F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 10 HU discussion
Studio RSR
      03-09-2020, 01:32 AM   #67
F20_M135i
France
101
Drives: BMW F20 M140i Xdrive
Hello,
Okay and with pleasure
      03-10-2020, 03:07 AM   #68
bjornus
Sweden
Drives: BMW E60 550i
Hi! Can someone try Sygic navigation app on Android 10. Can you change songs in background then you use the navigation app? or use split screen?
      03-10-2020, 06:45 AM   #69
shakir
Drives: bmw e60 530i
Please help! Update disaster!
Hi all. 1st time poster but love this forum for a long time as an awesome source of information!
Today I got an email from the supplier of my qualcom android head unit (octa core /64gig/4g/wifi) with a link to download android 10 (was 9 before) update.
I have updated newer versions of android 9 with no problem.
Anyway. after the update, its now stuck in a 'no signal' loop that then goes to scrambled graphics that I cant decipher enough to make out what menu its on..
It seems to be working in the background as songs were playing but the video mode seems wrong and I cant seem to fix it..
I have even uploaded and edited version of the bmw-oem xml file in case i could tweak it somehow there.
My car is CCC - perhaps they sent me a CIC Bios?
I have also tried renaming older android 9 ksw files to the 'factory reset' filename but it doesnt seem to force install of that at all..
What can I do? Obviously dont want to wait 6 months and pay return postage to china at this time of panic.
thanks so much for any help!
Shakir .
Heres the email from them - Andream
Download link:
https://mega.nz/#!2UwnRS6T!jyILVx7ka...xAEOkM3pgfcP6Q
Note:
for Android 9.0, change the file name to 'Ksw-P-Userdebug_OS_v1.2.5-ota.zip'.
for Android 10.0, don't need to change the file name.
Qualcomm upgrade instructions:
(Note: The upgrade process cannot be powered off and the files are not extracted.)
Upgrade path: U disk or SD card root directory
Step:
1. Copy the upgrade file to the root directory of the U disk/SD card (first level directory)
2. Insert the USB flash drive/SD card containing the upgrade file to the USB port.
3. Wait for the machine to recognize the SD card/U disk and the upgrade prompt box appears.
4. Click “Yes” and the system will start to upgrade until the vehicle terminal automatically restarts and the upgrade is successful.
5. The upgrade process takes 5 minutes.
      03-10-2020, 07:34 AM   #70
DaniXD
Drives: BMW X6 E71 M Performance Pack
Hello everyone today avin send to me the link with the instructions to upgrade from android 9 to 10
https://avinusa.zendesk.com/attachme....0%282%29.docx
i try to upgrade in the next days.
      03-10-2020, 08:08 AM   #71
daschacka
77
Drives: M5Competition
I've updated to Ksw-Q-Userdebug_OS_v1.3.0-ota and can confirm the bass bug is finally fixed!
Now i can enjoy my device again =)
Kri1083.50
      03-10-2020, 08:10 AM   #72
Mjam
134
Drives: E87, i3, Taycan Cross Turismo
Link to Android 10 v1.3.0 from docx above.
Kri1083.50
      03-10-2020, 08:15 AM   #73
Kri
Austria
1084
Drives: E87
Can you please Upload a copy to Wetransfer to share ? mekede share is still at 1.2.2
Kri
      03-10-2020, 08:38 AM   #74
daschacka
77
Kri
I reuploaded it to Mega since i dont have a Wetransfer account:
https://mega.nz/#!Gh9HWC4S!6GZ3RWaNv...ZUGRZLNAppWSDs
Kri1083.50
      03-10-2020, 08:48 AM   #75
DaniXD
If someone has the avin unit with the carplay dongle, and install the android 10 version can please say if the idrive now work with carplay correctly.
Thanks
      03-10-2020, 09:35 AM   #76
lehtee
144
Drives: F20
Thanks
It is problem with dongle (Autokit/Autoplay app), not a problem with our unit. You should contact your dongle seller and report the bug.
