04-25-2019, 09:27 AM | #67 |
1424
Rep 1,821
I have around 3000 miles on new transfer case. Obviously no problems yet, the original one lasted over 85k miles and wasn't 'finished' yet.
I will be pulling the driveshaft down to install the rubber flex disk (giubo) soon, so I can inspect how it's holding up. Lots of city driving will accelerate the wear and failures, while highway miles protect it. I agree when you said that xdelete won't help, because I have been running full 2wd mode for quite a while (using an alternative method to xdelete), and it didn't really help. I've gotta pull the original TC out of the box in the garage and take close up pics with it cleaned. The wear pattern really suggests vibration wear. I can also have my dad test the flange for hardness with his new tester, but I don't expect it to lead to many conclusions. It's obvious the flange is softer than the shaft, and you'd want it that way. I expect all the dealer transfer case replacements have sent the worn transfer cases to BMW or ATC for rebuild. Over the last few weeks, I have been thinking of methods to soften the engine torque at idle speeds (in the ecu tune) to prevent the vibrations while car is in drive and stopped. I have a few tricks to try. It's interesting that the manual xdrive 4-cyl cars from Europe aren't reporting much of this.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
04-25-2019, 06:38 PM | #68 |
197
Rep 368
Got this done last night. May have gone a lil heavy... Had a little unexpected loctite oozed out into the groove for the flange retaining ring. That was fun to clean out! I used the primer on shaft and flange and it appears it hastens the curing process quite a bit. The loctite had gotten clumpy in the groove in the 15 minutes or so spent before I came up with a way to clean it out. Probably spent 2 hours trying to comfort myself that it was all out and that the ring was fully seated lol. Though with that loctite it probably shouldn't be able to move anyways.
We'll see how it holds up, the flange teeth looked pretty good for 25k. Did the rubber guibo as well. For getting the bearing protrusion distance right I grabbed a drill bit with a 4.75mm diameter (spec'd range was 4+2mm), made that job pretty easy. Original distance was about 7-8mm. I was starting to feel a little hiccup when starting from a dead stop, Dont know if it was the guibo, the loctite, or both, but that seems to be gone. Only have put a few miles on so far though. |
Enabled1424.00 |
04-25-2019, 08:55 PM | #69 |
262
Rep 335
Is this a job for a lift or jack stands? I’d love to do this but it’s probably a step beyond anything I’ve done on my vehicle before... first time for everything I suppose
Edit: went back to OP and saw it was all on a lift which sure makes things easier I imagine. Last edited by CTMike; 04-25-2019 at 09:04 PM.. |
04-26-2019, 09:05 AM | #70 |
197
Rep 368
No reason you couldn't do this on stands. That's how I replaced the TC twice. Just bought a quickjack for my latest session. Very happy with that purchase! All 4 corners up and level in 5 minutes.
Of course a lift is best for any under car work if you have access to one. |
CTMike262.00 |
04-26-2019, 11:02 AM | #71 | |
262
Rep 335
04-27-2019, 07:07 PM | #72 |
197
Rep 368
They drop the price to $999 every couple months at costco. I've been eyeballing and contemplating for almost a year, finally pulled the trigger lol. Doesn't go super high, but makes sliding under the car with a creeper easy, Perfect for all the covers under these beasts!
04-28-2019, 08:00 AM | #73 |
114
Rep 233
I see that an updated output flange is available for less than $150. My car has 60k miles on it and I'm thinking of doing this job, replacing the flange and guibo and adding the 660. Is it correct that the wear is mostly to the output flange and not the shaft? Any idea if the updated output flange 27107595650 is better at preventing this failure than 27107593440.
04-28-2019, 01:49 PM | #74 |
197
Rep 368
Interesting, didnt realize they had an updated part available. It appears to be the flange from the ATC-45L. Not sure what's different about it though.
When I rebuilt my TC the shaft was also worn, which cut the life of the replacement flange down to 25k miles. So ideally you would probably want to replace it, but with the loctite holding it together you could possibly get away with leaving it. |
04-28-2019, 01:56 PM | #75 |
1424
Rep 1,821
There is no 'update'.
The flange posted above would not fit/wrong part number. Use only the last 7 of your vin and see the last available part number shown for your car. If you click on the part number, don't make the mistake of choosing parts that say "non-exchangable retrospectively" because they will not fit your car. RealOEM is a little misleading with that. You can also see that it's not installed on F30 at all. They have different bolt diameter and sizes. Also, there will be a little bit of wear on the shaft when there is moderate to severe flange wear.
Pittcrew34.00 |
04-28-2019, 02:29 PM | #76 |
114
Rep 233
I see that now, thanks. The FCP Euro page shows the flange with a collection of washers. Does the spacing have to be set exactly and these washers are different thickness?
04-28-2019, 04:02 PM | #77 |
1424
Rep 1,821
Correct, they are different thicknesses, and you have to set it to the tolerances. I think kdog_x had posted the instructions, if not, I can post from newtis.info
04-29-2019, 09:11 AM | #78 |
197
Rep 368
I actually did it by trial and error, stepping down in washer thickness until the circlip ring just fit. But that is much easier with the transfer box off of the car.
