06-30-2018, 12:08 AM | #67 |
71
Rep 112
Drives: 2017 BMW M2 - Mineral Gray
Great thread, thank you. Ordered the LED lights off Amazon. Looking forward to installing them!
Update: Installed! Super easy to do, inexpensive, and look great! My kind of mod. Thanks again ChrisK! Last edited by 425M2; 07-02-2018 at 09:00 PM.. |
ChrisK4454.00 |
11-03-2019, 04:03 AM | #68 | |
Rep 14
Has anyone tried the BA15S of the same brand (Tuincyn) for the tails? https://www.amazon.ca/dp/B0725VQZS3/..._zvQVDbV0VS6C0 I'm in Canada and they're easier to get so wondering if anyone has had any luck with them, with or without coding. |
11-03-2019, 09:23 AM | #69 | |
10949
Rep 4,554
Drives: 2015 328d xDrive
11-05-2019, 04:19 PM | #70 | |
143
Rep 185
https://www.amazon.com/TUINCYN-Repla...ve&sr=1-2&th=1 |
11-13-2019, 12:06 PM | #71 | |
148
Rep 266
mssVT98142.50 |
11-13-2019, 01:47 PM | #72 |
143
Rep 185
11-18-2019, 05:58 PM | #73 |
148
Rep 266
Glad you got the right ones. Not to make things confusing but the rear tail bulbs are not the same a the fronts. I'm pretty sure the prongs are 180 version if you're looking to change those. Also make sure to change the bulb type to LED if you have bimmercode
11-19-2019, 05:36 AM | #74 |
455
Rep 1,389
my rear lights are pretty dim when reversing, I usually upgrade my cars to LED just for more light when reversing in the dark.
Is this easy to achieve/get to the rear light cluster? |
11-19-2019, 12:47 PM | #75 |
148
Rep 266
It's not that bad. You could probably replace them in 30 min.
11-19-2019, 01:59 PM | #76 |
143
Rep 185
Yeah, for the tails I just got the ones listed by the OP of this thread, and then the 1156BAU for the fronts. Swapped everything, coded it to LED, all good. Hardest part was probably getting the back of the taillight off, since some of the clips were a little finicky and I didn't want to break any of them.
11-19-2019, 02:02 PM | #77 |
143
Rep 185
Yeah, getting the light cluster out was easy - just remove the two nuts, wiggle a bit to loosen it, then pull it straight out. Like I said above, the hardest part was probably getting the back of the taillight off, since some of the clips were a little finicky and I didn't want to break any of them. Ultimately I probably didn't need to worry - they don't have to move very far to unclip. I didn't even pull the wiring harness off, just swapped the bulbs and put everything back in.
11-23-2019, 10:15 PM | #78 | |
Rep 14
03-01-2020, 07:20 PM | #80 |
18
Rep 36
Just did the bulb upgrade and coded via bimmercode, but still getting a brake light malfunction for both sides. All lights seem to be working just fine. Any suggestions are appreciated.
03-01-2020, 07:59 PM | #81 |
10949
Rep 4,554
The lights will work regardless of coding, the coding is just for the bulb errors. I would recode everything you changed in the tail light back to bulb and then back to LED to see if that fixes it.
03-01-2020, 09:05 PM | #82 |
18
Rep 36
I tried your suggestion and still getting the error. I ended up buying a set from Sirius that says it has "built in resistors" because the others were out of stock. I wonder if that could be causing this issue.
03-01-2020, 09:15 PM | #83 |
10949
Rep 4,554
03-02-2020, 12:08 PM | #84 |
2865
Rep 3,844
I'm not trying to be a salesman but I have 2 sets of LEDs from my M235i. I spent quite a bit of time selecting the best ones. I'd be happy to pass them on for a minimal price. They are just sitting in my garage in baggies.
03-05-2020, 10:44 PM | #85 |
18
Rep 36
AndrewC198910949.00 |
03-07-2020, 07:44 AM | #86 |
481
Rep 684
I went with the Sirius ones out of the gate back in 2017 and they've been perfect ever since. Super bright too. When I tap the brakes on a dark road I can see everything light up behind me.
2004 E46 ///M3 SMG Convertible Carbon Blk\Imola
2017 LBB ///M2 DCT 2013 Porsche Boxster S |
04-14-2020, 12:53 PM | #87 |
178
Rep 765
Still have this sets? Very interested..
08-02-2020, 04:42 PM | #88 |
159
Rep 159
Looks like Sirius no longer makes the LEDs in the link provided, and we're stuck with a choice: white + lenses (CK/EK series: https://www.siriusledlights.com/coll...ght-1156-white) or red + no lenses (KG series: https://www.siriusledlights.com/coll...light-1156-red).
What have people who have done this mod recently been using? The picture in OPs first post has me a bit scared to try the KG bulbs (no lenses), since it seems to be too diffuse and light up the interior. The Tuincyn ones recommended wouldn't be here until sometime in October, so looking for something a little faster... |
