normal. Ignition ON: Either power connection or CAN bus connection is interrupted. Troubleshooting: Check the two wire taps for 12V and ground as well as the CAN connectors. Also make sure the CAN polarity is correct. LED permanently ON - Ignition OFF: Should not happen! CAN bus and module should enter standby mode after max. 1 min. The LED MUST turn off at some point. - Ignition ON: Module is connected to CAN and power, but does not receive the correct data. Recheck all connections thoroughly. LED blinks CAN Bus is active, the module is connected correctly and ready for use. Programming This module is equipped with our interactive setup feature to allow easy setting of the desired options. All programming is done by using the blinker stalk (3) and the two green turn signal (indicator) arrows (1,2). Functions are indicated by the left arrow (1) and their settings are indicated by the right arrow (2). Navigation is done by pushing the stalk down (next function) or pushing it up (next setting). After selecting the last function or function setting, the setup automatically jumps back to the first function / lowest setting. Each time either a new function is selected or a function's setting is changed, the arrows will indicate the new status by first blinking the function (left arrow) and then the current setting (right arrow). To enter programming mode, first make sure the key is not in the ignition lock. Tap the UNLOCK button on the remote fob, then push and hold the blinker stalk UP (only into the first position, not all the way!) until the left arrow blinks once to indicate function 1. Now let go of the stalk. From this point on you can navigate through the functions by pushing the stalk down and once the arrows are finished indicating the function and setting, change the setting by pushing it up. The new settings are active immediately. To end programming mode, either wait for 30 sec. or insert the key into the ignition lock. End of programming mode is indicated by both arrows lighting up simultaneously for 1 second. Examples: Function 1 (Module mode) is set to ON (setting 1): Left arrow blinks 1x to indicate function 1, then right arrow blinks once to indicate that this function is set to setting 1. In case the left arrow is finished blinking and the right arrow does not light up at all, the appropriate function is set to setting 0 / OFF and hence disabled. Installation - Steps 1-3 1. IMPORTANT: Turn ignition off, and pull key from ignition lock before installing the module! Remove the trim by pulling out on the end (1) and the middle (2). Unclip the plugs from the START/STOP button and the button panel between the air vents. 2. Pull out the Climate Control panel and disconnect the plugs on it's back. 3. Remove cover plate from Multimedia unit keypad. Like all the other parts it is just snapped in place. Installation - Steps 4-6 4. Remove the 4 screws shown in the picture. Then pull Multimedia unit out. Be careful not to scratch the gear shifter (use towel). 5. Unplug the large black plastic plug by squeezing the tabs (1) together while pulling outward (direction of the arrow). 6. Connect the module as shown by tapping the power and ground wires (thick red/green and thick brown wire), then cut the pair of twisted CAN BUS (orange/green and green) wires that goes to the pins directly next to the power wires (not the 2nd pair going to the little inserted plug). Connect the module harness between the CAN wires, orange/green and green from RADIO side connecting to wires in slots 10 and 2 respectively and orange/green and green from car wiring harness to 11 and 3. All wires are numbered in the picture. Connect all plugs, install module in back right corner pocket before sliding Multimedia unit back in. Reinstall all covers and plugs. Installation is complete.
05-19-2009, 10:52 PM | #79 | |
2312
Rep 13,025
Kufatec has a harness that could be modified for this BMW application already made for VW (they share the same connector; 12V/ground and CAN wires junction made for accessories). Just transfer the optic cables and the mini connectors to this new harness and that's it. I think that a typical BMW owner interested in this mod can pay up to ~ $50 (including the labor in creating the harness and with a nice profit) extra for a much better installation procedure with this device... and still keep the OEM wires unmolested and uncut... |
05-19-2009, 10:54 PM | #80 | |
Rep 96
I'm placing my order for my M right now. Good work |
05-19-2009, 11:00 PM | #81 | |
8312
Rep 18,880
Drives: BMW
Metra harness ends do not have the correct provisions. For those with simple DIY skills, I don't see the current solution as a problem. Yes - this will work for both applications.
05-19-2009, 11:21 PM | #82 |
Rep 96
05-19-2009, 11:26 PM | #83 |
8312
Rep 18,880
Drives: BMW
Thanks for the order, we'll get this shipped out first thing tomorrow.
05-20-2009, 01:22 PM | #86 | |
8312
Rep 18,880
Drives: BMW
In the meantime, all orders are shipping today, with 2 installs happening this week.
05-20-2009, 01:26 PM | #87 |
Rep 19
Tom:
With this module, how does it work? If I’m using the NAV and watching a DVD movie will it interrupt the DVD movie and give you NAV voice commands and on screen directions with map display then flip back to the DVD movie? |
05-20-2009, 01:40 PM | #88 | |
8312
Rep 18,880
Drives: BMW
Using the iDrive dial will allow you to navigate between various options freely.
