I cloned my MSV70 DME
09-23-2014, 11:18 AM | #67 |
81
Rep 525
09-23-2014, 12:04 PM | #68 |
2470
Rep 9,004
09-23-2014, 10:00 PM | #70 |
65
Rep 243
Guys, I'm not comfortable releasing Vishnu's maps out to the public. My map is not exactly as OTS as the n54/n55 ones are.
But I will tell you that the 5c71e (intake valve setpoint) map is altered in my tune. It is gradually more aggressive than stock, but does not feature the 330i higher lift earlier in the rev range. People are questioning whether it can do this or whether it can do that, so let me explain something. The Vishnu OFT is used for downloading your stock .bin file, and uploading your tuned one. If you can change it in the .bin file, you can load it into your car. All you need is knowledge of how the maps work and what effects it has on the vehicle. I can change anything from valve lift to throttle while the car is warming up the cats. Anything that AA or Evolve, ect can do, can be done with the OFT. I could take an AA .bin file and flash it to my car with my OFT, if I really wanted to |
09-23-2014, 10:29 PM | #71 |
3975
Rep 7,215
That was the point i was trying to make in the OFT thread when everyone said it was impossible to make your own tune. lol
Looking to take my car for a baseline soon.. then the fun begins! Last edited by hassmaschine; 09-23-2014 at 10:35 PM.. |
09-24-2014, 02:05 AM | #72 | |
2470
Rep 9,004
09-25-2014, 03:15 AM | #74 | |
17
Rep 163
And I am astonished that it seems that a 330i produces more power than a tuned 325i by Vishnu. Could that be true? btw, really interesting thread Subscribed
2012 M3 ZCP | GTS | PP | Akra | SKIICS
09-25-2014, 07:29 AM | #75 |
Freight Dawg
104
Rep 2,103
Yes it true. It's something that's been elusive for 325 guys even with a 3-stage manifold.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-25-2014, 07:40 AM | #76 |
17
Rep 163
Strange, as my car produces more torque and more power than a 330i and I have a better acceleration (5.7sec vs 6.0sec 0-100km/h)....
09-25-2014, 07:46 AM | #77 |
3975
Rep 7,215
isn't the 330i exhaust slightly different too?
there's so many factors, maps and curves that are different between the two, it's not that surprising. I really doubt many of the tuners have dug too deep considering the big gains and money are in the N54/N55 tunes. |
09-25-2014, 07:52 AM | #78 |
17
Rep 163
Yes, the 325i exhaust is much more restrictive than the 330i's
I can search for backpressure values, I know i have these lying around somewhere....
09-25-2014, 07:52 AM | #79 | |
Mike: Everyone's Pal
2046
Rep 2,972
Drives: F80 M3
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
09-25-2014, 08:44 AM | #80 | |
3975
Rep 7,215
I believe it's possible to flash the entire 330i file over to a 325i (making sure to leave the original 4kb eprom) but that might not be a good idea if there are physical differences like the exhaust. I want to test that theory on my spare DME by using the original test donor bin with my 4kb eprom. I'm thinking all the VIN/ISN data is stored there. |
09-25-2014, 09:31 AM | #81 | |
Freight Dawg
104
Rep 2,103
--Marcelo
09-25-2014, 10:25 AM | #82 |
2470
Rep 9,004
Just checked realoem:
The 328i uses a different exhaust manifold from the 128i and 325i/330i The 128i uses the same exhaust manifold as the 328xi, but again not the 325i/330i The 330i uses the same exhaust manifold as the 323i/325i The 330xi uses the same exhaust manifold as the 325xi N51 cars have a different exhaust manifold and different down stream catalyst, shared between the 128i and 328i. The bottleneck has to be the software, and for all N52 powered cars - headers. |
09-25-2014, 12:52 PM | #83 | |
Old Geezer
366
Rep 1,193
Drives: 08 E92 N53B30
09-25-2014, 04:50 PM | #84 | |
81
Rep 525
however I would still think that a full bolton 325i to be faster than a stock 330i, however just adding the 3 stage intake manifold with a tune is probably not going to do it... |
09-25-2014, 05:05 PM | #85 | |
2470
Rep 9,004
09-25-2014, 07:46 PM | #86 |
Freight Dawg
104
Rep 2,103
I'm fairly confident you're correct. I've done some pretty extensive research on the physical differences between 325 and 330 engines. They are IDENTICAL. Same part numbers for everything including long block, head, ECU. The only differences are the muffler and and intake manifold. I'm not sure about the software because I haven't looked into it. I know the software is extremely complicated and that there is a difference between the two cars. What we've seen here is just one table. There are hundreds more for all sorts of things.
BudVlad, you have an N53 so I can't comment on that.
--Marcelo
09-26-2014, 04:04 PM | #88 |
3975
Rep 7,215
toyed with valve lift a bit. there's also a full load (vollast) map of course. I found the factor for maxiumum lift (10mm). I set the VL map to 10mm from 9.7, can't say I can tell any difference, but I'm not surprised. it's only maybe 3% increase at most. I'll reset it to stock before getting a base line.
I also tweaked the torque scaling factor for torque reduction requests via CAN (aka, traction control). basically it's a scaling factor, so if the ABS system requests a 50% reduction in torque, it multiplies that by the scaling factor and that's what it uses to reduce the actual torque output (this is way simplified but you get the idea). stock was set to 400nm, I started with 200nm. coming from a car without any form of traction control, I found it to be pretty annoying and maybe even a little dangerous. I might play with it further but at half of what it was before, it seems much better - enough for a bit of safety factor, but not so much that it feels like somebody put the car in neutral. it would give me a little bit of wheelspin without letting it get out of control. too bad the car doesn't have LSD.. I set the fuel cut additive factor to 0 to see what happens. it still hits the spark retard first, basically can't tell any difference from stock.. there's a bunch of constants for disabling spark retard, I'll just have to try them and see if I can make the rev limit fuel cut only. so far the only change that's really improved anything is the torque scaling factor, but there's still a lot to learn! |
