09-05-2022, 07:44 AM | #67 |
72
Rep 266
Was tempted to give this a go, if I could have done it via Bimmercode, but alas im NBTevo_R, so not possible.
For me, its not worth the hassle updating the version just to get full screen carplay. |
09-05-2022, 09:07 AM | #68 |
Coding ECU's remotely
449
Rep 1,182
You don't need to update to a later version, you just need an enet cable and windows PC - takes 5 minutes.
09-05-2022, 02:12 PM | #69 |
Rep 8
09-05-2022, 02:29 PM | #70 |
1804
Rep 3,070
Unfortunately not enough posts yet to send a dm/pm.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
09-05-2022, 06:12 PM | #71 |
245
Rep 724
09-06-2022, 04:32 AM | #73 | |
449
Rep 1,182
Only 1 version of fimware works - 18-03 - but even then it is not an ideal solution, I would never reccomend this to anyone as it will not be reliable. If you want carplay and you have ID4, then just replace the headunit with an ID5 unit and have it flashed to 18-03 (NBTEvo_N)firmware to allow it to work with your existing screen (if you flash to later firmware then you will get random black screens), once flashed and coded/activated to your VIN it is plug and play) That is a much better solution and won't crap itself on a regular basis. |
09-06-2022, 04:33 AM | #74 |
449
Rep 1,182
09-06-2022, 05:24 AM | #75 | |
245
Rep 724
09-06-2022, 07:08 AM | #76 | |
449
Rep 1,182
Your car, your decision Amigo, but I've got 10+ years of experience coding BMW's and I know the pitfalls. No matter which way you go, you'll either have to flash your current headunit or flash an ID5 unit to the right firmware to make it work right. Anyone selling you a service to flash your ID4 unit to ID5 and not telling you it will not randomly reboot because the OS has crashed, is lying. I'm not trying to make any money out of you, so hopefully you can be re-assured that I have no skin in the game. |
09-06-2022, 11:51 AM | #77 |
Rep 8
09-12-2022, 01:56 AM | #79 | |
1394
Rep 2,130
I have to do that with mine every once in a while. It's also good practice to restart your phone every once in a while as I find this helps CarPlay stability.
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport
Current: 2018 F36 440i M Sport (Stage 1 BM3, xHP stage 3) |
09-15-2022, 12:13 PM | #80 |
Rep 26
Hi guys and gals….
Am I right in saying that I need to have the software update done? I have CarPlay working but half a screen that looks rubbish Also it appears my maps have never been updated 😂 Thanks Last edited by sparkie1984@!; 09-15-2022 at 12:30 PM.. |
09-15-2022, 02:40 PM | #81 |
449
Rep 1,182
Yes, you need to have the firmware updated in order to get Full Screen carplay - can be done with an ENET cable and Windows PC
09-15-2022, 02:43 PM | #82 |
Rep 26
Thanks Wibbles,
Do I need a charger to keep the battery from going flat too? Any recommendation for a cable? I can use the wife’s windows laptop I’m sure. Also any idea on cost? Oh also one more thing can it be made to look like ID6? Or is it the wrong unit for that? I was a bit disappointed it doesn’t have a touchscreen however the I drive knob navigates it pretty well |
09-16-2022, 12:18 AM | #83 | |
449
Rep 1,182
Rest of the items are free. |
09-24-2022, 10:42 AM | #85 |
Rep 1
Can you please advise that why the Bimmercode saying I can only have full screen on Carplay with NBTevo_X or _Y? I have NBTevo_N, purchased Carplay but can only see it on half of my screen and drives me crazy..
09-24-2022, 11:34 AM | #86 |
449
Rep 1,182
because on version X & Y full screen carplay is just a coding parameter, where as on earlier versions you have to SSH into the HU to change the aspect ratio to allow full screen - on your version it can be done with a USB stick - drop me a PM and I'll help you out, no charge.
BR2725.50 |
09-25-2022, 05:58 AM | #87 |
Rep 26
Wibbles was super helpful to me but after reading the instructions I think I’m going to give it a miss. Seems a bit complicated for me and I’m worried about bricking the unit or something.
09-25-2022, 09:36 AM | #88 | |
449
Rep 1,182
Once the bootloader is flashed, if anything fails after that the unit can be recovered. |
