05-02-2020, 05:56 PM | #68 | |
25
Rep 74
05-02-2020, 11:37 PM | #69 |
104
Rep 63
07-09-2020, 01:59 PM | #70 |
Rep 4
hooumeri
Couple of questions for you regarding the adaptive suspension; How do the two different suspension settings compare? I believe the ride height is raised 10mm compared to the standard suspension fitted to the M235i. Is this noticeable in the wheel arches particularly with the 18" wheels? My main concern with getting this option is both with the 18's and increased ride height the wheels look a bit small for the car. Cheers. |
09-04-2020, 01:11 PM | #72 | ||
304
Rep 243
09-28-2020, 03:58 AM | #74 | |
340
Rep 440
Some interesting info from my research: the 18" wheel while looking nicer, only come in a 225 section. the 19" (1RR) option code, come with 235 section SQ tires. - More interestingly though, choosing these tires is the only way to get option 840 (increased top speed limiter) in the M235i. You have to get deep into the options guide to find this info, very easy to miss. Especially sad if you live in Germany.
E36 318ti
E46 320i E82 135i F87 M2 G20 330i |
09-29-2020, 03:02 PM | #77 | |
112
Rep 16
From the equipment description of the adaptive suspension: Notes: - for M235i: specific tuning with suspension lowered 10 mm As far as I understand, both the M Sport suspension and the adaptive suspension come lowered 10 mm, for the M235i. The wheels are limited to 18" with the adaptive suspension, but I have not found myself visually wanting bigger wheels, but this of course is personal preference. I would highly recommend getting the adaptive suspension, at least judging by the difference between comfort and sport suspension setting on the adaptive option - the sporty suspension is quite stiff and depending on where you live, it might get annoying real quick to have no option of softening the setup. |
09-29-2020, 03:05 PM | #78 |
112
Rep 16
09-29-2020, 03:08 PM | #79 |
112
Rep 16
No staggered setup on the car I ordered. Somewhat related: in hindsight I would preferably spec the performance tires since the Bridgestone Turanzas the car came with are pretty awful when pushing the car at all..
09-30-2020, 02:21 AM | #81 |
112
Rep 16
It's a very simple install, it's just the top face of the button which is installed with adhesive. Nobody has noticed it's just installed on top of the OEM button lol.
This is the one I got. |
10-11-2020, 09:58 AM | #82 |
Rep 1
I have test driven a m235 today, two questions in my mind:-
(i) i can't find any sport plus mode in it, do you have that in your car? (ii) I find the new suspension (normal m sport suspension on the demo car) quite satisfying with good balance of comfort and stiffness, how is your comment on your adaptative m suspension? |
10-13-2020, 02:24 PM | #83 | |
112
Rep 16
(i) there is no Sport Plus mode like on some of the bigger BMW brothers. For "sport" there are only the Sport and Sport Individual modes.. (ii) I haven't driven the standard suspension, but the value proposition for me in the adaptive suspension is well, the adaptive part. At least in a country like Finland where road surfaces vary a lot, having the option to change the damper response is a godsent. Rarely do I drive on the sportier setting, my most used drive mode is Sport Individual where I have the sport settings except for the suspension - mainly due to road surface quality. Then again, the comfort setting is too loose for certain situations. I would guess the fixed suspension is somewhere in the middle of these adaptive settings. Depending on where you live it might not make as much of a difference (?) |
