11-20-2016, 03:24 PM | #67 |
Rep 8
I have not had any issues with my rear liftgate, or the rattling.
My issue at about 11K miles was severe tire cupping on the front. This is indicative of crappy PA roads and also the "sport suspension". Anyone else have these issues? The factory Goodyear RF's are being replaced with BFG G Force Comp 2 All Seasons! |
11-20-2016, 10:56 PM | #68 | |
234
Rep 396
Drives: 2022 X4MC - Marina Bay Blue
'22 ///X4M Competition - fully loaded Marina Bay Blue.
Lowered on MSS springs. 20" x 10 ET20 Vertini RFS1.2 wheels wrapped in Firestone Indy 500 Firehawk 275/40 tires (square setup). Hers: '15 X4 2.8i - Glacier Silver - loaded M-Sport |
FSociety3816.50 |
11-21-2016, 12:10 PM | #69 |
Rep 8
Thanks, yea between the holes and bridge joists it's hell on cars. I'm going next week for the alignment and mounting and balancing. I'm assuming they have a CPU to adjust for the weight or they will use the correct weight while they do it.
12-20-2016, 01:57 AM | #70 |
Rep 47
Addressing the deck lid open option:
On the 428 i coupe, I had a problem opening the deck lid until I realized "I" was doing it wrong. The direction show the proper form. Back to front, not side to side. After that I've had no problems. |
12-20-2016, 08:30 PM | #71 | |
24
Rep 123
Solution to the scary windows / sun roof opening without warning
I have seen this issue a few times ( two many in fact for my taste ). One day my son ran in the house yelling " Dad it's raining and the sun roof is wide open " Damn it !!! Ok ok without further examples here is the issue: The keyfob my friend ... simple as that. One of your keyfob had the "open" button depressed for over 5 seconds around the car. It is called something like "comfort entry" if I remember ... Think of this option when it's sunny and hot and your about to get in your car. You depress the open button 5 sec and suddenly the doors un lock, the windows open, the sunroof open (if you have one ) and I guess the hatch too if you have the automatic opening option ... So. I found this because one day my wife returned home with her car and had my second BMW key in her purse ... The open button was depressed because, hey it's a girl purse and there is a lot of space in there isn't it so no object would be sqeezed on another right ? So, when she got beside my X1 the signal was sent for more than 5 sec and all windows / sun roof opened just like that. Had the same issue packing the car with the keyfob in my jeans pocket tight on my thigh. So after finding what was causing it, I called my dealer and asked if this feature could be disabled ... Of course they said : No So I took the matter in my own hand as usual (I'm a network admin so my job is to resolve problems ). Ok, then I made many searches on google ( told you I was a network admin ) and I found an application you can install on your phone ( Carly for BMW ). The apps (http://www.mycarly.com/product/bmw-app/) let you make some codings in the car computer and by chance the option to disable the opening with the open button keyfob was just there to be reset to my taste. There is a second settings identical but with the metal key inserted in the driver lock door. If you turn left for 5 sec all windows are going to open and all ... So you can keep a version of the feature which is way more secure than the depressed button which can be activated without your knowing from different ways ... By the way, the apps let you get error codes and reset check engine and service warning ... It is not expensive and I really hope you'll take a look at it. All you need is to buy the BMW OBDII dungle and the apps and you're set. Hope it will help you sleep on your two ears ( french expression ) Friendly, Loukas135 |
02-06-2017, 07:49 AM | #72 |
2017 X6 waiting for the 2022 in Late August
Rep 19
ConnectDrive Not working
I have a X4 2016 and have not been able to get any apps to load. I have them on my iphone 6 plus but when I plug in the USB cable (non Apple) the apps do not load on the screen to play. Any one know of any good vidoes on you tube that show you how to work with the apps for my X$ 2016 .
02-15-2017, 02:48 PM | #73 |
7444
Rep 11,857
Drives: MY24 G01 AW Msport
the hubs rust too fast..just turn 1 year
even weights are rusted smh |
03-10-2017, 03:05 AM | #76 |
Rep 35
8 months in and my I drive controller is not functioning. As a result I can't acknowledge the warning disclaimer on the screen and use Nav or multimedia functions.
Can't push down on controller to okay. It looks like the controller has lost power as none of the buttons are glowing orange like the other buttons in the cockpit. |
03-10-2017, 06:01 AM | #77 |
7444
Rep 11,857
03-21-2017, 09:38 AM | #78 |
Rep 4
I just got an X4M40i for about 2 weeks and have the dealership installed a hitch (no wiring harness) before I take delivery of the car. However, my hand-free tailgate opening doesn't work. Would it be possible that the hitch is blocking the sensor? I will bring my car back to the dealership, but would like to be more educated before I speak with them.
Thanks you in advance. |
03-24-2017, 07:50 AM | #79 |
Rep 7
My issues with X4
The wheels are the Xline diamond cut version, within 11 months of new the wheels corroded, these got swapped out by BMW, and here we are again, not even a year and same again!!!, I have pointed out that the paint finish is substandard and does not reach a standard that many of the cheaper manufacturers manage - but not BMW.. I have complained for 6 months, all to no development or result... its really like thanks for buy the car, we got the money now off you go... I have seen better quality wheel finishes elsewhere within BMW range, and seen many other brand cars with same finish wheel all with much better finish, but getting this sorted, is going nowhere.. Other issue, when car is wet or it has rained or been washed, if you open the rear water pours in.. - sure testing would have noticed this, and fix would have been found..
03-29-2017, 10:13 PM | #80 | |
804
Rep 2,599
FSociety3816.50 |
08-02-2017, 03:47 AM | #81 | |
Rep 7
As follow on to the below, I just got another set of new wheels, again corrosion, again same issues, 3 sets in two years, 20k on the clock.. but for BMW it’s not an issue, just keep replacing them, 12 month warranty - at this rate when the cars 10 years old it will still be getting its annual new wheels 😀
08-03-2017, 08:59 AM | #82 | |
804
Rep 2,599
09-11-2017, 09:04 AM | #84 |
7444
Rep 11,857
i notice slight vibration when reaching speeds of 70+. I feel the vibration on the steering wheel. 22k miles with DWS06 tires. I think rebalancing wheels and wheel alignment should resolve it.
any suggestions? |
09-11-2017, 01:03 PM | #85 |
804
Rep 2,599
nyalpine907444.00 |
09-25-2017, 01:36 PM | #86 |
Rep 11
Just replaced 4 dws06 tires on my x4, and immediately noticed vibration on the highway. I thought the tires were balanced correctly and took it back for rebalacing all 4 tires. It rides smoother now but still not as smooth as the previous stock GY LS2 tires. Maybe because the sidewall is too soft than the RFT? Anyone has similar experience?
nyalpine907444.00 |
09-26-2017, 06:18 AM | #87 | |
7444
Rep 11,857
i havent been able to get the wheels rebalance. |
09-27-2017, 05:55 AM | #88 |
7444
Rep 11,857
update:
yesterday afternoon I was able to get front tires rebalanced. I also notice the rear tires are low on tread. Tire tech measure 3/32. On tirerack under warranty, if tires size are different the life span of tire is half. Contis DWS06 is rated for 50k miles. Now im thinking of going back to RFT, a peace of mind when traveling. I guess i have 2 choices Mich PrimacyMXM4 ZP or Conti ProContact GX SSR both are grand touring Last edited by nyalpine90; 09-27-2017 at 07:38 AM.. |