      03-10-2020, 09:45 AM   #77
DaniXD
thanks for the reply, i will try to contact avinusa
      03-10-2020, 10:13 AM   #78
ande86
Drives: BMW F20
Thanks
I just updated to Android 10 and the idrive was working properly with my carplay dongle but I also updated the dongleīs firmware before. Donīt know what helped.
Do I have to root the Unit again after the update? Cause my OK Google isnīt working anymore.
And does anybody have the problem that sound is working good but on the BMW side it says that no AUX device is connected even though it is ticked, i can adjust the volume and the AUX sign shows up in the upper right corner?
I didnīt connect to the AUX in the middle console as everything was working fine, just the AUX in the main harness is connected. I tried a lot of settings and but nothing helped. Does the AUX option in the settings has to be ticked or not?
Kri1083.50
      03-10-2020, 10:35 AM   #79
Kri
Austria
1084
Drives: E87
Rotation of the Idrive at carplay is also correct now (left/right mixed) ?
Yes you have to root your unit again after every update.
Kri
      03-10-2020, 11:07 AM   #80
ande86
Drives: BMW F20
Kri
Yes the roation was correct this time in Android 9 it was the other way round
      03-10-2020, 11:17 AM   #81
ande86
Drives: BMW F20
But your Google maps zoom with tasker was working fine without root, did it just need the root at the beginning when you install it?
      03-10-2020, 11:44 AM   #82
DaniXD
Finally i update my unit, everythings work, idrive globally in every single app and full support with carplay, unfortunately i have 2 issue:
1) if i start the car in the oem side as normally i do for listening music with my iphone with the carplay dongle inserted the unit automatic routing in the android side, if not inserted the unit stay in the oem side.
2) after checking every installed app, in Android 9 the Onkyo HF Player worked full screen but now work as the imaged attacked.
Any suggestions?
      03-10-2020, 12:06 PM   #83
whitewidow
Drives: 355i
Hey guys and gals. I know this forum post is mostly for the f30 and 10.25" Android HU. But i have a 2010 e90 with the 8.8in CIC Logic 7 stock system. No ComBox. I am looking into getting this Android Snapdragon unit.
Andream 8.8" Android 9.0 8core 4G 64G Car Multimedia Player
https://www.aliexpress.com/item/3284...65ae4c4dSaJnBA
Are these smaller units compatible with the android updates being posted here? If so I assume root is possible on this unit. Can someone post a link to the rooting instructions? Would the system wide idrive controller work on this unit as well? Is there a way to map the voice control steering wheel button to Google Assistant?
Also do these unit not need the aux cable routed to the center console? In this post he is stating he does not use the AUX cable.
https://www.e90post.com/forums/showp...&postcount=497
      03-10-2020, 12:06 PM   #84
akirax
31
Drives: BMW F30
Now with 1.3.0 bass sound bug is fixed.
Now I hope that they will include usb microphone support (in Android 9 there was support) in next update.
Also
would be great add also support for gamepads like xBOX and PS3 PS4 gamepads.
It's very easy to include support when they are creating the kernel.
If you know a good seller that he pay attention to you (mine is very bad seller, dont answer to my cuestions or problems), please tell him to include in next updates.
Cheers.
      03-10-2020, 12:20 PM   #85
TheRoss
Drives: F31 320xD 135 KW 10/2014
Would be interesting to know what advantages we have over the Android 9.0 one.
Specially in terms of booting times comparison between both units
F20_M135i100.50
      03-10-2020, 01:31 PM   #86
Mjam
134
Have they opened Bluetooth for connection to other devices than phones?
Is the low sound bug fixed?
What is the boot time?
      03-10-2020, 01:54 PM   #87
Xanderl
Drives: F30
Where i can get a new firmware for carplay? 😬
      03-10-2020, 02:07 PM   #88
ande86
Drives: BMW F20
My dongle is from carlinkit and when I open the app and go to settings and scroll to the bottom, there you can check for updates. On the left for the app and on the right for the dongle
f30post
