03-06-2024, 11:46 AM | #67 |
B58 Power
498
Rep 633
Drives: 05/2022 M340i xDrive Touring
Is your car stock or do you´ve something coded?
Just that i can be aware of certain things when comparing.
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
03-06-2024, 11:49 AM | #68 |
42
Rep 112
Drives: 2023 BMW 330e LCI M - Sport
[QUOTE=MichaelNRW;30962837]Is your car stock or do you´ve something coded?
Just that i can be aware of certain things when comparing. I have a few things coded in, anti-dazzle, cornering lights set to higher speed, I have the welcome animation currently, but it doesn’t do side to side, just the inside outside sweep, some custom ambient colors. *Do the DRLS in the EU turn off completely when the blinker is on? In US they do, unsure if this can be changed as well. |
03-06-2024, 11:54 AM | #69 | |
B58 Power
498
Rep 633
But it stays on when the low beam is on.
Calvindubois42.00 |
03-06-2024, 11:56 AM | #70 |
42
Rep 112
Ahh, same here. Which I could change that, looks so much better with the headlight on, I also wish I could increase the drl brightness slightly with low beams on. Nothing to bright to scatter light, but enough to not look so dim.
03-08-2024, 10:05 AM | #71 |
42
Rep 112
03-19-2024, 01:31 PM | #72 |
42
Rep 112
03-19-2024, 04:17 PM | #73 | |
194
Rep 652
Drives: 2018 F48 X1 xDrive 18D
https://g20.bimmerpost.com/forums/sh...0#post31000460 |
03-29-2024, 04:15 PM | #75 | |
182
Rep 308
04-14-2024, 04:03 PM | #76 |
182
Rep 308
MichaelNRW have you been able to find any differences to explain why the US cars don’t sweep left to right?
Appreciate all you’ve done thus far to progress this! |
05-02-2024, 09:50 PM | #77 |
182
Rep 308
One thing interesting I did notice today MichaelNRW ….the LED side markers on the US spec cars light up and do the sweep FIRST, then as soon as they’re done the main headlights do it outside to in.
Curious if maybe that’s what the staging 1 vs 2 settings impact, perhaps? Any findings from your end? |
05-03-2024, 02:11 AM | #78 | |
194
Rep 652
05-05-2024, 04:15 PM | #79 |
182
Rep 308
That's my thought, I might play with the order and mix/match staging 1/2 values to see if that changes things.
05-05-2024, 04:21 PM | #80 |
194
Rep 652
If we somehow could identify which number is related to the sidemarkers and normal headlights in respectively US and ECE version that might give some clue about How the data is build up as well.
05-14-2024, 12:31 PM | #81 |
194
Rep 652
05-14-2024, 12:33 PM | #82 |
182
Rep 308
Yeah just post it here dude.
I will say that it’s clear only Staging1 copy of the data is needed, so this line: 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 0E, 00, 0B, 01, 00, 21, 1E, 03, 1E, 03, 64, 03, 1E, 12, 1E, 03, 64, 03, 1E, 08, 1E, 21, 64, 4B, 1E, 0F, 00, 0A, 01, 00, 21, 1E, 03, 64, 03, 1E, 17, 1E, 03, 64, 03, 1E, 05, 1E, 21, 64, 4B, 1E, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00, 00 Staging2 seems to impact the side markers to do similarly on US models, not the DRL’s. So if we could mirror the Staging1 value to reverse the flow on the left light, that would give the sweeping motion. I believe the right DRL’s code is correct to euro spec. |
05-15-2024, 04:09 AM | #83 | ||
B58 Power
498
Rep 633
Just share the coding or gtfo. Quote:
He´s gatekeeping information for quite some time and only promotes his business against the rules of this forum. He wont... He´s just teasing something and then wants to sell you the information.
05-15-2024, 05:28 AM | #84 | |
182
Rep 308
Did you see my comment on Staging1, MichaelNRW ? Applying that code only to Staging1 seems to make the animation work (just not right to left, it’s outside inwards on each light mirrored). Staging2 code on US cars seems to make the animation happen on the side markers. So the key to me is in the delay and reverse of the left DRL’s animation. |
05-15-2024, 05:50 AM | #85 | |
26
Rep 97
05-15-2024, 06:06 AM | #86 |
194
Rep 652
05-15-2024, 06:44 AM | #87 |
182
Rep 308
Then back up your claim by sharing the information here instead of back channels. That’s the easy way to prove you’re here to help the community.
05-15-2024, 08:50 AM | #88 | ||
B58 Power
498
Rep 633
You do nothing and only write empty promises :-) Not the first time and wont be the last time. Remember the M HUD? You said you can code it without flashing M software but never shared how. You told me to contact you through PM and then never answered. And it wasn´t just me ;-) Anyway, go on with your shady behaviour... Quote:
As far as i understood the data, Staging 2 is just another place to write that data into. Because Staging 1 has not enough space for every car and then it just goes sinto Staging 2 and so on.
