06-27-2023, 05:55 PM | #68 | |
3924
Rep 4,185
DrFerry6734.50 |
06-27-2023, 10:35 PM | #69 | |
Derbo Tuning
3613
Rep 3,031
IG:ruhrohz_m3
Journal: Link E9x ZCP Suspension Info: Link Track Chat Discord: https://discord.gg/VsKbTyqBVj SF Bay Area: DM For coding services |
06-27-2023, 11:16 PM | #70 | |
137
Rep 32
Drives: BMW M3 Coupe
I have the harrop supercharger and the engine bay gets really hot, im wondering if the edc cable is also getting hot causing the system to go into failsafe. when i get the error, i usually let the car cool down a bit then wiggle the edc connections and the message goes away.
M3rulZ
DrFerry6734.50 |
08-17-2023, 07:25 AM | #72 |
12
Rep 7
Hi Rodeo82, with whom did you have contact?
I work at Tractive, i also wonder with who you had contact as non of the guys here own a E9x M3 But i think you probably mean one of our dealers. Such EDC errors can come from the wiring connections. This does not happen often, at all. But it is most likely the connectors. You can measure the DDA valve, the connector from the damper has 2 pins, if u measure those 2 it should read ~3 ohm. Then measure from 1 pin to the body, so do this twice from each pin. This should be infinite. However the valve rarely ever has issues, quality control on our valve is very high. Last edited by Lucase83; 08-17-2023 at 08:16 AM.. |
08-18-2023, 05:24 AM | #74 | |
12
Rep 7
I like bimmers and forums are always interesting. A lot of information which is also good to know to learn and grow. I'm relatively new to the company, but if there is anything anyone wants to know just shoot me a pm and i will share my work mail address. I've read there were some issues in the past and off course i cant fix those anymore. But if i can help somewhere i will. |
09-04-2023, 06:29 AM | #76 | |
12
Rep 7
Chris can also do full service on shocks. However if you know a shop that wants to be a dealer they can contact us. There are a couple of possible shops we are working on in the east coast. For Porsche we have several other dealers. |
09-11-2023, 10:48 PM | #78 |
137
Rep 32
Hi Lucase83 i have been in contact with your dealer Chris. Not tractive directly. Good to see a tractive rep in this community. I will check based on your suggestion.
Couple of questions? 1. Is it possible the edc module is faulty? Reason being, I get no code when the edc malfunction message appears. Shutdown and restart vehicle, message dissapears. If it was a wiring issues or connector, then i would assume the error message stays even after a shutdown and restart. 2. Could a bad damper cause this malfunction? Again should't the car throw some kind of error. I see no codes. Is it worth getting a used edc module and coding it to the vehicle to eliminate the module malfunction? Thanks Muthu
M3rulZ
09-14-2023, 02:51 AM | #79 |
12
Rep 7
Hello,
Try contacting https://theeuroshopva.com/ They are not dealers yet but have shown interest. Perhaps this can push that interest a bit more. |
09-14-2023, 02:54 AM | #80 | |
12
Rep 7
I have heard of EDC controllers going faulty, it is not an impossible situation. If the damper is bad it will show in the simple measure test with a multimeter. If it is a wire/connector it could be that the fault only appears when driving as it might rattle/shake under those circumstances. |
rodeo82136.50 |
09-14-2023, 07:35 PM | #81 |
3924
Rep 4,185
I've found BMW electronics to be very sensitive to cable movement. Same thing happened to my throttle pedal when I forgot to route the cable thru the clips. Just a bit of a wiggle would cause an error.
Maybe try to cable tie the EDC cables and make sure the connector cannot move. |
01-24-2024, 10:42 AM | #85 |
237
Rep 3,303
I would love to drive your car back to back with mine. Solid aluminum subframe, purple everywhere else including on diff (LOVE THAT FAINT WHINE!!! ) monobol upfront….yada, yada, yada.
Difference is I have the Ohlins dedicated with as you know insane spring rates. Rough on the street with rough roads, but on the highway or track I had a G80 owner get in it and go “WTF, 13 years old and I swear this feels better than mine at speed”…..so smooth and the grip is insane. But, around town I have to be at 15 clicks, no lower and can’t crank her till I hit the track. Still love her though Would love to see what these do on my setup where the only thing changed is the shocks leaving the springs I have. I venture to guess that being tuned for the spring rates they sell this kit with means they won’t work right being paired with spring rates approaching 1000. Wish they would come out with a more track focused version of these or tune to different spring rates——course if I wanted that someone should tell me to go buy a 2022 GT3 (which I would if I was man enough to afford it ). Thanks for the thread, really appreciate it as I looked at these when I did my suspension but distributor in DE was busy and they were not as readily available as they are now! Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
Thumbie103.00 |
01-24-2024, 12:44 PM | #86 |
2485
Rep 5,976
e46e92love
Tractive does have a more track oriented version of the 1-way EDC setup (track line) and a three-way damper with manually adjustable HS and LS compression + EDC rebound (motorsport line). Also, Nitron is releasing etron R1 and R3 dampers (and a roadsport street version) similar to the Tractive options. R3 is a EDC rebound + LS & HS manually adjustable compression. A comparison of Tractive and Nitron EDC offerings will be interesting. What are you looking for in the comparison? With the same spring rates, The Tractive Track line will most likely ride more harshly than R&Ts properly valved for your spring rates. EDC dampers are trying to always find the correct LS underdamped (0.6-0.8 % of critical) and HS significantly underdamped (e.g., 0.2-0.4 % of critical damping) damping coefficients to minimize the number of cycles for each disturbance. The Tractive version that uses their own active controller allows you to set up pre-configured settings that control LS body motions along with different base maps to define performance levels (e.g., comfort, sport, track, etc.). |
01-24-2024, 01:48 PM | #87 | |
237
Rep 3,303
Honestly, would be nice to not have to get under her and fuck with clicks depending on the day. There are many highways near me I could crank my Ohlins to “1” and it would be fine, but then I come off the exit and FUCK . I’m considering trailering her to the track this summer rather than having to get there early, and do the whole jack her up, do the click game and such. Listen, Ohlins dedicated with all the other upgrades I made was NOT cheap but it has transformed my car into a track beast that can be driven on the street (huge for this engine to be used consistently). I’d have to be good enough to go semi-pro / pro circuit for me to out drive this setup. But I just wish I’m getting older and lazier and wish I could click a button to allow the car to soften a bit at times. Make sense? I like the ability to adjust roll and pitch as well….rather than just adjustments for stiffness. I like how you tell the computer you want less roll and it adjust things. It’s a big reason why probably 90% of people who get 3-way adjustable shouldn’t because they don’t know enough about suspension tuning to get it right for different tracks / roads leading to the car performing WORSE than it would fitted with significantly cheaper 2-ways. Again, 1st world problem of: make enough to buy a 2022 GT3RS…. Cheers, e46e92
01-24-2024, 06:15 PM | #88 | |
3924
Rep 4,185
Even til today the TracTive still continue to impress me. The magic is in the roll and pitch control. Your brain tells you soft springs should not be able to have body control like that, but the car just takes your inputs and does what you command it to. No fuss, no drama, and super smooth. I haven't driven Ohlins Dedicated Track yet, but the TracTive was another level above and beyond the R/T. |
DrFerry6734.50 |