The newtis instructions are a little more calculated. I'd recommend going that route https://www.newtis.info/tisv2/a/en/f...r-box/KVymAjuL |
Enabled1424.00 |
04-29-2019, 03:59 PM | #79 |
11
Rep 15
I was thinking of picking up a used TC for when mine finally let's go and making sure it has these modifications, and is ready to go. Local wrecker has one for $400, out of a 2014 320i. Is it same unit as my '14 328d? It's got 43k miles on it.
04-29-2019, 05:17 PM | #80 | |
1424
Rep 1,821
FYI, when you change transfer cases and/or transfer case actuators, the control module has to be programmed. The transfer case has a calibration number printed on it that must be inputted into the module. If not, it will throw codes at you eventually for incorrect calibration, as it "measures" and builds up adaptations about internal tolerances.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 04-29-2019 at 05:38 PM.. |
havesignals10.50 |
06-25-2019, 12:35 AM | #81 |
10949
Rep 4,554
Drives: 2015 328d xDrive
kdog_x Enabled
I'm not much of a DIY'er and i'm on a budget. Would having a local indy mechanic install the rubber guibo (by itself) be a good cost effective preventative maintenance measure for my car (328dx, 42k miles) or should I not bother unless I'm also replacing the flange and putting in the loctite? and if it is a worth while upgrade, would i need the entire flex joint kit : https://www.fcpeuro.com/products/bmw...yABEgI9yvD_BwE or just the flex joint itself : https://www.fcpeuro.com/products/bmw...iABEgKEYPD_BwE Thanks for the help. |
06-25-2019, 07:26 AM | #82 |
1424
Rep 1,821
If you're there changing the giubo, it's only another 20-30 minutes to remove, clean, and loctite the flange. Considering the transfer case is over $4000 now, it's good prevention.
Make sure you carefully select your giubo accounting for the size change (bolt circle diameter) that happened around 2015. You can use the kit, although I don't think it's strictly necessary. Pay attention to the rubber bushing alignment as described earlier.
06-25-2019, 10:40 AM | #83 | |
10949
Rep 4,554
I am already feeling some slight hesitation and jerking on acceleration. Should I replace the flange or would the loctite be enough to remedy this?
06-25-2019, 10:58 AM | #84 |
1424
Rep 1,821
Hesitation is very subjective, so I would make that decision once the driveshaft is free and out of the way. If there is only a little bit of play, enough for a wiggle, then a new flange and loctite would be ok. If there is a lot of wear, then often the shaft is worn too, so it will complicate things.
Loctite 660 is designed to fill in some wear and fix play, but I wouldn't depend on it if there is advanced wear. The only reason why I inspected mine is because it was leaking fluid, due to play between the seal.
06-26-2019, 09:26 AM | #85 |
Rep 43
I knocked out the rubber UFO replaceent (upgrade) and Loctite 660 last night. I will add that I struggled more with my bluetooth speaker in the shop disconnecting than the actual wrenching. I do have lift, so freedom of movement and access to the back of the transfer case was in my advantage. It's not a tough task at all. The rubber UFO replacement definitely has flex that shows itself when tightening the flange bolts during install, so it should absorb more vibration coming from the motor.
I didn't take any pics as it was 100*+ in the shop and I was working as diligently as possible to knock this out and get to bed. |
06-28-2019, 08:54 AM | #86 |
Rep 43
Alright folks, what am I missing here? After the rubber guibo swap and loctite 660, I now have drivetrain vibrations on decel at speeds over 75 mph. These vibrations were not present prior.
Is there some fancy way to install these guibos? Anyone know the torque specs? I have a feeling something isn't correct because as it sits right now, the guibo as a zig-zag shape to it between the flange bolts and the driveshaft bolts. |
06-28-2019, 09:49 AM | #87 |
1424
Rep 1,821
Did you follow this for the driveshaft centering bushing? The protrusion distance has to be changed a little. See these instructions, about mid way.
https://www.newtis.info/tisv2/a/en/f...shaft/1Loe7egW You may also have to release the midshaft nut to allow driveshaft length to change slightly.
06-28-2019, 10:31 AM | #88 | |
Rep 43
Somewhat, but wasn't really sure about the centering sleeve protrusion. My rubber disc fit loosely onto the driveshaft, thus allowing it to move around up until tightening of the flange bolts. Does this mean 4+2 MM after the disc has been tightened to the driveshaft flange? If so, I'll need to add some washers between the disc and the driveshaft flange to reduce the distance. I also reused the nuts, but with red loctite. Should I replace with nylock nuts from the hardware store? I'm seeing now that I did NOT torque to 55 NM, which is 40 ft lbs. That may explain why the rubber disc was pulled at an angle to each bolt hole. Last edited by mpm01; 06-28-2019 at 10:48 AM.. Reason: clarified questions |
